catch_twotwo 0 Posted February 18, 2006 Well doing allot of motorway driving right now and was wondering what I can do to drop the high revs when I'm on the Autobahn's. Right now when I'm at 80mph it's cruising at 3000 rpm.... it then raises about 500rpm per 10mph from this. Usual cruising on the Autobahn is about 100mph however. So I've had a look about the forum and seen what options there are. But what I wanted to know is this. If I fit a VR6 1st, 2nd and 5th into my box (probably with a lightened flywheel) what sort of rpm will I be getting at the same speeds ? Also, is it worth me looking at a 6spd box, and what sort of prices did this cost the people who've done this :?: For the records it's 1990 G60 with a few tweeks running on 15" steelies right now (17x7 alloys in summer). Quote Share this post Link to post Share on other sites
Timo. 0 Posted February 18, 2006 Will dropping the revs not put more strain on the engine?? especially at those high speeds. Why do you want to lower the revs?? fuel comsumption or just for wear and tear? T. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted February 18, 2006 Well 3 reasons... * Fuel comsumption * Wear on the engine * The rather loud noise from the eninge ;) It puts more strain on the engine :?: I'd have thought less as the newer cars mostly come with a 6th gear for this sort of speeds on the motorway... Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 18, 2006 You want the 5th gear cog and ancils from a Golf Tdi gear box, ASD type if I remember rightly. This wil be a straight fit into your box and should lower your revs at speed quite a bit from standard. I am in the middle of this but have managed to shear the head from the bolt holding the 5th cog onto the end of the main shaft. :roll: Quote Share this post Link to post Share on other sites
chaz g60 0 Posted February 18, 2006 I find myself wanting a 6th gear at high speeds, that 5th cog in my g60 box is that a big job?? what would you expect to pay at a garage if I dont want to brave it myself?? Quote Share this post Link to post Share on other sites
Walesy 0 Posted February 18, 2006 Yeah, i'd have liked another gear at top end in my g60 Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted February 18, 2006 You want the 5th gear cog and ancils from a Golf Tdi gear box, ASD type if I remember rightly. This wil be a straight fit into your box and should lower your revs at speed quite a bit from standard. I am in the middle of this but have managed to shear the head from the bolt holding the 5th cog onto the end of the main shaft. :roll: Hmm, ok then. Looks like I'll be looking for a VR 1st, 2nd and a Golf TDI 5th. Will this effect things with normal driving in 5th. Like having to rev it further in 4th to keep the torque into 5th :?: or is it not noticable. Silly question probably, but any benefit in getting these cogs made up specifically if I can get the exact data for them. Maybe lighweight like the flywheel change people tend to go for :?: Quote Share this post Link to post Share on other sites
matth76 0 Posted February 18, 2006 Catch_twotwo I have a golf vr6 which (I think) has even longer gearing than a Corrado VR6, if not the same and when I cruise at 3000rpm my car is doing just over 70. Your gearing sounds pretty good to be cruising at 80mph at 3000 revs. My car also revs quite high after 80mph. 1st and 2nd gearing is good in the vr6 as I can reach 65 in second. Acceleration is awesome without the need to change to third. Not sure what a tdi 5th gear is like (I would assume it is longer than a vr6). However the ultimate upgrade to reduce your revs would be a 6th gear conversion. Quote Share this post Link to post Share on other sites
Guest Posted February 18, 2006 matth76, Only thing is must 6 speed convertions use old 5th as finial drive.. Would need to find another Quote Share this post Link to post Share on other sites
G60ING 0 Posted February 21, 2006 You have 4 options for 5th gear: .756 .717 .70 .68 I would recomend the .756 or .717 Quote Share this post Link to post Share on other sites
Jim 1 Posted February 21, 2006 6th gear in my GT TDI is great on the motorway.. 70MPH is about 1900RPM.. 80MPH is about 2,200RPM I think? Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 14, 2006 My g60 sits at 2500 revs when doing 80mph, can anyone suggest why that is? As far as I know the gearbox is standard Quote Share this post Link to post Share on other sites
chrishill 0 Posted March 14, 2006 heh, you're finally back in the fold then walesy? hold the door open for me, wont be long! ;) Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 14, 2006 Yeah , shes a bit of a pig at the mo though Chris, i'm trying to get through it bit by bit. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 14, 2006 Catch_twotwo I have a golf vr6 which (I think) has even longer gearing than a Corrado VR6, Golf and Corrado VR6 have the same gearing. It's worth noting that 5th can be changed without dropping the box, so you can experiment with different 5ths relatively easily and cheaply. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted March 14, 2006 Hmm interesting to note that kev.... Although personally I wouldn't know one end of the gearbox from the rear spoiler ;) Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 14, 2006 My g60 sits at 2500 revs when doing 80mph, can anyone suggest why that is? As far as I know the gearbox is standard Anyone? :( Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted March 14, 2006 Well if you don't like it we can change gearboxes as that's what I'm after ;) Quote Share this post Link to post Share on other sites
biggrim 0 Posted March 15, 2006 Wales, is your G standard or chipped 'n' pullied? Would a smaller pulley make it rev higher than a std pulley? Min is c'n'p'd and 80mph = 3k on the revs Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 15, 2006 That's the difficulty, I've just bought the car so don't know the exact history of what's been done, i'm asking what possibly could have been done to the car to make it rev lower :confused: It has a ported head and chip to suit from jabba :roll: ..but i think the charger is standard My last g60's sat at around 3k-3.5k at 80mph. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted March 15, 2006 The pulley on the charger shouldn't make any difference. Looks like your 5th has been swapped for something different ;) Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 15, 2006 Looks like your 5th has been swapped for something different That's what i'm thinking, 1st 2nd 3rd and 4th all feel normal, but 5th is deffinately different . Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted March 15, 2006 Strange... If I had the gearbox apart then I'd have changed 1st and 2nd for VR parts. Although somebody once told me that you can change 5th without dropping the box so it might be an easy job. Can anybody confirm this ? Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 15, 2006 I'd really like to find out exactly what's been done because in fairness...it's f'kin great! lol ..cruising at 2.5k at 80mph is surly better for the engine. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted March 15, 2006 this doesnt have too much relevance but my g seems to sit better and be quieter at 100 than 80- Quote Share this post Link to post Share on other sites
