flusted
any sprayers out there??
Sprayed my car as you might of guessed.Was told to use grey primer (which i did)but car has come out very dark.
Sprayed front bumper without priming it,and its came out really bright how i wanted it.
Should i have used white primer? or give it a load more coats?
I have always used red primer with red. My flash red raddo seems to be white primed, from the odd stone chip etc.
I cant find any big pics of your car but from the tiny ones it looks nice
How many coats of paint did you put on the car? It is certainly a lot darker.
It also looks like it needs rubbing down with 1500 wet and dry and compounding to get some shine on it, the finish looks very dull in the pic.
looks alot like the dark red (the correct name of which escapes me) that was availible on corrados from the factory, or at least I think it will when polished up. I reckon it'll look nice, although its probably not as bright and attention grabbing as you'd have liked.
The colour won't change from what it is now, flatting and polishing will only give you a better finish.
Well done for having a go yourself, looks good. If you want it the same colour as the bumper, I think you need to be painting it again. In my opinion the there is not enough paint on there, so the red is still a little transparent, showing the colour of the primer underneath.
cellulose! thanks for all the comments so far,when you rub your hand over the paint it feels very smooth so i presume ive laid it on ok but just not enough paint
If its got a good finish you can't be far our with your spraying.
I would have gone for 2 pack paint though.
What do you think you'll end up doing? If you like the darker colour, you could always paint the bumper in the same primer, as the rest of the car, and then spray it red to try to match the colour better.
Thats what id do, the darker red looks good.
Ive actually bought an rs bumper that i waiting to be delivered.Guna grey prime that,then give the car loads more coats until i run out of paint!
