junkie 0 Posted July 26, 2007 Ok so i have been on this forum for a couple of years and never actually got round to take the time to start my own thread on my wonderful Corrado. These are the pictures i have so far and how the car stands at the moment. Picture 066.jpg[/attachment:ae5d0] Spec time 1991 Corrado "G60" Engine My "G60" IHI VF22 1.5 bar/Haltech passat climatronic wiring diags.pdfSimon_Corado dyno.jpg[/attachment:ae5d0] 20vt standard engine IHI VF22 1.4 bar/Haltech, going against everything i have ever said but i may be doing this in the future, i need more power. climatronic wiring-Golf from May 01.pdfElton_Rallye dyno.jpg[/attachment:ae5d0] The 2 overlaid for a direct comparison 2.8l 24v Climatronic system.pdfRallye_&_Corrado dyno.jpg[/attachment:ae5d0] 1900 (1870) 83mm bore JE 83mm forged pistons 144mm 16v rods Lightened & balanced crank, rods, flywheel Big Valve Head ported & polished Ported throttle body Matched exhaust port Custom 2.5" Blueflame downpipe Custom 2.75" Blueflame exhaust Piper 285 camshaft Vernier Pulley IHI VF22 Turbo + ported wastegate Bailey dual piston dump valve Jabbasport Cast Manifold Jabbasport baffled sump 440cc injectors 16v external fuel pump Aquamist Water Injection Pro Alloy FMIC Mocal 13 row oil cooler MK3 Golf Alternator + various pulley's Haltech E6M stand alone engine management + in car boost adjustment and trim Custom Jabbasport map Wasted spark ignition Polo crank position trigger wheel x3 Vibratechnics competition engine mounts Low temp thermostat Slimline radiator fan Silicone & alloy boost pipes Jabba custom heat shield JR cone air filter Trimsport dipstick Transmission Standard :( Chassis FK Konigsport Silverline coilovers 50mm drop Neuspeed 25mm F&R anti roll bars Polybushed F&R Brembo Seat Ibiza 305mm Cupra brake kit Braided brake lines Ferodo DS2500 front pads (to be fitted) Replaced Wishbones, track rods, top mounts Compomotive CXR 17 x 7.5 wheels x2 Toyo 215 x 40 x 17 tyres (very good) x2 Falken 215 x 40 x 17 tyres (utter poop) Interior Recaro, electric & heated black leather MOMO Monte Carlo 320mm steering wheel + MOMO boss MOMO Race half leather gear knob Wolfsburg car mat set A pillar gauge pod Mocal Boost Gauge Audi Early 80 VDO gauges. Audioscape door pods ICE Clifford Concept 500 Nakamichi CD400 Phoenix Gold Line Driver Phoenix Gold EQ215x Phoenix Gold 1000/2 Phoenix Gold 1200/1 + LPL control Focal K1 2 way components Jl Audio 12" sub/box 0 gauge cabling Phoenix Gold RCA/Phono cables Phoenix Gold 200amp breaker False floor/custom not in your face build 18 sheets Extreme Dynamat 1 Focal Plainchant kit Exterior Sleeper style :lol: Memory has gone blank so thats it for now. Right then i have just quickly converted the Nm figure to torque, to show the actual torque figures as in my eyes it is a good torque curve but the graph makes it look short and peaky when its down to the torque peaking so high in the 1st place. As can be seen i have a minimum of 260lb/ft between 3000rpm > 6000rpm, now at 2500rpm its 166lb/ft which is the same as a G Lader peak torque and quite close to a pullied, chipped and flowed charger, and right on the limiter its still doing more than the previously mentioned set up. For the torque to double in 1000rpm between 2500rpm > 3500rpm as it comes on boost you can imagine the problems i have with traction in 1st and 2nd :) hence why i need longer gearing and quite possibly i may be trying the CTN as a cheap alternative to the VR6 set up, i think i have made my mind up. RPM = lb/ft 2500 = 166 3000 = 258 3500 = 317 4000 = 332 4500 = 339 5000 = 317 5500 = 291 6000 = 258 6500 = 239 On the 2 seperate graphs with red lines they are the same dyno run from my engine, just shows you how different they can look to the eye as in the 2nd graph it looks like it has more torque for longer compared to the 1st graph even though they are identical runs. So again Green line is torque, Black line is BHP So opinions please? Quote Share this post Link to post Share on other sites
g60greeny 0 Posted July 26, 2007 at last we get to see the beast :lol: Quote Share this post Link to post Share on other sites
Sonicriot13 0 Posted July 26, 2007 That is looking sweet. The thing that caught my eye externally are your calipers. They seem to be one of those nice details that just set the car off. :thumbleft: Quote Share this post Link to post Share on other sites
Yandards 0 Posted July 26, 2007 Who took the rolling shots? Very good indeed. Quote Share this post Link to post Share on other sites
junkie 0 Posted July 26, 2007 Apart from the very top pic all the rest were taken at the Golf+ photoshoot, the top 2 moving shots i was going a full half a mile an hour :lol: so anymore pics i get up will not be of the same quality. Just been looking at them and a few things have changed nothing too major though. so will update when i can find my damn cam lead to PC. Quote Share this post Link to post Share on other sites
