hombre_paulo
Blackberry Corrado VR6
easypops - refunded
KadVR6 - i do, but as I am storing parts in the car i dont want to leave it unlocked for the tme being. i`ll pm once available
ok no problem, just send me a pm when they are available
karl
I'm after two of the looms from behind the dash...
The ignition/stalks - fuse box
The cig lighter/cd player - fuse box
... Have you got these and how much would you sell them for.
Thanks, Jim
Thanks, Jim
Yes got both of these. Tucked behind the dash at the moment but will be coming out soon i`ll let you know once they are out.
Have you got the headlight switch to fuse box loom?
If so how much posted?
Has to be good condition with no sign of cable damage from short circuit though
Oh, and the under bumper plastic splash guards? The ones that join the wheel arch lining and the front splitter
Cheers
Gus
What condition are the front door seals in?? NOT the ones that are on the door THE one that goes around the body of the door frame
Must have no spilits or parts where its come apart
Cheers
Jon
Update - also see page 1 for more updates
- ISV, damper pot & pipe work - £25
- Fan Control Module - SOLD
- Mk4 Expansion tank, cap and Plug (does require mounting bracket to be modded) - SOLD
- Head, TB, Heater Matrix coolant hose (used for less than 1,000 miles, non-vag) - SOLD
- Wiper motor and linkage (new crank arm) - £30
- Comfort Control Module - £17
- Rear View Mirror - £8
Edited by hombre_paulo
Does the DOHC engine cover have any splits or significant marks? If not then I'd like to take it please.
Do you have a dash blank (the slightly curved one) that normally sits where the heated seat switches would be? It looks like this: http://www.ebay.co.uk/itm/VW-CORRADO-DASH-BLANK-SWITCH-VR6-G60-16V-8V-BLANKS-/220749309361?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3365af25b1
Also... do you have the left and right wing mirror glass (just the glass) and if so is there any discolouration?
Sorry but I offered this to C5 OEM in his wanted thread, yours if it falls through though.
Sorry but i dont have the dash blank and the mirror glass will be sold with the mirrors
How much for both wings and front bumper with postage
cheers
Hi mate how you going with these and also how much for the radiator also?
cheers
Hi did you get my reply yesterday regards the motor and other bits? I sent it from my phone so no idea if it actually worked lol
Hi mate do you have the top radiator fixing lugs? I've got the two bits that go thru the slam panel, it's the bits they screw into with the rubber bushes on. Hope that makes sence
