Kevin Bacon 5 Posted June 6, 2013 No the Microphone won't fit down there and yes the cams will work a treat. VAG-HAG's old man has them with a V9 (or could be schrick 248s actually) and his car made some impressive numbers. Quote Share this post Link to post Share on other sites
n3p 3 Posted June 7, 2013 Thanks Kev. No idea what filter to use, will post a thread. Cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 7, 2013 A small 80mm cone usually. 80mm being the ID of the MAF end :) Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 7, 2013 Kevin Bacon said: No the Microphone won't fit down there and yes the cams will work a treat. VAG-HAG's old man has them with a V9 (or could be schrick 248s actually) and his car made some impressive numbers. Mine made 305 bhp, 251ft/lb at 8 psi with 263s. Although that was a December day. You still want that Mocal, Nick? Quote Share this post Link to post Share on other sites
Rams 0 Posted June 13, 2013 Has anyone tried this idea for cooling? Looks quite neat. I'm working out what to do next with cooling as I want to increase the boost/performance. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 13, 2013 So long as you use a decent water pump (Meziere), decent size hosing (JIC/AN -10), a decent size heat exchanger and a decent size water resevoir, it should work. HPA do one for the R32 which apparently works quite well. http://www.hpamotorsport.com/intake.htm Quote Share this post Link to post Share on other sites
Rams 0 Posted June 13, 2013 They look good, thanks for link. Kev, do you prefer this to the SP charge cooler/short runner? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 14, 2013 You're on the slippery slope now mate :D I'd take the Schimmel intake and chargecooler over that any day of the week, but it's not cheap kit! Quote Share this post Link to post Share on other sites
danielmjpyle 10 Posted June 16, 2013 Gents, problem on startup. when i start the idle is up and down and eventually stalls. i have to rev it for a little while then it seems to sort itself out. What is causing this? thanks. Quote Share this post Link to post Share on other sites
n3p 3 Posted June 25, 2013 Since supercharging I have noticed my cabin feels a hell of a lot warmer than before, legs are sweating like crazy. Fan still blows cold, and I guess the heat is to be expected. Anyone know ways of keeping cabin temps down? All I can think of is heat wrapping the exhaust manifold... Would this make a big difference? Next Q relating to that - I have a stainless 6 branch from a vr6 golf which I could wrap. Will this fit? I am guessing adding the mani won't affect the map at all? Cheers Quote Share this post Link to post Share on other sites
coullstar 0 Posted July 16, 2013 Anyone know of a V5 fitted to a C? Got to thinking last night if I ever go down the power route with my car I would fancy doing something a bit differenent and though about a turbo'd V5. It should just be the same as any 24v V6 engine I would have thought with some custom exhaust mani's required. Quote Share this post Link to post Share on other sites
chazrad 0 Posted July 18, 2013 coullstar said: Anyone know of a V5 fitted to a C? Got to thinking last night if I ever go down the power route with my car I would fancy doing something a bit differenent and though about a turbo'd V5. It should just be the same as any 24v V6 engine I would have thought with some custom exhaust mani's required. Coulstar, I happened to have a chat to one of the guys at The Phirm about the V5 a few months ago and was told there is very little tuning support for it. I think everything would have to be custom and it would cost you a lot of money to achieve power gains that would be underwhelming. I'm sure it could be done, but what price exclusivity? I'd go down the rotrex'd R32 route if I was going to swap out the engine in the C now. V impressive power gains (over 500 bhp) available depending on the engine build and size of the pulley. The R32 block is a great engine. Quote Share this post Link to post Share on other sites
coullstar 0 Posted July 22, 2013 Id heard they are the 4mo block minus a cyl with an effective R32 head. Surely the internal components are the same as the 2.8VR. I wouldnt be looking at mega HP (350ish) if I was doing this so a spacer gasket with standard internals and standard intake should suffice. You can also use the gearbox from some as it has lower ratios. I realise some custom bits like the manifold and downpipe would be needed but I think it would be a cool little project. Quote Share this post Link to post Share on other sites
Dox 28 Posted July 22, 2013 coullstar said: Id heard they are the 4mo block minus a cyl with an effective R32 head. Surely the internal components are the same as the 2.8VR. I wouldnt be looking at mega HP (350ish) if I was doing this so a spacer gasket with standard internals and standard intake should suffice. You can also use the gearbox from some as it has lower ratios. I realise some custom bits like the manifold and downpipe would be needed but I think it would be a cool little project. http://www.carlicious-parts.com/epages/62028049.sf/de_DE/?ObjectPath=/Shops/62028049/Categories/%22V5%20Tuning%22 I have a 4mo BDE head and an AQN V5 head sat on shelves in the garage, I've weighed the V5 block in this morning, selling V5 engine parts is like selling nuclear waste......................... Quote Share this post Link to post Share on other sites
n3p 3 Posted July 31, 2013 Those of you running FI- is it normal to have a stronger fuel smell when starting? Wondering if I need to get it checked out. I have uprated injectors and fuel pump, standard cat, new MAF. Car runs on V Power Nitro+ if that makes any difference. Cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 31, 2013 Nope! You have a carbon can vent escaping into the bonnet somewhere, or a fuel leak :D Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted August 30, 2013 Hi, I've just finished a vortech V9 install but have what I think is a problem. T'd in my vac/boost gauge. My vac at idle is only 16 and I think it should be about 22 from what I've read. Anyone know what the correct vac reading should be? Also, I'm running the DV off the brake booster line. One of the two nipples on the one way valve. The gauge is T'd into my DV line. Anyone know if that is an ok setup? Cheers Ron Quote Share this post Link to post Share on other sites
ovens 0 Posted December 10, 2013 Hi there, I need to move my brake reservoir to make room for my turbo air intake. Can any of you tell me what fitting is used to push into the master cylinder and where to buy it from? Quote Share this post Link to post Share on other sites
Rams 0 Posted December 18, 2013 Hofmiester said: Hi, I've just finished a vortech V9 install but have what I think is a problem. T'd in my vac/boost gauge. My vac at idle is only 16 and I think it should be about 22 from what I've read. Anyone know what the correct vac reading should be? Also, I'm running the DV off the brake booster line. One of the two nipples on the one way valve. The gauge is T'd into my DV line. Anyone know if that is an ok setup? Cheers Ron I've connected mine in the same way, used a Y joiner by the fuel reg and then the other line to the brake pipe by removing the nipple. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 23, 2013 Cheers Rams, do you have a boost gauge? Just interested to see what vacuumed you are getting at idle. Mine is about 15-16 when cold and then rises to 19 once warm. Quote Share this post Link to post Share on other sites
Rams 0 Posted December 23, 2013 I do have a boost gauge, I will check the vac readings when I next go out. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 23, 2013 Thanks, still getting the issue of seeing 5psi and not 6psi on occasions. Not sure if that is just the way it is, or if I have a boost/vac leak Belt is as tight as I dare so don't think it is slippage. Quote Share this post Link to post Share on other sites
Rams 0 Posted December 23, 2013 It's not easy looking at the boost gauge when gunning it Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 23, 2013 Vac at idle will also tell if it's leaking so getting the idle vac readings from another car at cold and warm will help :) Quote Share this post Link to post Share on other sites
Rams 0 Posted December 23, 2013 How are the oil temps etc at the time you loose boost? Maybe more cooling is needed to sustain the boost levels. Mine feels quite a bit quicker on different days/lower temps. Have you got a uprated injectors and fuel pump? Quote Share this post Link to post Share on other sites