waynos 0 Posted July 26, 2007 very nice! second shot kinda looks like your drifting Quote Share this post Link to post Share on other sites
joneinar 0 Posted July 26, 2007 very nice, I have that issue of Golf+ with you`r corrado in it.... can`t throw away any vw mag 8) Quote Share this post Link to post Share on other sites
junkie 0 Posted July 26, 2007 very nice, I have that issue of Golf+ with you`r corrado in it.... can`t throw away any vw mag 8) Im not the only sad 1 then :lol: currently up to 5 years Golf+ and PVW.Dont know if you read any older 1's recently but i still find them a better read years on compared to the shite they are now. Quote Share this post Link to post Share on other sites
joneinar 0 Posted July 26, 2007 no I don`t have any older than that.. 3 years aprox... now I almost only buy pvw, it`s hard to get hold of golf+ where I live (norway)... seems like they suddenly would`t sell it any more here.... Quote Share this post Link to post Share on other sites
junkie 0 Posted July 27, 2007 Who took the rolling shots? Very good indeed. Its just sprung to me and it was Michael Whitestone i think he is called and works for various mags freelance, also does alot for Mini world. Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted July 27, 2007 your definatly not the only one i have about 4-5 years worth of pvw and the golf mags in my room collecting dust, nice car by the way :D Quote Share this post Link to post Share on other sites
_leon_ 0 Posted August 8, 2007 like this car a lot... dying to see a vid or be a passenger and see what it does Quote Share this post Link to post Share on other sites
junkie 0 Posted August 8, 2007 like this car a lot... dying to see a vid or be a passenger and see what it does Well if i had a cam to do the vid i would do, and you have dipped out for not just a ride but a drive as your not doing ED38 now, how comes??? Quote Share this post Link to post Share on other sites
_leon_ 0 Posted August 8, 2007 well moving to edinburgh within a week, off to moldova for a quick trip next friday, start the new job 2 days once i'm back, skint and no-one from here is going to my knowledge. may change as i want to meet up with folks (like yourself) - so just staying flexible for the moment. being in a high powered corrado will kill me until i do more to mine though lol will try mate. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 8, 2007 I hardley post on here any more but i have to say this is one of my favorite raddos 8) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted August 9, 2007 Sweet lord that thing is clean :-o Deep turqouise paint + gunmetal wheels + big calipers = woot :shock: # good work buddy, what colour is that? do you know the veedub code for it too? Quote Share this post Link to post Share on other sites
junkie 0 Posted August 9, 2007 I wish it still looked like that, 2 years ago now that was, worked out i need to spend around 40+ hours minimum to get it looking the same. Its not clear in my service book but is either LC6V/LC6U but the colour is called pearlescent green. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted August 9, 2007 I wish it still looked like that, 2 years ago now that was, worked out i need to spend around 40+ hours minimum to get it looking the same. Its not clear in my service book but is either LC6V/LC6U but the colour is called pearlescent green. 40 hours of what - cleaning? Quote Share this post Link to post Share on other sites
junkie 0 Posted August 9, 2007 :lol: :lol: yep thats right..... Quote Share this post Link to post Share on other sites
_leon_ 0 Posted August 9, 2007 cant be serious! how did you calculate that? Quote Share this post Link to post Share on other sites
junkie 0 Posted August 9, 2007 Its been neglected for ages and ages and im wanting to get everywhere detailed, maybe not perfectly but to the standard my car will allow without been in the body shop and i work slow :lol: Quote Share this post Link to post Share on other sites
_leon_ 0 Posted August 9, 2007 whats the general paint condition like on it? mines not great - but then i'm in no rush - it'll get stone chipped etc quickly anyway due to the way/places i drive Quote Share this post Link to post Share on other sites
junkie 0 Posted August 9, 2007 Personally i think its not great but i see it everyday, the usual 16 year old condition. But i have been told quite a few times that considering its 16 years old its in good condition. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted August 12, 2007 how did you attach your radiator fan to the radiator? Quote Share this post Link to post Share on other sites
junkie 0 Posted August 12, 2007 without looking i think its kind of pushed in some how, but however its done it is a common way to do it, will take a look when i get chance, its been put away for the week now. _leon_ you def decided on 1.8T now :) Quote Share this post Link to post Share on other sites
