Jim 2 Posted November 22, 2007 I've never actually heard of the chains just going on the VR, let alone one with that sort of mileage. Will be interested to see what has happened! Its not possible that the tapping was due to oil starvation, and subsequently the engine has siezed or something dreadful like that is it? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted November 22, 2007 The starter motor may be turning but if it has not engaged the starter ring, the engine isnt turning. Take out a plug and check that the crankshaft and pistons are rotating. Only then can you be absolutely sure that the chains have broken. But, tbh, if it stopped dead it sounds bad Best wishes RB Quote Share this post Link to post Share on other sites
fla 9 Posted November 22, 2007 Jim - could be, but when the temp got up to about 70 the noise used to disappear. Plus there were no abnormally high temps, which would indicate lack of oil. RB - will have a look tomorrow, thanks for that. If it is the worst case scenario i may be on the lookout for a new block. Does anyone know of one in good nick and lowish mileage? Quote Share this post Link to post Share on other sites
double-6s 0 Posted November 22, 2007 Bad luck mate :( As for the insurance thing? Not a chance i'm afraid. I hate to be the bearer of bad news :( Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted November 22, 2007 Pm you back about engines Quote Share this post Link to post Share on other sites
zak 0 Posted November 22, 2007 is it not possible to turn the engine over by hand using a spanner? then that would eliminate the starter motor not meshing with the flywheel. I don't think ive ever heard of anyones chains snapping so wouldnt fear the worst just yet. Let me know if you need a hand. Quote Share this post Link to post Share on other sites
chriscorrado 0 Posted November 22, 2007 hydraulick tappets can become noisy with age - its not a disaster but you may need a head rebuild at some point - if it drives ok leave Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 23, 2007 I've heard of a couple of cases of chain snapping, but it is rare. How to tell: put it in gear and roll the car forward/back - if the cams don't move then chains are knacked, because you're *definitely* turning the crank when you do that. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted November 23, 2007 Only thing is, it's an auto gearbox, so it's a spanner job. Best wishes RB Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 23, 2007 Ah, didn't spot that.. Quote Share this post Link to post Share on other sites
fla 9 Posted November 23, 2007 Zak - thanks for the offer, might need to take you up on that! RB & Mat useful pointers thanks. Just spoken with another mechanic and he needs to see teh car first before diagnosing the problem. says it may just be the starter coupler, as we need to check if the cranks are turning as well (same as RB advised) If the chains are snapped then its far easier to just pull the engine out and put a new one in. I'm feeling somewhat reassured now as i was seriously contemplating breaking it, thankfully that wont need to be an option (hopefully) Quote Share this post Link to post Share on other sites
Toad 0 Posted November 23, 2007 fla said: If the chains are snapped then its far easier to just pull the engine out and put a new one in. I'm feeling somewhat reassured now as i was seriously contemplating breaking it, thankfully that wont need to be an option (hopefully) Don't throw the baby out with the bath water just yet.... You've got a 60k mile bottom end, which is a great base and shouldn't have suffered much damage (posibly need a piston or two), get the valves replaced or buy a second hand head and get it fully rebuilt and wack it on probably cost around £500 for the head/refurb. You'd have new chains and tensioners etc and would never have to worry about the engine internals again... compare that to buying a fairly unknown second hand engine which could potentially need all the same work doing in the future...... See what turns out with the mechanic. Quote Share this post Link to post Share on other sites
fla 9 Posted November 23, 2007 Toad - interesting points. What could i expect to pay for that little lot ie how much are pistons etc? I know chains are faily cheap (£20 for a trade buyer) plus tensioners which are also not too much i believe (can anyone elaborate?) What pointers should i give to the mechanic? Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted November 23, 2007 Ive got my old block, pistons, rods, crank in my garage. You can have any of it that you need for free mate. One of the rods spun a bearing, so is of no use, but the pistons are fine. Let me know, or find out if its better to buy new ones. Quote Share this post Link to post Share on other sites
fla 9 Posted November 23, 2007 Stan, many thanks for that, its very kind of you. Just had a chat with Jimmi, who suspects its prob NOT the chains and its best to turn the engine manually first and see. Its more likely somehing to do with the starter motor and the tapping may just have been a stuck tappet. I hope he's right, but i'll turn it over manually this weekend and see. What size socket is required, 26 or 28mm i guess? If its the chains he says it may be better to get a 2.8 and rebore this to 2.9 so i can use my old pistons with new liners. Anyway if anyone has any other ideas or suggestioins i'd welcome them. Lest i repeat myself in this thread, all comments and support are greatly appreciated. Its bizarre feeling frustrated over a car - then again these are our Ferraris and Lambos, the attainable pride & joys. Do pm me if you ahve any further advice or suggestion. Quote Share this post Link to post Share on other sites
double-6s 0 Posted November 23, 2007 Stan 24v said: Ive got my old block, pistons, rods, crank in my garage. You can have any of it that you need for free mate. One of the rods spun a bearing, so is of no use, but the pistons are fine. Let me know, or find out if its better to buy new ones. And in theory i still have a partly shagged vr bottom end and a reasonably good head at Stealth racing still - you're also welcome to any of that for free mate. I reckon between me and Stanley that should pretty much be the whole shebang. You'd have to ask Vince though - cos I can't be a*sed! Tis free though! :) Quote Share this post Link to post Share on other sites
fla 9 Posted November 24, 2007 double 6s - cheers too. I picked my car up this evening so i'll be having a look at it tomorrow to see what exactly the problem is. Then the fun will start!! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 26, 2007 I've heard of shagged fluid flywheels stopping the engine turning. 27mm is the socket you'll need to turn the motor by hand. Take the plugs out first though or you'll struggle! Quote Share this post Link to post Share on other sites
fla 9 Posted November 26, 2007 Didnt get time to havea look this weekend so next weekend it is. Zak, thanks for the text. Quote Share this post Link to post Share on other sites
fla 9 Posted December 2, 2007 How do you get access to that 27mm head to turn the engine over - it seems to be just too tight for a socket or a spanner in there? Also, to remove the inlet manifold, is it better to remove the throttle body from the manifold or the air inlet line? I've just about managed to open the manifold bolts without removing the slam panel or fans, but putting them back may be a tad harder. Suggestions? I presume all gaskets should be replaced too? Quote Share this post Link to post Share on other sites
fla 9 Posted December 2, 2007 OK, i removed the manifold and rocker cover, a bit of a pain getting all those bolts off. Now the chains are OK, thankfully, but this makes it even more confusing. I am not sure what the tapping noise was - it appeared to come from the left hand of the rocker cover, which had the vapour valve fitted to it. The cams look fine and i'll try and post some pics of it soon. As mentioned in my previous post i dont know how to turn the engine by hand as there's no space. Now i dont know what to look for or what to try. I guess the starter clutch is toast, so that will be replaced soon (is there any difference between a manual and auto starter?) But whilst i feel reassureed that the chains are OK, i'm kind of at a standstill as to what to do now. Thanks Quote Share this post Link to post Share on other sites
fla 9 Posted December 3, 2007 any ideas guys? Quote Share this post Link to post Share on other sites
steve @ 0 Posted December 3, 2007 Get some pics up of the chains, top pad, cams etc. Quote Share this post Link to post Share on other sites
zak 0 Posted December 3, 2007 i just had a look in my engine bay and see what you mean about space, try access from underneath after jacking the car? Quote Share this post Link to post Share on other sites
fla 9 Posted December 4, 2007 Will post some pics tonight hopefully. Quote Share this post Link to post Share on other sites
