gradeAfailure 0 Posted June 1, 2006 Well, seeing as I was getting p***ed off at looking at a crumpled front wing every day, I thought I'd have a crack at knocking it back into some sort of shape, filling the dents, priming and spraying it. To all the bodyshop experts out there - yes, it's going to be a poor repair compared to what a pro bodyshop would do, but my plan is to actually get a replacement undamaged or new wing on it before E38 show anyway, so I don't really care if it looks a bit poo, I wanted to have a go and see how badly I could do! :lol: First pic is the original damage, second pic is partway through the sanding to get back to bare metal, and third pic is after the first skim of filler. Have discovered this stuff called Fadeaway, which looks like it could really help me out, but there's no UK distributor... Hmmm, time to phone the European distributor in Holland then... ;) Quote Share this post Link to post Share on other sites
corradophil 3 Posted June 1, 2006 Looks like a good job so far. Make sure you rub it down with a hard block. As soon as you see an island of metal start to appear in the filler stop and give it a gentle tap with a hammer, then continue rubbing untill you get the shape right. The metal high spot is far harder than the filler, so it needs to be knocked in, if you keep sanding you will never lose the high spot. Get the shape right, ignore low areas from trapped air in the filler, you can always fill them with the next wipe of filler. Give it a good blow off between applying filler to ensure all dust is removed. You should be able to get that ready to prime in 2 or 3 wipes of filler. Make sure you run your hand over the repair to feel for any highs or lows. To blend the edge of the lacquer we always used to use thinners (2 pack when using 2 pack paint). Just mist it around the edge. It will come back to a good finish once flatted and polished. Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 1, 2006 mate take it to a bodyshop if your happy with the prepping and tell them to blend it in,, it may only cost something like £20 and it will be perfect, unless u got an awkward colour, worth a try Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 Cheers Phil - yeah, I'm washing it off, drying it and tacking it off between skims of filler - and will do the same when I start priming and basecoating... Can't mix thinners with lacquer as I'm using aerosols for the time being...! Like I said, this is just temporary til I get a replacement wing, as the arch edge is too far pushed in to be able to resurrect the correct shape of the arch so that I'd be 100% happy... Anyone know if you can still get new wings from the stealers? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 Right, updated pics...! First one is after sanding down the first skim of filler, second one is after sanding the second skim of filler, and the third is the rust around the side repeater being taken care of before the third skim of filler gets applied... :) Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted June 1, 2006 Nice reflection of Ruby watching you work. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 :lol: yeah, she looked a bit worried when the 40grit came out but I assured her it wasn't for her! Decided against a third skim of filler as time is marching on - there's still a couple of low spots but like I said, this isn't aiming to be a perfect job by any means! First coat of primer... Quote Share this post Link to post Share on other sites
Phil K 0 Posted June 1, 2006 Top work chap - have you got time off work? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 heheh, yeah, took the afternoon off as I basically had no work to do...! not a good situation when i need the money from overtime, but there you go... just about to go and remove the overspray and put on another coat of primer in a min methinks... Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 Right, here's where it stops tonight - three coats of primer. Gonna sand it down tomorrow and do the basecoat, then do the clearcoat on Sat morning. Have decided to clearcoat the entire panel just for the sake of an even finish... Bit dusty and dirty, with some overspray still to remove, but looking better than it was! Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted June 1, 2006 Sweet, good on you having ago. It looks like your doing okay. Wouldnt it be a good idea to take the front bumper and trim off though? Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted June 1, 2006 Looking good. Dem wheels need a clean :) Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 Wouldnt it be a good idea to take the front bumper and trim off though? Probably - and if I was doing it properly I would have! This is just a temporary stopgap really, so as long as it looks better than it did before I started then I'm happy... :) Dem wheels need a clean All in good time... ;) Quote Share this post Link to post Share on other sites
KADVR6 0 Posted June 1, 2006 i would take your time dave, as my mate needed a new wing after he's front wheel came off?? even with a mates 25% VW discount, he payed £255 for a new wing :shock: Quote Share this post Link to post Share on other sites
2cc 0 Posted June 1, 2006 Good work there Dave. Be interested to see how the colour comes out, see you Sunday at Stonor I expect Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 1, 2006 Indeed, I shall be there - I'm interested to see how it comes out too...! Quote Share this post Link to post Share on other sites
Jim 2 Posted June 2, 2006 Nice one Dave.. looks like its coming along great. Suspect I will also see you / the car on Sunday at Stonor :) Quote Share this post Link to post Share on other sites
PhillT 0 Posted June 2, 2006 8) looking good, you going to stoner park? planning on going if you want to meet up there for that chat? :wink: I've got a smaller version of your dent in the exact same spot I'll be tackling once I've finished replacing the battery tray Quote Share this post Link to post Share on other sites
Trig 0 Posted June 2, 2006 Looks like a good job mate, wish I knew how to do that to my door! Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 2, 2006 I'll be honest mate, I don't really know what I'm doing but seeing as the wing's fubar'd anyway i thought why not...! Quote Share this post Link to post Share on other sites
dinkus 10 Posted June 5, 2006 I'm sure you've watched more than enough Overhaulin' by now to know what you're doing :lol: Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 5, 2006 you may laugh, but if i didn't spend all my time watching american hotrod/overhaulin/rags to riches/etc, then i wouldn't have even considered having a go at it! it's all your fault... ;) Quote Share this post Link to post Share on other sites
NickVR6 0 Posted June 5, 2006 nice one Dave, its looking great. ive seen your spray can work first hand and i know this is going to look great! and dont forget, the final finish is all in the wrist Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 6, 2006 so have u done it yet or still on the forum talking abt how your gonna do it Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted June 6, 2006 heheh, had a bit of a busy weekend, so it's still in primer - but i did actually manage to locate a late-spec aqua blue passenger wing from a breakers anyway so now i don't need to finish it off! though i think i will, just for the practice... sometime this week, if i get time... :) Quote Share this post Link to post Share on other sites
