Stan 24v
Definitive 24v into a (VR) Corrado thread
  DutchVR6 said:
Where is your aux. water pump then Stan?
Dutch
Not sure mate, you know what Im like :oops:
If you need any pics, just gve me a shout ;)
Stan, can yo PM me some pictures of your aux. water pump mate?
It's either just to the back of where the 12v coil pack sat or on the front of the block between the oilfilter/cooler and your PAS pump? Could you also *try* and get some pics of your front engine mount bracket and how it attaches to your block/gearbox? I'm curious how yours has been done!
Cheers,
Dutch
Can I swap the oil filter/cooler from the 12v onto the 24v?
Reason being the 24v one is in the way of my front mount bracket and as the 12v is a slightly different design it wouldn't sit in the way?
Dutch
  CoxyLaad said:
yes you can my friend.
Mr Horrocks fitted his r32 with the vr oil filter housing and cooler
no i didn't. I used the bolt hread from the 12v
I'm going to try and see what happens as it'll be easier than modifying the mount bracket if it's possible.
Dutch
I stand corrected. My mistake.
just put me r32 engine in my corrado,but having trouble getting the std vr6 fan set up to fit,there doesnt seem to be enough room between the rad & the front of the engine?
any ideas
Personally I would dump them and use a couple of SPAL slimline fans, but maybe the 24V boys can suggest a cheaper method :-)
I've not tried to fit the rad back yet btw, but now I'm curious if it'll fit.
Will get back to you on that this evening, but I'm only fitting the 2.8 24v and maybe it's slightly different than with the R32?
Dutch
...well, my rad fits fine :)
There are several mounting holes in the cross-member for the rad. It is possible to fit it so the left fan doesn't clear the alternator, but if you mount the rad in the correct holes you will have minimum of 2 inches clearence to the engine/alternator etc.
The right hand gromet thing on the bottom of the rad has to sit in the right most hole on the cross-member, then the left one will only fit in the hole in the bracket welded onto the front of the cross-member that sits about 2 inches forward of the other holes if you get what I mean.
Dutch
Pics:
Mine fits too, but not as much room as yours Dutch.
Do you still want some pics mate? Sorry for being useless and not getting them sorted :oops:
Hello mate.
If possible pics would be handy as I'm interested to see how Andy plumbed your water piping and aux. pump. :)
Dutch
Sent some pics mate, not sure how useful they are.
Got one of the engine mount when Andy was doing the job.
My rad went straight in. Because I fitted the AC I had to remove the secondary fan, but it has made absolutely no difference and the water temp never exceeds 90 degrees.
Jay
Thanks for the pics Stan, very usefull :thumb right:
I will try and figure out my piping this weekend so if I get stuck might ask for a few more :)
Have you anymore of the front mount by any chance?
Dutch
No mate sorry. I need to get under her at some point as there is a small water leak somewhere, so when I do I'll see if I can get some.
