24V Renshaw 0 Posted June 13, 2012 Does anyone know if the Rubber fuel lines on the side of the VR are moulded to shape from new, or is it just 6mm rubber hose that has set in that shape over time. I need to replace mine and was just going to buy some 6mm fuel hose... Jay Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 13, 2012 I also need to do mine, took a pic of them the other day Looks a bit tricky getting to the end near the bulkhead. Sent from my X10i using Tapatalk 2 Quote Share this post Link to post Share on other sites
daves16v 1 Posted June 13, 2012 Jay, just check the internal bore, I remember reading somewhere that it might be 8mm. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted June 13, 2012 Cheers Dave, I have not actually checked the size yet, but is it just straight rubber pipe rather than a pre moulded pipe? Jay Quote Share this post Link to post Share on other sites
daves16v 1 Posted June 13, 2012 Cheers Dave, I have not actually checked the size yet, but is it just straight rubber pipe rather than a pre moulded pipe? Jay Not sure about that. Quote Share this post Link to post Share on other sites
RW1 0 Posted June 14, 2012 They are both pre-shaped as you see them on the side of the engine in the clips. Ordinary straight fuel pipes will look odd as they won't have the right shape. VW spare parts are pre-shaped. . Quote Share this post Link to post Share on other sites
fla 9 Posted June 14, 2012 i have used the 7.5mm (iirc) fuel hose from Halfords on mine since about 2005 with no issues at all. I also bought the appropriate hose clamps rather than jubilees to ensure even allround sealing pressure. No kinks or folds so far. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 14, 2012 They are both pre-shaped as you see them on the side of the engine in the clips. Ordinary straight fuel pipes will look odd as they won't have the right shape. VW spare parts are pre-shaped. . They won't have the correct stress relief for engine movement either. Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 14, 2012 I'm about to do this when the replacements arrive - you'll have to remove the air box and the rubber intake boot to get access. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted June 14, 2012 I have a pair of these that were on my car for Are you sure you mean fuel lines mate? Jay Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 14, 2012 Are you sure you mean fuel lines mate? Jay No..... sorry bud, post deleted due to me not reading your post properly. whoops! Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted June 14, 2012 Just checked with VW and they are £52 each!! hmmm... really want the original ones, but.... Jay Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 14, 2012 damn :! I might have to order some though, would rather £104 than a corrado on fire Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted June 14, 2012 There is no question of me replacing them, I am definitely doing that this week, its just whether I spend £100 on OEM ones... Or £10 on 8mm high pressure certified fuel pipe. (spot the difference) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 14, 2012 I actually bought £4 abs sensors instead of vw ones that were £55 each. Am sure the cheaper fuel pipe is up to the job. Id be happy with that. Sent from my X10i using Tapatalk 2 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 14, 2012 The first picture is spot on. So long as you keep the 90 degree bends like that, you'll have no issues. I've seen people run straight lengths to rigid lines, which is a big no-no. Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 14, 2012 You can buy the VAG lines for around €45 each from Germany - shipping is very cheap. Still a lot more than the generic hose though. Quote Share this post Link to post Share on other sites
Goldie 2 Posted September 7, 2012 Im about to change these on mine.. The lines are on back order from the Factory and are the wrong side of hundred quid for the 2. Fuel lines under the car, 2 out of 3 flexibles are obsolete.. Has anyone used anything else to change these or have any idea where i could get them from?? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 7, 2012 I ended up doing what jay said and just bought some 8mm ID fuel hose and some new clips. Went on fine and can't see any problem with it, it just clipped in and the fact it wasn't preformed bends didn't cause any issues. Used this stuff http://www.fuelpumpsonline.co.uk/8mm-fuel-hose---sytec-competition-injection-rubber-fuel-hose-371-p.asp Quote Share this post Link to post Share on other sites
swampy 0 Posted September 7, 2012 If any wants it I could supply braided fuel hose with aero quip type clamps Would be more than the rubber hose but less than genuine Quote Share this post Link to post Share on other sites
Mawrick 0 Posted September 14, 2012 Just my 2 cents - I went for braided lines ........for a while Was actually a kit made for the Corrado - BUT from time to time I smelt petrol - especially just after "startup", after a bit of testing smaller clamps, and thightening them (I used the same as shown in the picture in the post further up also)......but still smelt petrol - after a while I got someone to look when I started and it was leaking petrol when doing the start, and the petrol drained straight down into the alternator. After this I went with the OEM hoses and OEM Clamps (Would especially recommend using the OEM Clamps - even if one goes with a normal rubber hose).... Just glad mine didn't catch fire, as it would be real danger of that pouring fuel into the alternator.......;) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 14, 2012 I still not started mine so can still change them. Think I have the original clamps. Can't remember what they looked like though. Am buying fire extinguishers before I fire it up for first time. Wanted some anyway. Sent from my X10i using Tapatalk 2 Quote Share this post Link to post Share on other sites
fla 9 Posted September 14, 2012 Just my 2 cents - I went for braided lines ........for a while Was actually a kit made for the Corrado - BUT from time to time I smelt petrol - especially just after "startup", after a bit of testing smaller clamps, and thightening them (I used the same as shown in the picture in the post further up also)......but still smelt petrol - after a while I got someone to look when I started and it was leaking petrol when doing the start, and the petrol drained straight down into the alternator. After this I went with the OEM hoses and OEM Clamps (Would especially recommend using the OEM Clamps - even if one goes with a normal rubber hose).... Just glad mine didn't catch fire, as it would be real danger of that pouring fuel into the alternator.......;) Looks excellent Mawrick, especially that support bracket. I would have just replaced the jubilee clips with hose clamps. Jubilees just dont offer even pressure across pipes and tubes which is of course even more critical on fuel lines. Quote Share this post Link to post Share on other sites
Mawrick 0 Posted September 14, 2012 Looks excellent Mawrick, especially that support bracket. I would have just replaced the jubilee clips with hose clamps. Jubilees just dont offer even pressure across pipes and tubes which is of course even more critical on fuel lines. deff looked good, but after trying hose clamps like the ones in the picture from the post above (not my post), which is supposed to clamp evenly (it's the ones where the screw just screws directly tightening it, without having the threads on the "band" itself but still had problem that they would "untighten" after a little while, and IIRC the OEM ones wouldn't fit onto these.....sad but true :) )....... Ohh well, personally I'm just better of being safe then sorry.....:) lol Just thought I'd flag my little "concern" here though......as a tip ;) (although I would think the rubber lines would be just fine - but I would strongly recommend the OEM hose clamps).....it's the "self adjusting" ones): Didn't find pic of exactly the ones on the fuel line - but same style as these ones: Cheap from the dealer anyhow :) Quote Share this post Link to post Share on other sites
Goldie 2 Posted September 15, 2012 All the clips, brackets etc are still available from the dealers as are the hoses... Stand by for parting with around 120 for the lot.. Quote Share this post Link to post Share on other sites
