fla 9 Posted September 8, 2013 I have directional tyres on the rear but on a roundabout recently the back end felt a bit 'slippery', as though it wanted to step out a bit. Perhaps being directional being the cause of this? Only on the back as they don't rub the front of the wheel arch (waiting for the rear axle plates group-buy!) Toyo Proxes T1-R btw. Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 8, 2013 I thought all tyres were directional? Its to direct water out when moving forward. If you look at the tread pattern on the T1R its a kind of V shape. If they were on the wrong way round then when you were moving forward, it would draw the water inward. Quote Share this post Link to post Share on other sites
st4stokie 10 Posted September 8, 2013 As long as you've got the tyres fitted in the right direction of travel you shouldn't have a problem. If they are running in the wrong direction then you'll get problems. should be an arrow on the wall of the tyre to tell you which direction the are supposed to be travelling in. Quote Share this post Link to post Share on other sites
chaos3oe 0 Posted September 8, 2013 It would only make a difference if it was wet, and they were the wrong way around. You shouldn't mix across an axle, but different front to rear should be ok, really want 4 matching though. Whats on the front btw. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted September 8, 2013 How good are your rear beam bushes? Mine felt ok on islands/bends in the dry but would let go easily in the wet, I had them replaced and now feels like its on rails whatever the conditions Quote Share this post Link to post Share on other sites
fla 9 Posted September 9, 2013 stuarttaylor37 said: How good are your rear beam bushes? Mine felt ok on islands/bends in the dry but would let go easily in the wet, I had them replaced and now feels like its on rails whatever the conditions Good point - i've not replaced them as yet so perhaps this is the route to go down. Apparently Poly bushes improve the rear end without having the 'wobbly axle' syndrome of the 'passive rear steering'. anyone with comparative experience? I bought some bushes a while back from AVS, so might try and fit them soonish. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted September 9, 2013 I went for standard bushes on Midland Vw's recommendation as they reckon the poly bushes are harsh and can cause the rear end to be skittish. I've got no personal experience of polys though. I like the feel of the rear now its been refurbed, gives a sharper but more predictable turn in.....just what you need on the way to Asda. Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 9, 2013 I think TT or R32 bushes are the recommended route for rear beam now? More positive than standard yet not as harsh as Poly. Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted September 9, 2013 seanl82 said: I think TT or R32 bushes are the recommended route for rear beam now? More positive than standard yet not as harsh as Poly. I think, you're thinking of the wishbone bushes... Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 9, 2013 Are they directional on the front ? Are the rears slightly wider/larger then the front ? Quote Share this post Link to post Share on other sites
fla 9 Posted September 10, 2013 Dragon - no. Standards on the front (Westlake) which have a squarer shoulder than the Toyos, so could be considered as being slightly wider. In fact that's why I swopped them to the front as they were scrubbing the front of the rear arch (pass side only). Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 10, 2013 I've always had 4 matching tyres on mine,a couple of directional sets,no bother, About a month ago,I had to put two new tyres on the rear,different to the front.Mine now feels like yours ! The word skittish comes to mind.My rear beam bushes were changed last year with genuine VW parts, I'm sure it's just having different tyres,I will be needing the fronts changed soon,they will be the same as the rears. Hope this helps a little Quote Share this post Link to post Share on other sites
fla 9 Posted September 10, 2013 much appreciated. I'll try swopping them back to the front once the rear axle plates are available, but also try replacing a pair to Toyos. Skittish - absolutely spot on as to how my car feels right now in the wet! Quote Share this post Link to post Share on other sites
