Neocorrado
Activating the Dormant rear Fog lights
The rear fogs are not activeted for the US :mad: Corrados but i know they are for the Euro ones!!! does anyone have a pic of them on ? i wonna see what they look like cause i want to get mines activeted...
Bear in mind the nearside rear fog has no metal heat deflector like the offside one has, so there is a risk of melting the plastic during prolonged use. You should be OK if you don't leave the fogs on for too long.
less than that...
the later switches are better becuase there are seperate ones for front and back but then again the fronts also crack because of the intense heat :roll:
Ya i know what you mean, i had changed my front ones before but they cracked again so i just leave them, what if i put a low voltage light bulb in it, would that help ?
you'd need a low WATTAGE bulb to reduce the heat... low Voltage would make it brighter/hotter and last lots less time... ;)
