Philuk 0 Posted July 26, 2016 Changing power steering pipes, what a poor job it is to do. Took 2 nights to change the pipes and then I need to fill it back up and test it! I really hope it works otherwise it's rack off which I didn't want to have to do before vwf :( Quote Share this post Link to post Share on other sites
Philuk 0 Posted July 27, 2016 And it doesn't work, new rack on its way and the garage can replace it Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 27, 2016 Whats wrong with it Phil? The PAS system can be a mare to bleed properly. Keep it in the air with ignition off, do the lock to lock thing there, then start the engine and do it again. Finally, do it again with wheels on the ground, then again on a bit of a test drive. The pump can whine like a bitch sometimes, but often settles down after a while. Quote Share this post Link to post Share on other sites
Philuk 0 Posted July 28, 2016 The steering seems to bleed fine, steering is perfect after being filled for about 2 mins and then it feels like the belt has come off, the steering is that heavy Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 28, 2016 Have you replaced the pump? I'd do that before the rack mate. Quote Share this post Link to post Share on other sites
Philuk 0 Posted July 28, 2016 3 pumps, full set of pipework, back to a genuine original pump after 2 brand new ones, can't be anything but the rack Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 28, 2016 Ahh............................. Quote Share this post Link to post Share on other sites
Philuk 0 Posted July 28, 2016 Other than burn it, if this doesn't sort it I'm really stumped Quote Share this post Link to post Share on other sites
culshaw 1 Posted July 28, 2016 Replaced passenger side door handle, now it opens properly yay! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 28, 2016 I'm still wetsanding my bonnet, applied some lacquer and it didn't go well so back to wetsanding it. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted July 29, 2016 Fitted new AP Coil overs. No major issues set just below standard height for the next 50 mile for them to settle then will adjust to around 30 / 40 mmm drop. Quote Share this post Link to post Share on other sites
MZpog 10 Posted August 5, 2016 Upgraded my brakes from 256mm to the G60 280mm setup. Plus an oil change for the old girl. [ATTACH=CONFIG]84236[/ATTACH][ATTACH=CONFIG]84237[/ATTACH][ATTACH=CONFIG]84238[/ATTACH][ATTACH=CONFIG]84239[/ATTACH] Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted August 6, 2016 Had a great holiday with the s/c VR6 until alternator packed up Luckily some of the VR6OC lads came over to where I was staying in Cornwall to give me a hand and now all back together. Cleaned and ready for VWNW tomorrow! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Hisnibs 10 Posted August 7, 2016 Finally got around to slinging the Audioscapes on - more of a faff than anticipated. Went for body colour (la9v) opposed to leather, as I was hoping it'd lift the gloom and it really, really does. Just the right side of Honda civic fartcan in the flesh. [ATTACH]84243[/ATTACH] [ATTACH]84244[/ATTACH] Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
vwfil 0 Posted August 7, 2016 De-wipered the rear window. Removed car phone areil from rear window re-soldered and heat shrank radio loom as previous owner has for some unknown reason cut off the plugs. Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 14, 2016 [ATTACH]84313[/ATTACH]got the speedo out so I could get at the bulbs that aren't working. Hopefully order them tomorrow Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 14, 2016 [ATTACH]84313[/ATTACH]got the speedo out so I could get at the bulbs that aren't working. Hopefully order them tomorrow Sent from my SM-G900F using Tapatalk Ooo can you tell me what the bulbs are please one of mine is out too Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 14, 2016 The green one is 1 of 3 that sit at the top and shine the light into the gauges. 12v 1.8w The black one is 1 of 2 that sit behind the electronic displays. 12v 1.2w I'm going to contact TPS tomorrow to order them in. Previous searches I've looked at talk of blue bases but these are green !! So I'll check with VW Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
vwfil 0 Posted August 14, 2016 B4 moonroof conversion as my original sunroof was dead ! Quote Share this post Link to post Share on other sites
Hisnibs 10 Posted August 16, 2016 Roose coolant kit - somehow have 2 left over though (well, 3, was never getting to the back of the oil cooler). Kinda mystified as to where the 2 go :scratch: Oh and resprayed bonnet as a boulder took a liking to it. Bit orange peely but carpro's denim pad will munch that up double quick. Really feels like it's getting somewhere now :cheers: Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 16, 2016 [ATTACH]84321[/ATTACH]Fully working set of lights. Happy for the most expensive bulbs ever. .. Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Jim 2 Posted August 16, 2016 Spent a couple of hours installing a new bonnet cable (thanks easypops) along with a new trumpet thingy for the far end of the cable from VW Heritage. Actually was a pretty easy job but just took extra time as I decided to replace the cable outer as well as the inner, and also removed the front lights just so I could actually release the bonnet in the event the cable didn't work the first time I pulled it all shut :) Pleased to say it works perfectly and the bonnet release lever action is suuuuuppper smooth now :) Quote Share this post Link to post Share on other sites
Jim 2 Posted August 26, 2016 So popped back to the lock-up and re-visited the bonnet cable. Ordered some heavy duty bowden cable sheathing on eBay and made up a nice new replacement for the 'middle' bit of the cable that sits across the radiator. Looks spot on. Also raised the height of the coilovers a bit (too damn low) and adjusted the camber on the front wheels - sitting, and riding much better this evening! Off to Stealth tomorrow morning, as it's 750'ish miles since the rebuild so ready for a second oil change and a new filter. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 27, 2016 Btw both GSF and ECP doing heavy discounts over the bank holiday weekend. Check the sites for discount codes. Quote Share this post Link to post Share on other sites
ed.speller.7 10 Posted August 28, 2016 Got the 20vt running sweet just as I think all is well oil leak out the top the oil cooler so stripped front end back off to fix. But if that's my only problem I cam cope with that Quote Share this post Link to post Share on other sites
