big ben 10 Posted August 11, 2009 as title, how can i remove the side bump moulding strips easily?? do i need to heat them with something?? Quote Share this post Link to post Share on other sites
Jay23Sx 0 Posted August 11, 2009 Yes, warming helps apparently, but not as hot as something like a hot air gun. When I was researching this for doing my paintwork several people suggested using a hair dryer. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted August 11, 2009 i dont think there is an 'easy' way.......its a slow & very gentle route needed it was very tense in my experience as im sure non of us want to harm paintwork lol i used a heat gun, monitoring the temp constantly & worked them off very slowly & this worked great on passenger side think i got a little overzealous on drivers side tho as managed to loose a very small flake of paint :( but the doors will need addressing as the strips leave laquer lines another 4 the to do list lol Quote Share this post Link to post Share on other sites
big ben 10 Posted August 11, 2009 yeah, im thinking i will try and remove them before it goes to have some bodywork done, so they can touch up any bits that need doing at the same time... might give a hair dryer a blast Quote Share this post Link to post Share on other sites
aide 0 Posted August 11, 2009 heat gun, patience and great care are the order of the day, residual adhesive can be cleaned off fairly easy. i think there is threads discussing this before. Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 11, 2009 I used a kettle or two of boiling water :grin: Quote Share this post Link to post Share on other sites
big ben 10 Posted August 11, 2009 did boiling water work good?? couldnt find anything in search, so if someone does, post in here :shrug: Quote Share this post Link to post Share on other sites
B41LEY 0 Posted August 11, 2009 Boiling water first then t-cut and a lot of elbow grease Quote Share this post Link to post Share on other sites
big ben 10 Posted August 11, 2009 boiling water sounds the way to go to me then Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 11, 2009 beware, you may find a previous owner has had a cheapo repair done hidden by the strips :( Quote Share this post Link to post Share on other sites
big ben 10 Posted August 11, 2009 there is a cheapo repair i can see :lol: got touch up on one side, and instead of blue its purple :gag: needs sorting!! Quote Share this post Link to post Share on other sites
aide 0 Posted August 11, 2009 i used boiling water at first, problem i found was walking backwards/ forwards to the kettle all the time :D meanwhile i felt the strip was cooling which makes you paranoid about pulling at it - does work tho i got a cheapo heat gun from b&q, cost me like £10/ £15 and has been invaluable for loads of stuff Quote Share this post Link to post Share on other sites
bigrichi 0 Posted August 12, 2009 Another recommendation for boiling water and...... TAKE YOUR TIME!!!!! Quote Share this post Link to post Share on other sites
PROVR6 0 Posted August 12, 2009 I found they come off quite easily but leave behind a sticky residue. This is easier to remove if warm. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 12, 2009 I was going to remove my strips but prefer the protection of them, so colour coded them and put them back on. Any slight discrepencies in paint quality and panel gaps is very obvious with the strips removed. Looks better with them imo. Anyway, if you want to put them back or indeed stick anything to the bodywork and get it off again without wrecking the paint, then I recommend this stuff - http://www.apetape.co.uk/index.php?app= ... 859830f8jj It's the dogs. Comes off in one big strip too, so no picking little chunks off for hours like you get with ye old fashioned foam tape. Quote Share this post Link to post Share on other sites
Jay23Sx 0 Posted August 12, 2009 I was going to remove my strips but prefer the protection of them, so colour coded them and put them back on. These are the bump strips that protect other cars but not yours ? :) My doors are full of parking dents because they don't offer any protection what so ever - but they do stop me marking other peoples. Quote Share this post Link to post Share on other sites
OSV 0 Posted August 12, 2009 Car looks better with them unless its v smodded and smoothed, plus better protection and as so many have lost them its increasingly more unusual to see them on than off Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 12, 2009 I was going to remove my strips but prefer the protection of them, so colour coded them and put them back on. These are the bump strips that protect other cars but not yours ? :) My doors are full of parking dents because they don't offer any protection what so ever - but they do stop me marking other peoples. You can say that of any car. There's no guarantee where the panels will clash in carparks. You might get a Range Rover next to you, you might get a Triumph Spitfire next you, you don't know! What I actually meant was protection when opening the door in narrow garages because the doors are so feckin long.... Quote Share this post Link to post Share on other sites
Walesy 0 Posted August 13, 2009 did boiling water work good?? couldnt find anything in search, so if someone does, post in here :shrug: search.php - Just put 'remove bump strips' into the search mate I just got 4 pages :) Quote Share this post Link to post Share on other sites
