daves16v 1 Posted April 1, 2010 I've noticed part of the windscreen seal has an equal gap of about 5mm each end - see photo. Now I know this isn't right, no gap on my valver. I'm guessing when this strip was pressed into the gap it wasn't stretched enough or maybe it just isn't long enough, probably not the latter as it would have been pulled out to change the screen then popped back in. So can I remove it and refit properly? Thanks Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted April 1, 2010 there is four pieces all together,the one main outer trim, two sides and the top seal that you have,but like most rubber seals they shrink over time... :( leaving that gap. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 1, 2010 CorradoVR6-Turbo said: there is four pieces all together,the one main outer trim, two sides and the top seal that you have,but like most rubber seals they shrink over time... :( leaving that gap. Is it available from the dealer? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted April 1, 2010 Probably mate,but i know auto windscreen places do a seal kit which will be a fraction of dealer costs,but be warned you will have to remove the outer seal which will probably be glued in place if the screen was replaced and the top trim is slotted on to the top of the glass as is the two side sections,its not a easy job and might end up having the screen removed to do it properly,it might be best to fill it with silicone? Quote Share this post Link to post Share on other sites
STU175 0 Posted April 1, 2010 i fitted windscreens for living and i wouldnt attempt it mate youll end up with more problems then the gap youve got allready stu Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 2, 2010 stuartscales said: i fitted windscreens for living and i wouldnt attempt it mate youll end up with more problems then the gap youve got allready stu Stu, what are my options, silicone sealant or something similar? Will I get leaks if don't bother filling it? Dave Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted April 2, 2010 you will have no leaks,as these trims are just finishing trims,most you might get is whistling at speeds cos of the gap. Quote Share this post Link to post Share on other sites
Kev_VR6 0 Posted April 12, 2010 Check mine out Dave. http://the-corrado.net/.archive/forum/viewtopic.php?f=11&t=87283&start=15 I really don't wanna scare you here mate but I definitely would wanna know if there was something like this lurking on mine ever again in plenty of time. I'm sure worst case scenario your's won't be anything like as bad as mine. Mine had a new screen at some point in the past that was never properly sealed. Good job I found it when I did or it would have gone beyond repair! I hope you don't have to look at anything this depressing on your new motor. I'd defo check behind the rubber and if all seems ok then you've lost nothing just gives you the peace of mind. But if there is some rust there best to find it sooner than later. Thankfully mine's in the garage now being welded and waiting to be sprayed. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted April 13, 2010 My outer seal (the one on top that runs all the way round) has come loose. What do you guys suggest for sticking it back down? Quote Share this post Link to post Share on other sites
big ben 10 Posted April 13, 2010 i got the same problem with my valver to, at 90mph (not that i dirve that fast :wink: ) it comes out and starts vibrating the hell out of the roof, so annoying... when i finally get it back from being painted the last thing i want is that seal vibrating on the new paint Quote Share this post Link to post Share on other sites
The_Dude 0 Posted April 13, 2010 big ben said: i got the same problem with my valver to, at 90mph (not that i dirve that fast :wink: ) it comes out and starts vibrating the hell out of the roof, so annoying... when i finally get it back from being painted the last thing i want is that seal vibrating on the new paint Yeah, I'm getting tiny scratch lines appearing above it. Need to sort it before winter. Quote Share this post Link to post Share on other sites
big ben 10 Posted April 13, 2010 The_Dude said: Yeah, I'm getting tiny scratch lines appearing above it. Need to sort it before winter. annoying hey. It does polish out with a DA, but not the point, bloody thing Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 13, 2010 Kev_VR6 said: Check mine out Dave. http://the-corrado.net/.archive/forum/viewtopic.php?f=11&t=87283&start=15 I really don't wanna scare you here mate but I definitely would wanna know if there was something like this lurking on mine ever again in plenty of time. I'm sure worst case scenario your's won't be anything like as bad as mine. Mine had a new screen at some point in the past that was never properly sealed. Good job I found it when I did or it would have gone beyond repair! I hope you don't have to look at anything this depressing on your new motor. I'd defo check behind the rubber and if all seems ok then you've lost nothing just gives you the peace of mind. But if there is some rust there best to find it sooner than later. Thankfully mine's in the garage now being welded and waiting to be sprayed. Oh that's crap! Could you see any rust creeping beyond the seal inside or outside the car? I want to check without removing the screen. Quote Share this post Link to post Share on other sites
