P3rks 11 Posted April 8, 2013 (edited) LIST UPDATED - 17th June 2013 OPEN TO OFFERS ON EVERYTHING (unless otherwise stated) VR6 Corrado 2.9 VR6 Inlet manifold (both parts) including throttle body. Also fits OBD1 Golfs and has a larger bore/plenum for better top end. Underside covered in heat reflective tape to reduce heatsoak - £100 VR6 Coilpack (left on the picture), genuine VW, no cracks and perfect working condition - SOLD VR6 original exhaust manifold and downpipe -£25 VR6 Flywheels, Both have the part number: 021 105 273 H. The one to the right it noticeably thinner and weights approximately 2kg less than the one on the left. The only difference in markings on the rear is that the lighter one says 'F&S 1' and the heavier says 'F&S 4'. I can only presume it's been skimmed or lightened. - £25 each VR6 (Golf and Corrado) fuel filter housing and clips, unbroken with no cracks. Part No: 1H0201505B - SOLD Golf VR6 (1997 OBD2) fuel pump. Nice and quiet operation. £30 VR6 (Golf and Corrado) 90a alternator with wiring. Part No: 021903025. SOLD VR6 Aircon pump (right in photo) - £30 VR6 K&N air filter / induction kit, with all brackets and cold air feed - SOLD VR6 Driveshafts - £50 VR6 Wishbones, perfect for powdercoating. - £50 VR6 ECU (1993/94 Corrado 2.9 VR6 - OBD1 - Part: 021 906 258 AG) - £50 VR6 Lambda (1993 Corrado 2.9 VR6 - OBD1) - Removed due to a OBD2 upgrade. Was VAGCOM tested as fully operational before removal - £15 VR6 Brake servo and master cylinder - £50 VR6 Cam sensor - VAGCOM tested - £20 VR6 Injectors, perfect for sending off for cleaning. £10 VR6 4bar fuel pressure regulator (this was recently sent off and ultrasonic cleaned with new filters and o-rings - Unused since clean as I went 3bar for my OBD2 instead) - £25 Edited August 31, 2013 by P3rks Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 8, 2013 (edited) G60 G60 Exhaust manifold and downpipe - SOLD G60 Engine brackets; large charger bracket/pulley, alternator bracket (x2), rear charger bracket (x2) G60 rear engine mount bracket (the rest are ABF and in another listing so please ignore). The large charger bracket is £30, the rest £10 a piece. G60 standard camshaft and pulley - £20 G60 driveshafts - £50 G60 charger outlet blank - £15 G60 inlet manifold, larger port version. Part number: 037 133 223AD General Corrado Corrado electric sunroof switches. Both for late cars (post 1993). Ones early type, ones late, both interchangeable. - £10 each Spoiler (Sold) and central locking relays, part numbers: 191 959 875 & 535 919 845A - £5 Early and late clutch master cylinders, fully working. SOLD Late window switches - £20 JBL GTO 528 speakers - Direct replacement for the front of late Corrado's - £10 90mm Splitter - Cracks to both corners but still looks ok when on the car. SOLD 90mm Splitter - no cracks, few scuffs but nothing you wouldn't expect from a 20 year old splitter - Just trying to be honest; but it's as good as you'll ever get. I reluctantly don't wont to sell it but Sheffield roads will just kill it. SOLD All items are in Sheffield. I can post at cost. Rich 07815 089 163 Edited August 31, 2013 by P3rks Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 8, 2013 (edited) Double post Edited June 17, 2013 by P3rks Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 9, 2013 Can I have the spoiler control module posted please Rich. Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 9, 2013 Can I have the spoiler control module posted please Rich. You can. PM'd Quote Share this post Link to post Share on other sites
G60MAT 0 Posted April 9, 2013 Interested in the G60 Meyle oil pump but how much is the G60 inlet manifold - no price? cheers, Matt. Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 9, 2013 The Meyle oil pump is provisionally sold over on E38, he has 24 hours then it's yours. The inlet. £20? Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 15, 2013 Meyle pump is sold Quote Share this post Link to post Share on other sites
GrahamU 6 Posted April 15, 2013 I'll take the eye brow please, could you PM a price posted Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 15, 2013 PM'd ---------- Post added at 4:29 PM ---------- Previous post was at 2:44 PM ---------- List updated, see post 3. Magnex exhaust, ECU etc. Quote Share this post Link to post Share on other sites
mayo6650 10 Posted April 15, 2013 will take the g60 badge Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 16, 2013 G60 Badge and eyebrow sold. Quote Share this post Link to post Share on other sites
GrahamU 6 Posted April 18, 2013 Received the eyebrow today, spot on, thanks Quote Share this post Link to post Share on other sites
karmannski 0 Posted April 19, 2013 Engine mount and vr6 stealing wheel please ASAP Quote Share this post Link to post Share on other sites
mayo6650 10 Posted April 21, 2013 Badge received thank you Quote Share this post Link to post Share on other sites
kingkenny100 0 Posted April 22, 2013 Interested in exhaust - will you post? Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 22, 2013 I can post. PM'd. Quote Share this post Link to post Share on other sites
vr6lee 10 Posted April 28, 2013 Hi is the magnet exhaust still for sale? Quote Share this post Link to post Share on other sites
sgaites 0 Posted May 4, 2013 Hi I have PM'd you - please could you let me know if the G60 fuel rail (and injectors + loom ?) is still available ? thanks Quote Share this post Link to post Share on other sites
P3rks 11 Posted May 9, 2013 Magenx exhaust is sold. As is the G60 fuel rail. Thanks Quote Share this post Link to post Share on other sites
dj b 10 Posted May 12, 2013 Have you still got the maf for the corrado vr6? im gonna check my wires today and see if theyre ok if they are Ill need this. cheers, Ben Quote Share this post Link to post Share on other sites
P3rks 11 Posted June 17, 2013 Bump. Un-cracked 90mm splitter, injectors FPR etc added. List updated, open to offers on EVERYTHING! Quote Share this post Link to post Share on other sites
enrikito42 10 Posted June 20, 2013 Im intested in 2.9 VR6 Inlet manifold Quote Share this post Link to post Share on other sites
