DaveVR6 0 Posted June 10, 2005 Wonder if anyone can help.. My drivers side door has never shut easily and always needs a good push to get it to catch. Because of this the electric window developed quite a rattle on closing and now does not rise evenly, slows down, left side (of the window) goes up and bit then the right side. Sometimes it just stops and you have to grab the top of the glass and jiggle it a bit while pressin the button. Went to the local dealers and they quoted me 70 buff for a whole new window mech, but im guessin its just a clip or somehting that has broke/is breaking... sound reasonable??? Also, the reason the door is not closing.... is this the common corrado door prob? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 10, 2005 Nope, the most common Corrado door problem is the door handle breaking... Almost all Cs have rattly windows if they're not 100% closed when you slam the door. Some people have actually had the glass break when they closed the door .. £70 isn't too bad, considering the Corrado tax. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 10, 2005 Door closure - it's an alignment thing. See if you reduce the closing pressure by slackening the striker pin (15mm spanner) on the B pillar and moving it out a bit. Window - Kind of sounds like the glass clamp is loose, possibly from the years of door slamming. Either that or one of the guide gutters is loose/missing or the plastic pulley guides at each of the mech have snapped.....that's quite common. Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted June 10, 2005 Cheers guys, dr_mat it does feel like the glass is gonna break in when I close the door! eek Guess im best getting the door card off and having a good look. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 10, 2005 The glass should only rattle if you close the door when it's right at the bottom of it's travel as that is when support from the inner and outer seals is at a minimum. Anywhere from an inch above the weather seal to the top of the door frame, the glass shouldn't rattle at all. Yeah you need to take the door card off and see what's going on..... Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted June 10, 2005 The glass (or the mechanism) rattles whenever I close the door, even when the window is fully closed! Quote Share this post Link to post Share on other sites
Dan_Storm 0 Posted June 10, 2005 Quote The glass should only rattle if you close the door when it's right at the bottom of it's travel as that is when support from the inner and outer seals is at a minimum. Is it possible to fix/improve this? With the good weather I love driving round with the windows open (sod the air-con) to hear the VR do its stuff. But the sounds of the glass rattling when closing the door is awful! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 13, 2017 Arise old thread!! Guys please help, what causes window to rattle when the window is down a bit? It's bugged me for years, I just took the card off but can't find the source of the rattle. It's drivers side door and the rattle sounds like it's near the handle/ catch/ mech area Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 13, 2017 (edited) Usually its the window rollers that cause it to rattle mate they wear over time. Someone on here did replacements for cheap and its a simple fix http://the-corrado.net/showthread.php?58587-Window-Rollers-on-hiatus-due-to-c*ck-up/page38 Edited February 13, 2017 by Jon_vr6 Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 13, 2017 holy thread resurrection batman!!! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted February 13, 2017 Interested in the fix too Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 14, 2017 Jon_vr6 said: Usually its the window rollers that cause it to rattle mate they wear over time. Someone on here did replacements for cheap and its a simple fix http://the-corrado.net/showthread.php?58587-Window-Rollers-on-hiatus-due-to-c*ck-up/page38 Did that hoping the same..... no good :( Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 14, 2017 lilfuzzer said: holy thread resurrection batman!!! Thanks Robin :lol: Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 14, 2017 are you sure its the window and not all that cash you have in your pocket's that's jingling Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 14, 2017 VAG-hag said: Did that hoping the same..... no good :( Loose rivet on the mech? Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 14, 2017 Jon_vr6 said: Loose rivet on the mech? Sent from my SM-G930F using Tapatalk Not that I can see mate :( Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 14, 2017 delfinis38 said: are you sure its the window and not all that cash you have in your pocket's that's jingling The car collects all my cash so yeah maybe it's all in the door! Quote Share this post Link to post Share on other sites
Wendy 0 Posted February 14, 2017 Just open the window a tad Chris. !! Stops it every time. Not like you use your car in Winter and need to keep warm. Easy, cheap Fix !!! :-) Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 14, 2017 When closed it sounds solid. This is when open either slightly or fully..... I know loads do it but I'm determined to fix it!! Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 14, 2017 When you find it , you can come round and sort mine Chris. Quote Share this post Link to post Share on other sites
Wendy 0 Posted February 15, 2017 And mine ? !! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 21, 2017 Fixed it!!!! Mine was the bottom of the rail on the handle side. Tapping against inner skin of door. Bit of felt and we are rattle free :) Boom!! Quote Share this post Link to post Share on other sites
