Wastegate86
Corrado weight?
was just wondering if someone give me true weights of the carrado range?
tried searching the net.....recons a g60 is around 1200kg
but iv got a plaque on my engine bay saying 1470kg :shock:
Wow - that is light! Presumably the 1.8T engine is quite a lot lighter than the old VR6 motor?
Maybe he's lost a few kg's to rust over the years lol
Wash your mouth out ! lol
Alloy brakes,KW coil overs are so much lighter then OE,I don't know the weight of a 1.8T,
Have just checked for the weight of a VR6 on about 10 different sites and they all have it at slightly different for kerb weight - the lowest was 1210kgs and the highest at nearly 1280kgs but none any heavier than that.
Some quote with half a tank of fuel and the driver?
Weighed my C the other week,
1136kg
Interesting. Our front weights are quite similar but I have about 180kg less over the rear axle. Shows that unless you take it back to bare shell there's very little weight to come off the front of the car unless you run a 0.5l engine.
I have seriously soundproofed the rear of the car,it even has two boot carpets !
I'm getting too old for a droning exhaust ! 😀
Rust is lighter than carbon fibre.
Got mine weighed today 1250kg all fluids full.
Spec that effects = leather, loads of Dynamat, r32 engine, ARB's, rear brace, coilovers, bbs ch 17x8.5, Brembo fronts.
