Taggart 0 Posted November 14, 2005 My handbrake is bent and leans to the drivers side, catches on the side of the centre console as well. I had to take off the handbrake lever trim as it caught and snapped on the side bit. Am I ok just to bend the handbrake back? What's the best way to do this? Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted November 14, 2005 If I am reading your post right then I believe the weld comes loose where the handbrake is mounted to the transmission tunnel- I read a few posts where peoples handbrakes had almost come off!! If you whip of the side tunnel trim you'll see what I mean. I certainly wouldn't bend it anywhere otherwise you'll just fatigue it even more- prob needs sorting sooner than later :( Cheers Quote Share this post Link to post Share on other sites
Taggart 0 Posted November 14, 2005 I did have it all off yesterday and I didn't notice any loose weld, I didn't notice the problem before as my trim was sitting at an angle. Quote Share this post Link to post Share on other sites
Walesy 0 Posted November 14, 2005 searchy wearchy.... :D http://the-corrado.net/.archive/forum/viewtopic. ... ake+broken Quote Share this post Link to post Share on other sites
Walesy 0 Posted November 14, 2005 It might just be bent... Quote Share this post Link to post Share on other sites
Taggart 0 Posted November 14, 2005 I'll have it off again next time the weathers good, see if I see anything (I did actually have a look around to see if I could see anything, even half undid the bolts to see if anything could be slid) Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 14, 2005 slightly OT but how do you get the leather handbrake grip off, mines stuck fast... is there a button underneath or something??? ben Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted November 14, 2005 slightly OT but how do you get the leather handbrake grip off, mines stuck fast... is there a button underneath or something??? > Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted November 14, 2005 Whoops- Don't have it any longer- just got the trim left- sorry > Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 14, 2005 Ice White Socks, dont worry oiff to bed......... ben Quote Share this post Link to post Share on other sites
JBOB 0 Posted November 14, 2005 Mines the same and the welds are fine :roll: must just be over usage :lol: Quote Share this post Link to post Share on other sites
Walesy 0 Posted November 14, 2005 there's a little doodar you have to push up...then pull towards the windscreen, be carefull not to put your elbow through the windscreen when it comes off though! Quote Share this post Link to post Share on other sites
dinkus 10 Posted November 14, 2005 I've got a spare handle (no trim) if you need it... Quote Share this post Link to post Share on other sites
Taggart 0 Posted November 14, 2005 I found it a right PITA getting the handle off, DieselGolfWales has the method above,. Can the weld be hammered/pressured back into position? Quote Share this post Link to post Share on other sites
_leon_ 0 Posted November 15, 2005 I also have this same problem. its not loose at all - just bent (over to drivers side). the center tunnel is also sitting squint as a result. Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 15, 2005 The handbrake assembly is bolted to a piece of steel that is spotwelded to the tunnel. Over time this piece of steel develops a tear that eventually lengthens and detaches completely. Best way to repair it is by having this piece of steel properly welded back to the tunnel. I did this on my Rado and it has been fine ever since. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted March 26, 2006 But as said earlier - the metal spot welded to the frame has no tears etc in - it just seems the lever or the brackets connected to the lever are bent. Quote Share this post Link to post Share on other sites
Rossco 0 Posted March 27, 2006 Yeh mines solid but it leans over to drivers side as well, take all the trim off and push like hell, sound Quote Share this post Link to post Share on other sites
_leon_ 0 Posted March 27, 2006 or buy one off ebay thats straight for 99p ;) Quote Share this post Link to post Share on other sites
Rossco 0 Posted March 27, 2006 Well theres that too Quote Share this post Link to post Share on other sites
junkie 0 Posted March 27, 2006 suspect it will snap sometime tho if its bent as mine started that way then came completely off. Not good Quote Share this post Link to post Share on other sites
g60griff 0 Posted March 27, 2006 mine has just developed this bend. gonna have to have a little looky. Quote Share this post Link to post Share on other sites
16vrixter 0 Posted February 4, 2007 Had the exact same problem. Tried various things including hammering weld back in and using a big washer etc but these remedies all failed eventually. This is an automatic MOT failure so best getting it welded back. Got the bracket welded back on for about £40 - a small price to pay for peace of mind and another year on the road. Quote Share this post Link to post Share on other sites
