daves16v
Various parts off a 94 VR6
All parts taken off a 94 VR6 that had done 135k miles.
Prices are plus postage but some parts will be collection only.
Collection from Notts/Derbys M1 J25.
Black carpet, vgc but will need shampooing - SOLD
5 stud spare wheel, tyre looks unused - SOLD
Black boot side carpets, vgc £15 for both collection only.
Inner door rubber that run around the frame, vgc £10 each.
Classic Green rear spoiler, some light scratches but nothing major £10 collection only.
Scuttle to engine bay seal, good condition £5 collection only.
Roof lining front trim in Grey, vgc £20 collection only.
Driver door card top trim, - SOLD
Pass door top trim, the door card top trim clips into this part, vgc £10.
Black pass side foot well trim, vgc £10.
Black driver side lower shelf, has an alarm switch in the top part which can't be seen when fitted, vgc £10 collection only.
Black C pillar trims, one of the posts has snapped off the driver side but doesn't appear to cause a fixing problem, vgc £10 each collection only.
Black driver side rear shelf support, vgc £10.
Exhaust manifold cover - SOLD
Clear side repeaters, vgc SOLD
Alloy door lock pins, vgc £5.
Door speaker grill, vgc £5.
Door inner trim triangles, vgc £5 each.
Inner driver side door pull with mirror switch, vgc £12.
Inner pass side door pull, vgc £7.
Edited by daves16v
More.....
Pass side door opener trim, vgc £5.
Interior light/sunroof switches, vgc - SOLD
Wiring loom 535 971 056 - heated rear window and fog lights switch £10.
42 pin engine/injector loom - SOLD
Wiring loom 536 971 052 AP - has numerous connections to it and also the glove box light £10.
Wiring loom 535 971 322 AF £10.
Wiring loom 536 971 282 AD Blower Motor £10.
Steering column, vgc £20.
Plastic rocker cover with oil cap £15.
Grey driver side sun visor, just needs a clean £5.
Driver footrest, vgc £5.
Loom heat shield £5.
Fuse box with relays and fuses - SOLD
Gear surround, vgc £10.
Rubber door loom gaiters £5 each.
Glove box hinge cover, some tabs broken but can be glued in place £5.
Dash switch blank with hole for alarm LED - SOLD
Fuse box carrier £5.
Rear ashtray £5.
Cable carrier, front of gearbox £5.
Edited by daves16v
More.....
Dash speaker cover pass side, just needs touching up £5.
Aux pump rubber mount - SOLD
Freshly powder coated gearbox shift weight £10.
Wiring loom 535 972 235 A £5.
Wiring loom 535 971 063 BN £5.
Aerial cable £5.
Wiring loom 536 971 160 K £15.
Rear brake pads, used but plenty of pad left £7.
Black B pillars, tiny nick on driver side, vgc £10 each collection only.
Roof grab handle, vgc £7.
Plastic trim behind pass headlight, vgc £5.
Rear exhaust heat shield - SOLD
Exhaust heat shield, small amount of corrosion on one of the mounting points £15 collection only.
HT lead holder £5.
Handbrake with leather handle cover, leather is a little worn £10.
Tank filler rubber boot - SOLD
Tank access cover £5.
Black carpet piece that sits under the rear hump £5.
Classic Green rear umber plate light surround, tiny bit of corrosion of the rear, ideal for a repaint - SOLD
OBD1 Lambda Sensor £5.
Edited by daves16v
More.....
Dipstick with tube £10.
Chrome door openers, some pitting on the driver side - SOLD
Door front window runners £5 each.
Wiring loom, ECU to engine - SOLD
Jack and wheel brace with plastic wallet £10.
Alternator/power steering pump bracket £10.
Injector rail with loom channel and fuel pressure reg £10.
Upper chain cover £10.
Lower inlet manifold £10.
Water pump pulley £5.
Alternator pulley £5.
Thermostat housing with sensors, the housing is in good condition with no signs of age - SOLD
Lower chain cover £10.
Central locking controller £10.
Rear shock covers £5.
Rear seatbelt set £15.
Front seatbelt set £15.
Throttle cable £10.
ECU 021 906 258 CP - SOLD
Immobiliser controller and ring £10.
Edited by daves16v
Interested in the clear side indicators & chrome door openers. Can you quote a price with combined postage.
Cheers
  A.passap said:
H do u have the distributor for sale along with the ht leads? For a 2.0 16v?
No, these parts are off a VR6.
Can i have the driver and passenger top door card trim's please and if you wouldn't mind posting the carpet I'll have that as well please Thankyou.
The trims are different, driver is the top trim, the pass is the trim underneath that attached to the top of the door. Still want them?
At the moment the carpet is collection only.
  Alan h said:
Was the lamba sensor in good working order if so how much with postage
Alan, I don't know to be honest which is why it's a fiver. £7.50 posted if you still want it.
Have you still got the loom from the ecu and the loom to the injectors? (just to be sure are these the ones that connect with the big round plug by the aux water pump?) If you've still got them how much for both please? Can collect as only in Stoke so not far away from you. Thanks Neil
  Stonejag said:
Could I have the exhaust heatshield, posted please? Ta :)
Are you after the one at a tenner or fifteen ?
Only ask as I could do with the one at a tenner and didn't want to step on your toes.
Sorry Dave just seen your reply can i have just the driver's then please and regarding carpet I would really appreciate it if you would consider posting/couriering Paisley freight have a car part's section which is really good,It's just I am a little far away for collection if i was 100miles from you i would. Thank's
