stormseeker
VAG-COM scanning & help
Yep, you just get another lead - you're talking about the one behind your gearstick, right?
yeah, what do you mean get another lead, I dont have one. just the black one , do I ground it out to the battery or something?
hi i've got vag-com if any one need's it. i've got both 16pin and 2x2 connectors
i am im anglesey north wales
.... no one listened to me. I have just the black one, what do I do. will VAG Com 2x2 even work? yes I only have 1 looked about 10 times
A single black wire means your Corrado early non digital diagnostics. Therefore it uses voltage pulses ("blink codes") to show singularly the 4 digit fault codes. VAG-COM will not work with it. The Bentley manual covers this in full detail.
"If the two diagnostics sockets (Black/White) have either 1, 2 or 3 wires only attached, then the car is analogue and VAG-COM cannot interface with them. These cars use "blink" codes (grouped voltage pulses) in a primative way to throw out the faults out, one at a time. "
http://the-corrado.net/.archive/forum/viewtopic. ... ght=vagcom
VAG-COM frenzy at CCGB AGM Sun 17/4/2005
I'll be taking my laptop on Sunday, if anyone needs a good deep scanning (ooooer! :shock: ) give me a shout....
I've got the KEY-COM version official cable and full software and am willing to help people in the Glasgow area. I don't have a 2x2 adapter unfortunately, so can't do the earlier cars. Mine is 1994 and has the 16 pin new-style connector.
I try to check the forum regularly but can't guarantee to be on every day.
I have VAGCOM and the OBDII connector, can help out in Coventry/Warwickshire depending on timing. Drop me a PM.
Olly
Anyone with vag-com close to Epping in Essex?
I've got an 95 Storm with the 16 pin connector.
It's got an idle & mis problem, :( (separate post 'vr6 misfire'). I'm considering replacing the MAF but would like to check the codes first.
Kev read codes last week & it looks like it's highlighted problem car was having (Camshaft position sensor). I'm thinking I should have my own copy of vag-com. Any opinions on the cheapest way of getting cable/software?
I now have vagcom with both 16 pin and 2x2 adaptor. Live near Bournemouth and work in Southampton so if you near and need help please shout.
Cheers Andy
I can provide quick VAG-COM fault code scans (16-pin connector) if people can come to me. Location High Wycombe, Buckinghamshire.
can anybody help me with these faul codes i know its not registered but any help would be cool
VAG-COM Version: Release 311.2-N
Chassis Type: 50 - VW Corrado
Scan: 01,02,03,08,15
Address 01 -------------------------------------------------------
Controller: 021 906 258 CP
Component: MOTOR 2,8L 6-Zyl.
Coding: PMC 1 HS
Shop #: 0261203565
6 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00561 - Shareware Version. To Decode all DTCs
15-10 - Please Register/Activate - Intermittent
00553 - Shareware Version. To Decode all DTCs
29-10 - Please Register/Activate - Intermittent
00518 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
00611 - Shareware Version. To Decode all DTCs
28-10 - Please Register/Activate - Intermittent
00513 - Shareware Version. To Decode all DTCs
03-00 - Please Register/Activate
Readiness: N/A
money is keeping me from registering at the mo please help
kelly
