GVK 0 Posted November 26, 2006 Went to Stealth a couple of Saturdays ago with my mk2 VR6 Spec is 160,000 mile 0BDII 2.8 with new chains/guides/tensioners, Dougherty 268 cams, 6 branch eBay manifold and Carbonio CIA,Jetex 2.5" system. Very pleased with results considering vag-com logged faults with lambda probe and MAF... 209bhp at 6150 and 188 lb/ft @ 5243rpm! 171bhp at the wheels Plot overlaid with the last engine ( two week wonder 2035cc 16v on Newman 272s....) http://i74.photobucket.com/albums/i270/GVK34/vr6vs16vpower.jpg Comical torque difference..... http://i74.photobucket.com/albums/i270/GVK34/vr6vs16vtorque.jpg Vid of first run, note -wheel spin , first time Vince has had to spray glue on the rollers for my car..lol! http://s74.photobucket.com/albums/i270/ ... ower01.flv Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted November 26, 2006 need to get Will to put up his 2.9 OBDII plot, the torque is insane, nearly as good as a 3.2! Quote Share this post Link to post Share on other sites
GVK 0 Posted November 26, 2006 Yeh, got a text off him when I was on holiday 196 bhp : 215 lb/ft wasn't it? Quote Share this post Link to post Share on other sites
Trig 0 Posted November 27, 2006 Yeh, got a text off him when I was on holiday 196 bhp : 215 lb/ft wasn't it? Is that a standard 2.9 other than the OBD2? Quote Share this post Link to post Share on other sites
GVK 0 Posted November 27, 2006 Think so, it's got a Jetex 2.5" system same as mine with no centre silencer and either a BMC CDA or Ram air 'cossie' style filter. Standard cams as far as I'm aware. Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted November 27, 2006 GVK another Worcester raddo??? Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted November 27, 2006 Ok maybe not, just looked at the url in your sig. Nice track Golf though 8) Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 27, 2006 ...188 lb/ft @ 5243rpm! 171bhp at the wheels I think I've just worked out how to buy a decent Corrado VR6... don't ...buy an 8v C and a Passat instead :wink: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 27, 2006 Yeh, got a text off him when I was on holiday 196 bhp : 215 lb/ft wasn't it? Seems unusually high for nothing more than a 2.5" exhaust and air filter. In fact I have never seen a normally aspirated VR6 with more torque than power, or a 24v come to think of it! Sure he hasn't got a stroker crank in there? Quote Share this post Link to post Share on other sites
double-6s 0 Posted November 27, 2006 Do schrik'd 12v's produce more power than torque still Kev? I'll be able to tell you tomorrow actually - on the RR at last! :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 27, 2006 Yeah that's true, where the torque is in the rev range wasn't mentioned, but that is schrick like behaviour to a degree, but normally you're talking 205lb/ft, playing 190hp for example......and only around 3000rpm. The the torque falls away rapidly past 5000. Quote Share this post Link to post Share on other sites
ziderapple 0 Posted November 27, 2006 i'm looking forward to seeing your results double-6s as im having a schrick mani on the group buy and am thinking of going for cams aswell - what are you expecting? Quote Share this post Link to post Share on other sites
double-6s 0 Posted November 27, 2006 I'm expecting to break down a couple of times on the way there probably mate! :) Seriously I haven't got a clue what to expect. I've got a big bore throttle body going on as well so will be interesting to see what it produces all together. In my experience though........ Don't hold your breath. Plenty of time for things to go wrong :) Quote Share this post Link to post Share on other sites
VR6Will 0 Posted November 27, 2006 Hello everyone, yes was at Steath weekend before last, i got 196bhp and 214lbft mods are 2.9 ABV engine converted to OBD2, BMC CDA filter, 2.5" Jetex centre box removed and no cat, :D Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted November 27, 2006 I used to have a Shrick'd and remapped (plus t/b, panel filter, Skorpion exhaust) VR6. As originally rolling roaded by AMD* it was making 229lbft and 206bhp. Six years later it was making 'just' 207 lbft and 215bhp. *in 1998 - having just fitted the parts above. Quote Share this post Link to post Share on other sites
GVK 0 Posted November 27, 2006 Odd shaped torque graph - or is mine odd shaped? Quote Share this post Link to post Share on other sites
VR6Will 0 Posted November 27, 2006 look similar dont they, just yours is higher up the rev range because of your cams?? Quote Share this post Link to post Share on other sites
matt_corradovr6 0 Posted November 28, 2006 I tried to email dr camshafts in the us re some cams for my vr and my mates 16v twin 45'd rocco. but the email on their site bounced back. anyone got the right email for them?? also whats obd and abv mean re the vr6?? Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted November 28, 2006 For Weird, try this... Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted November 28, 2006 VR6Will, This is without a remap right ? Quote Share this post Link to post Share on other sites
eatthis 0 Posted November 28, 2006 what were the wheel figures?? Quote Share this post Link to post Share on other sites
GVK 0 Posted November 28, 2006 Mine was 171 at the wheels Quote Share this post Link to post Share on other sites
GVK 0 Posted November 28, 2006 ABV is the engine code for a 2.9 VR6 engine OBD = on board diagnostics 0BD1 - earlier pre 95-96ish VR6 , runs an idle speed valve as an easy thing to identify under the bonnet.. OBD II later 2.8 VR6 easily identified by no ISV and a stepper motor throttle body. OBD II has a faster more efficient ECU and even though it's rated the same power from VAG the OBD II cars tend to give more power, sometimes more than a 2.9. I'm sure there's loads of other bits of info on this too :-P Quote Share this post Link to post Share on other sites
VR6Will 0 Posted November 29, 2006 VR6Will, This is without a remap right ? correct, not been mapped yet, Quote Share this post Link to post Share on other sites
matt_corradovr6 0 Posted November 29, 2006 thanks Quote Share this post Link to post Share on other sites