Kev_VR6 0 Posted April 13, 2010 Just a really small blister underneath the paint, just starting to show itself creeping out the top of the rubber. Thought at 1st it was just a flaw in the respray (coz it wasn't a screen out job) so we ignored it for a bit. If your car doesn't stink everytime u get in it then I'm guessing you don't have a leak. Just trial and error with the hose pipe should be enough to reveal anythin wrong. I'm sure you'll get away with just resealing though. Good luck mate let me know how u get on :wink: Quote Share this post Link to post Share on other sites
fla 9 Posted June 15, 2010 my windscreen outer 'seal' is loose in both the top corners, giving a lot of wind noise at speed. Looks like the windscreen as been replaced at some point in teh past because teh channel into which the seal fits is clogged with sealant. Whats the best way to remove the sealant and refit the top trim piece? Or would it be better to remove teh seal entirely, clean it all up and refit? Knowing my luck i'd end up scratching half the paint again... Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted January 31, 2015 Quote my windscreen outer 'seal' is loose in both the top corners, giving a lot of wind noise at speed. Looks like the windscreen as been replaced at some point in teh past because teh channel into which the seal fits is clogged with sealant. Whats the best way to remove the sealant and refit the top trim piece? Or would it be better to remove teh seal entirely, clean it all up and refit? Knowing my luck i'd end up scratching half the paint again... Thread Resurrection :) I've got the same problem. First "spirited" run today after having the screen replaced in December. The outer seal across the top of the screen keeps popping out. There is sealant in there. But not a lot of it. What should I use. Sikaflex, Wurth Classic Plus, Tiger Seal? Should I cut the existing sealant out before reapplying? Never done this job before and I know this area can be a rust trap. Mine is like factory at the moment. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted January 31, 2015 (edited) Or maybe they reused the old push-in seal? I wasn't there at the time to see them fitting. But it is a fitter well known and regarded on the Forum. Does a new push-in seal come with a new screen (Pilkington)? I see the seals are only £7.50 535853307A01C Edited January 31, 2015 by MikeVR6 Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 1, 2015 When i had my screen fitted the guy had the screen and all the seals, He refitted the old outer seal as the new one was so out of shape it looked terrible and wouldn't sit very well. It come all screwed up in a tiny bag. That £7.50 seal isn't the outer one, that the top one i think, fits onto screen before it goes in. Someone was recently selling 5 or 6 of the complete seal kits (on ebay) for about £36, i bought that for the outer seal, it came in a long tube so not all kinked etc. Not fitted it yet though. But i'll probably go around the seal with some silicone sealant before fitting it. Quote Share this post Link to post Share on other sites
STU175 0 Posted February 1, 2015 (edited) i would call the fitter out to sort it, it should come with at least a years warranty? the last thing you want to do is squirt in lots of sealant and block the drain channel or seal in water stu - autoglass fitter Edited February 1, 2015 by STU175 Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted February 1, 2015 (edited) Quote i would call the fitter out to sort it, it should come with at least a years warranty? the last thing you want to do is squirt in lots of sealant and block the drain channel or seal in water stu - autoglass fitter I would do Stu. But the fitting was done in the UK and the car is now back with me in Germany. So I gotta take care of it myself. Shame really as the rest of the job was as good as everyone on here who'd used them said it would be. At least they didn't go the other way and completely fill the gap with sealant. I can see the bodywork around the screen when I pull the seal out. It's all like factory. So how should I go about it and what do you recommend as a sealant? And you're right Jim. The part no. is 535 845 127A £26.80 from VW heritage. And the picture on their site is exactly how it shouldn't come :) https://www.vwheritage.com/shop/535845127A/front-windscreen-surround-cover-section-corrado-89-95/ Looking at the trim today. I'm sure it's new and it's not kinked. They just were too careful with the sealant. Edited February 1, 2015 by MikeVR6 Quote Share this post Link to post Share on other sites
Glassman 10 Posted February 2, 2015 stuartscales said: i fitted windscreens for living and i wouldnt attempt it mate youll end up with more problems then the gap youve got allready daves16v said: Stu, what are my options, silicone sealant or something similar? Will I get leaks if don't bother filling it? He said he did it for a living. He didn't give any indication of how good he was. Quote Share this post Link to post Share on other sites
kidcorradovr6 10 Posted February 2, 2015 check this, plan b http://forums.vwvortex.com/showthread.php?5696176-A-Civic-windshield-moulding-works-on-our-Corrados&highlight=civic Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted February 2, 2015 (edited) The Fitter has checked his e-mail and is sending me the right adhesive and some instructions. I'll post up how I get on. Edited February 2, 2015 by MikeVR6 Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted February 13, 2015 From VW/Audi DH009100A2 for the Adhesive D002000A2 for the Adhesive Remover (in case you get some on the bodywork ;) Quote Share this post Link to post Share on other sites
