P3rks
Clearout - Mainly G60/VR6 - Loads! List Updated 22nd July
22.07.2012 - This is an updated list with what's left
All prices are negotiable, especially the bigger stuff. I need them gone.
OBD1 2.9 VR6 Throttle Body. All cleaned up as I started polishing it. Comes as pictured with the diaphragm and sensor. SOLD over on E38
Corrado rear script badge (genuine), in Aqua Blue Pearl. All clips are intact. SOLD To: guildmage
Genuine G60 rear badge, very good condition. £20
Metal Rocker Cover (perfect for polishing/powdercoating) with a BNIB VW gasket: SOLD
VR6 K&N Induction Kit (Bracket, Filter and Air Direction Hose): £30
VR6 Green Induction Filter: (little worn on one edge, still perfectly usable): £30
VR6 Coilpack. Genuine VW - Stamped VW and Beru. It has two tiny cracks (see Photo 3) on the body next to the fixing holes, just cosmetic. This does not arc and works perfectly: £50
Loads of G60 Engine parts:
x2 Plastic cambelt covers and x1 metal back plate - SOLD to floppyman
x2 Rocker Covers - £20 ea
ISV (fully working, proper G60 one) - SOLD to VW_john
x2 rear alternator brackets (top of first pic next to cambelt covers) - £5ea
Fuel Pressure switch, bracket and hose - £10
In-tank fuel pump - £30
Water Flanges (fairly new) including recent senders - £15
Cambelt Pulley (1k old) £5
Brackets for inlet/head/fuel rail/isv - £5
Charger oil feed hoses (x1 braided x1 rubber) - SOLD to floppyman
Larger charger bracket with pulley - £30
Small(er) charger bracket (front block to lower charger) - £15
Plastic charger top cover - £10
Oil filter/cooler to head bracket - £5
Auxiliary belt bracket/pulley/tensioner - SOLD to VW_john
Metal water pipes - £10
Crank pulley - £10
Clutch master cylinder - £15
Starter motor (honestly the best VW starter I've ever had!) - £15
Fuel rail/injectors - £20
Servo vacuum hose - £5
Inlet manifold - £15
Charger boost return blacking plate - £20
G60 Exhaust manifold and Downpipe - £50
G60 Driveshafts (one recent joint, all four rubbers are good with no splits - No knocks or anything) - £50
Edited by P3rks
Continued...
G60 Subframe - SOLD to clumpy1
Early Spec (1991) Window control module and spoiler control module: £10 ea
Late style indicator/wiper stalks. One has cut wiring (was attached to an early car) but is in the better condition. The other is uncut but has faded writing. Both fully work and are the same part number: £15 ea - Cut wires one sold
Smoked side indicators (IN.pro): SOLD
Autohaus PORSCHE stuttgart plate holders - £10
Late spec front indicators. These were new in 2009 and have covered approximately 10,000 miles. Some arsehole reversed into my car and put hairline cracks in them. Other than the cracks they are in excellent condition. The cracks are watertight and aren't too bad all things considering: £30 each:
Edited by P3rks
1993 Year Spec Genuine VW Corrado Brochure. Excellent condition. Bought in error (mines a 1993 car but being built in December it's 1994 spec). Just want what I paid: SOLD
August 1990 Genuine VW Corrado brochure. Excellent condition. Once again, bought in error but this time by my g.friend: SOLD
Late Spec (6-pin) sunroof motor. Fully Working, slides back, forward, up and down. Nice an smooth. Came from a 1993 car. Part No: 3A0 959 731B: £20
16v Rocker Cover (ABF/9A/KR), powdercoated metallic silver, including 16v front mount bracket and a few other brackets: SOLD
Ford VR6 PCV Valve - Brand new in bag. This is identical to the VW part (VW don't supply the PCV valve by itself, only with all the pipework and it's mega bucks). It's not actually stamped Ford anywhere on it, the part number states VW. These are approximately £50 now. SOLD
Late spec genuine heated seat switch. Bought then turned out I didn't need it. I paid £25 posted so I just want that back. SOLD
That is all.
Thanks.
Edited by P3rks
Hello mate,
I'll take the semi polished manifold (assuming it fits a 94 VR6), one of the PCS Valves, and the clifford alarm as long as you have the working valet pin code for it. £100 for the three including delivery?
Can't collect so happy to go with a courier.
Cheers
Rick
Edited by Tigerfish
Hello mate,
Cheers
Rick
Great it's all yours. :o
And yep, I have the valet code.
PM'd
One pcv valve
G60 cambelt covers
Charger oil feed pipes
How much posted to tw19 if possible?
And would be interested on the short g60 driveshaft if you want to split them
One pcv valve
G60 cambelt covers
Hey
I'd like to keep the driveshafts as a set for the time being please. Give it a week or so and I may split.
£35 for the rest posted with royal fail or £40 with a 24 hour courier.
Rich.
hello mate can i get the G60 front badge and also the early grill with the silver badge in it?
so £40 in total and how much for p&p ?
ALL SOLD:
Semi polished VR6 Manifold
Clifford Alarm
x2 pcv valves
G60 cambelt covers
Thanks Tigerfish & floppyman
Hey man,
Once again call postage £5 with royal Fail or £10 with a next working day courier.
Rich
If anybody wants stuff picking up & taking to CCGB National day then let me know.... Enthusiast just out of interest you dont have any car space going begging do you? In need of a good place to keep mine.
Nice one!
Unfortunately I don't. I'm borrowing a friends single garage and it's practically jammed to the brim with mine, his and another friends car parts. I am heavily considering renting a unit, I would be more than happy to share the space/costs with someone. PM'd
I'll take the boost gauge please, how much posted to leicester?
Cheers
Scott
PM'd
Hi, I'll take the VR6 HT leads please.
PM'd
---------- Post added at 9:40 PM ---------- Previous post was at 9:39 PM ----------
hi, would you split the numberplate plinth from the hatch
Little confused? Do you mean the script bit from the bottom of the plate holders?
sorry, you've described it as the black plastic number plate recess in your pics,
Ahhh,
I got you now.. Well, If the boot hasn't sold by next week I'll be scrapping it and taking off the plinth and wing off etc.
So you get first refusal on it. Expect a PM next week.
Rich
What make are the leads for the vr?
Just this minute been sold to 'smee'
Sorry.
Rich
