s.g 0 Posted August 9, 2006 lookin good there richard , keep up the good work Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted August 9, 2006 nice job there! Quote Share this post Link to post Share on other sites
Henny 0 Posted August 9, 2006 woah... why am I getting seriously tempted to make J-DUB 4x4 with a G60diesel engine?!? ;) :lol: Good work there fella... can't wait to see the completed work... 8) Quote Share this post Link to post Share on other sites
rmn 0 Posted August 9, 2006 Henny, you know it makes sense! :lol: Quote Share this post Link to post Share on other sites
Henny 0 Posted August 9, 2006 *goes off to look at the £500 golf syncro he spotted for sale the other day...* Quote Share this post Link to post Share on other sites
rmn 0 Posted August 9, 2006 :lol: you dont actually need the floor, you can do it without the floor, its the rear beam you need and they are not hard to get, cleck out Coxy's thread, he has some savage work done on his one. Done away with the need to do what i have done with the boot floor J Dub need to come out to play again! so make it better and 4 wheel drive is better! Diesel is cheaper so 4X4 diesel makes sense! in the immortal words of Starsky and Hutch "Do it!" Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 9, 2006 Someone's been busy! Excellent work! 4x4 Corrados will out number FWD ones soon if this trend keeps up :-) Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted August 9, 2006 rich, just noted all the scratch marks on the towers lol Tell tale signs of some serious wrestling to fit that floor :lol: Its a bloody nightmare isnt it! Quote Share this post Link to post Share on other sites
rmn 0 Posted August 10, 2006 CoxyLaad, That would be correct! Colourful language makes it fit easier i belive :lol: Got some more pics now, its got the bottom of the boot floor all stone guarded and the welds all covered up too Quote Share this post Link to post Share on other sites
Bobby 0 Posted August 10, 2006 nice work, neat job so far mate Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 10, 2006 Once all the underseal is on, you're hard pressed to tell! Good stuff. Quote Share this post Link to post Share on other sites
gsbellew 0 Posted August 10, 2006 You're making great progress Richard, thought you were mad when you were running through your schedule for getting things done last night, but by the looks of things you are on track to get it sorted sooner rather then later. Keep it up 8) Quote Share this post Link to post Share on other sites
quicky1980 0 Posted August 12, 2006 loving this project, keep us posted. Might even folow suit in the future Quote Share this post Link to post Share on other sites
rmn 0 Posted August 14, 2006 Right a bit of an update, been trying to sort out my front and rear suspension, not the shocks and springs but the hardware fo it. I have decided to use mk4 R32 front wishbones as they are forged so no need for some seam welding on 13 year old ones, they fit into the vr fornt subframe quite easily with only the sightest modding to them. these will mount up to mk3 vr front hubs on the rear i will be doing the haldex mounting bracketry myself, after speaking to several people who have dont it themselves it makes sense as i have all the templates i need (a rolled ralye shell to trial fit stuff to before going ont the corrado :lol: ) the last issue i had was with the rear track, this i think i have figured out(feel free to correct me lads if i am way off) there are 2 type's of syncro rear beams a plus and a non plus type, they are basicly the same but have different mounts and hangers onto them bolt the rear wishbones, these came in several types. the non plus ones came with a 65mm ish baring and then a plus type with a 73mm ish baring(exact numbers not to hand but about those numbers) these were all on the 4 cylinder cars and made the track at the back 1430mm the vr6 syncro for what i can figure out had a 1439mm rear track the same as that of the passat g60 syncro, the extra 9mm appears to be made up in the actual hub/baring area. so what i have is a full 1430mm rear beam setup, so i think i will stick with this, any input fro coxy or phat would be appreciated now :lol: Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted August 15, 2006 vr6 syncro rear wishbones are wider than the standard items. Quote Share this post Link to post Share on other sites
mattosmond 0 Posted September 1, 2006 this looks ace, cannot wait to see this bad boy, i used to have a mk2 syncro bloody good fun!!! 4 wheel powerslides around roundabouts in the wet Quote Share this post Link to post Share on other sites
rmn 0 Posted September 1, 2006 Thanks, i am doing little bits on it, time is the most difficult thing to get hold of lol and those goddam VR6 syncro rear arms too i will post some pics up after the weekend, i have some small progress Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted September 1, 2006 gonna be awesome..... 8) Quote Share this post Link to post Share on other sites
rmn 0 Posted September 4, 2006 bit of an update, but no pics as i forgot to charge my camera this weeekend i made the jig up to maintain the location for the diff, i bolted a syncro diff onto the axle i am using, then made a bracket to sit onto the input shaft and bolted it to it this plate was then welded to a bar which in turn was welded to the beam i then cross braced it off the beam then once this was done i could remove the syncro diff and then remove the supporting bracketry for it the part i made up will maintain the location of the diff for trueness and it just so happens that the haldex diff will bolt to it and then i can make the bracketry up for it. I intend to make it copying the style of this one ( i pinched the image off vortex :lol: ) http://img92.imageshack.us/my.php?image=desktop1081ao.jpg Quote Share this post Link to post Share on other sites
rmn 0 Posted September 10, 2006 well i thought i would post up some pics of the work from the last week or two first thing i did was to get out the axle and strip it, take off the ARB and the brake lines and all that stuf and then i bolted a syncro diff to it here is a pic of the axle with the diff removed and everything else still on it here it is in the pic, excuse the focus i made a cock of the pic and here is a pic of the Haldex rear diff you will notice that the bot holes are in a simular place but slightly different the physical sizes are simular, but the bracketry will all have to be made up here are the 2 diffs beside eachother so the shape of the haldex one(closest to the camera) is totally different so with the Axle stripped and the diff bolted to it with its 4 bolts i made a bracket to locate it what i did was get some heavy angle and cut it to the length between the 2 anti roll bar mounts once cut i then lined it up and drilled two holes in itlining it up with the input shaft bolts for the diff The haldex and syncro diffs have the exact same bolt pattern i then built it up with specially made washers till the diff and the bracket were touchingand tightened it home so at this stage the diff is held by the original brackets and the new bracket is bolted to it and touching the beam i then welded it on to the beam then removed the diff and will remove the original bracketry this week and start fabricating the new brackets here is the bracket that we made up, it looks simple but a lot of time went into making it work 100% and and 1 more on another note for comparison purposes here is a pic of the 2 fuel tanks, the syncro one is smaller and higher and in the fron of the pic and there is my trial fit bed to use for measuring and calculating if things will work Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 10, 2006 LOL! - loving the trial fit bed... Nice parking :lol: Quote Share this post Link to post Share on other sites
