Mawrick
Just thought I'd whore the rado in here.....:)
A small update:
installed the DubNutz stainless steel fuel lines and Gruvenparts fuelline brackets:
And some pics of the front brake calipers sitting on car:
A small update - before I get around to actually starting it up :)
refurbished alternator - powdercoated:
DSC_5093.jpg?t=1273856075
DSC_5092.jpg?t=1273856076
And FINALY "lift off" - well not quite, but atleast I got to start it up today - so seem to be working alright after the rebuild, so an important milestone reached :)
Small update - not so good though.
Have gotten the car in for a inspection before getting it registered - all went good - however there are wrong data about the car in the Swedish documents - turns out it was registered for only 2 people there, and the weights are wrong.
So the pr*** at the gov inspection center won't register it for 4 people - and the VW importer here in Norway don't seem to be able to give me a confirmation of weight etc. TÜV could give me a certificate for the technical data of the car - but that wasn't sufficient for the gov goones.
Guess it won't be registered this year afterall - gives me time to think about braking it......doubt it, but I'm considering it :)
Finally something positive today - spoke again with the gov guys, and they said they could weigh the car for me - and I just should make sure to toss out spare wheel +++ that I don't need if it was close to the limit.
Was up just now on the weight to check and it seem to come in right around 1275Kg - max limit was 1280 to get 4 seats :)
Hopefully they will be able to work that out tomorrow - so I can register it after the w/e :)
ah man after all your effort i hope you get it sorted.
i don't get the weight issue tho, four seaters have a limited weight band in Norway :scratch:
yea - well you can say they have a "standard" for passanger weight which is 75kg per person - meaning that for 4 persons it must have 300 kg available when the car is weight when empty and up to the maximum allowed weight.
The Corrado has maximum allowed weight of 1580Kg - meaning it must weigh 1280kg max - and it's stated from VW 1285 - and the swedish documents stated around 1400kg. When I checked tonight with the spare tire out it came in roughly at 1275 with full tank of gas, meaning that it's within the limit :)
Hopefully it will work alright tomorrow....:)
FINALLY!
Was able to get it worked out today - so only thing missing is paying the taxes and getting it's new wings................ehh...plates (thinking monday).....:)
Finally got all things sorted - it's now on Norwegian plates - and it's a 4 person car again (not that it's much room for 4 but anyway)....:)
Value off it also raised significally today after the taxes was paid....lol....:)
Just thought I'd put in a few pics of it after the registration - better photo's to come eventually - have been to busy driving it to get time for another wash and a "photoshot" :)
YES! I know it sits to high - will also be adjusted a bit down on the height ;)
And before the trip to Germany - the Speedlines are back on - after powdercoating (done a few years ago I guess :) )
18 minutes ago, ger040 said:
great looking car and great scenery too
thnx - yea was a great drive on curvy roads fit for a Corrado 🙂 (a bit of bad tarmac - but hey that's the usual stuff up here 🙂 )
