VAG-hag 0 Posted November 21, 2011 lots of stuff as im stripping it for paint - damn you brittle old (expensive) plastic!! Quote Share this post Link to post Share on other sites
guildmage 11 Posted December 12, 2011 disaster :( Drove my car to work and while opening work's gates I've noticed I'm leaking oil. Not just drops, I was leaving streaks of oil! I could have killed the engine if my work was more far away from my home. Hopefully it was just 2-3 miles. Now then I have located the leak to be coming from that top part of the "oil-filter section" (forgive me I am not very mechanical). Car is now at the garage, mechanic told me I had almost no oil left in engine and that I was very lucky. Now waiting for it to be repaired... it's always Monday isn't?! Still I am unsure if located leak correctly and if it's something that can be easily fixed. But keeping my fingers crossed (from what I researched, hopefully it will be just that rubber o-ring, but knowing my luck... ehh better not think). What I don't fully understand is, if I was almost out of oil there should be an engine/oil light showing up on my dashboard to inform me about it, right? Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted December 12, 2011 guildmage said: What I don't fully understand is, if I was almost out of oil there should be an engine/oil light showing up on my dashboard to inform me about it, right? guess the oil pressure sensor is also busted! Quote Share this post Link to post Share on other sites
scruffy16v 10 Posted December 12, 2011 drove car into a house. elec windows stopped working. slow flat on front tyre. i dare not write the rest of the list out in fear of RSI :) Quote Share this post Link to post Share on other sites
Album56 0 Posted December 13, 2011 Backlights for LCD displays not worked for about 10 years, got the new lamps about 2 years ago, its on my to do list, along with the window thingys I bought on hear last year........ Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 13, 2011 (edited) Oops wrong thread. Edited December 15, 2011 by Critical_Mass Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 13, 2011 24V Renshaw said: Ordered mine tonight on the way home so should have them Wednesday. 57p from VW :) Can you fit mine at the same time lol. I tried n failed . Quote Share this post Link to post Share on other sites
luke w 0 Posted December 14, 2011 While putting the shopping in the boot this fell on my head. Anyone know where it should go? I had a quick look but it's pitch black outside and peeing it down so I got inside pretty sharpish. Quote Share this post Link to post Share on other sites
Album56 0 Posted December 14, 2011 That looks like the boot lifting spring/plunger, its fitted in the boot lid to the left of the catch & lifts it slightly when you pop the catch so you can lift it easily. Quote Share this post Link to post Share on other sites
luke w 0 Posted December 14, 2011 Thanks mate, will check it out tomorrow when it's light. Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted December 14, 2011 I replaced one recently. It cost about 10 from the stealers. You'll need the little rubber stopper on the end as that doesn't come with the plunger. You need to take the boot lid trim off to get your hand in the fit it. There's a plastic collar/nut that you need to find. My memory is that it was inside the boot lid. If you can't find it then you'll need one of them too. Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted December 16, 2011 Just looking atthe picture now - was viewing on the phone originally - the part in the picture has the nut fitted to remember to take it off before chucking it in th bin Quote Share this post Link to post Share on other sites
Redfox 10 Posted April 9, 2012 A ground cable from the hood to body. Will order one tomorrow, or make one up. Cheers, Redfox. Quote Share this post Link to post Share on other sites
Fin2982 10 Posted April 10, 2012 Well went to move the C over the weekend and to start cleaning it up, turns out the battery is flat as a fart, went to pop the bonnet and the cable snapped again!! Took 2 of us 20mins to pop the bonnet last time! Quote Share this post Link to post Share on other sites
G60 CS 0 Posted September 6, 2012 earth cable from bonnet to body, wiper linkage, heater matrix, clutch master and coolant outlet on the side of the block :( What a week !! so found someone who can supply the bushes on the wiper linkage and can make me a new arm if required as its obsolete now, found a company to re manufacture my clutch master as that's obsolete too. Found a guy in Germany that makes the coolant outlet cover plate again obsolete part. had to buy a new block as mine was too corroded from the coolant leak just need the obsolete O ring now !! Soon be back on the road !! Quote Share this post Link to post Share on other sites
G60 CS 0 Posted March 4, 2013 Ha Ha surely other C's have broken since my last post !! So since the above I couldnt seal up the coolant outlet & ended up having to change the complete engine !! Here's whats happened since : Brake master as well as clutch master cylinder Sunroof repaired CO Pot failed ABS fault microswitch on throttle body repaired rear spoiler failed Windscreen and bonnet replaced to to bonnet catch failure 3 toothed drive belts snapped due to incompetent RAC technician stage 4 charger failed due to incompetent RAC technician solid tensioner replaced due to incompetent RAC technician cambelt tensioner (used in toothed pulley setup) replaced due to incompetent RAC technician aux belt failed and replaced due to incompetent RAC technician water pump and thermostat replaced Powersteering pump failed due to incorrect fluid being used by previous mechanic Bonnet release cable failed due to incompetent bodyshop However cars now in very very good hands and am looking forward to collecting it Friday coming and enjoying the drive home ! Quote Share this post Link to post Share on other sites
bully 10 Posted March 4, 2013 water pipe.. lol was being cut by my fan.. fixed and replaced with a new thicker one and re mounted it so it dosnt touch the fan. Quote Share this post Link to post Share on other sites
G60 CS 0 Posted April 7, 2013 Well just me then with a Car that's cursed !! Got it back from JMR running really really nicely now. 2 weeks later it gets hit twice whilst parked, same day 2 different places& no details left. Then a stone flicks up and puts a crack across one of my fogs. I buy some replacements and realise they're the wrong type, my cars a 92 with an early interior but late bonnet and as I've found out late fogs Quote Share this post Link to post Share on other sites
Cressa 45 Posted December 30, 2018 Found this unused thread.... Got to be worth adding to Quote Share this post Link to post Share on other sites
Cressa 45 Posted January 6, 2019 Spent 100 pounds on a new aircon condensor. Managed to ruin the thread when fitting an old hose onto it..... to make matters worse, on disconnecting the hose it snapped a piece off the receiver drier... Expensive day as I need to sort the hose as well. 3 items all sha##ed. AGHHHHH Good job its the Corrado and these things are the norm for us !!! Quote Share this post Link to post Share on other sites
