willmason1975
My vr6 project. Picture heavy
[ATTACH=CONFIG]75707[/ATTACH][ATTACH=CONFIG]75708[/ATTACH][ATTACH=CONFIG]75709[/ATTACH][ATTACH=CONFIG]75710[/ATTACH][ATTACH=CONFIG]75711[/ATTACH][ATTACH=CONFIG]75712[/ATTACH][ATTACH=CONFIG]75713[/ATTACH][ATTACH=CONFIG]75714[/ATTACH][ATTACH=CONFIG]75715[/ATTACH][ATTACH=CONFIG]75716[/ATTACH][ATTACH=CONFIG]75717[/ATTACH][ATTACH=CONFIG]75718[/ATTACH][ATTACH=CONFIG]75719[/ATTACH][ATTACH=CONFIG]75720[/ATTACH][ATTACH=CONFIG]75721[/ATTACH][ATTACH=CONFIG]75722[/ATTACH][ATTACH=CONFIG]75723[/ATTACH][ATTACH=CONFIG]75724[/ATTACH][ATTACH=CONFIG]75725[/ATTACH][ATTACH=CONFIG]75726[/ATTACH][ATTACH=CONFIG]75727[/ATTACH][ATTACH=CONFIG]75728[/ATTACH][ATTACH=CONFIG]75729[/ATTACH][ATTACH=CONFIG]75730[/ATTACH]
Ive got a lot further on since my last post on the car but the pics Ive taken are too high res to post up Ive put them on flickr but dont know how to get them on here!
[ATTACH=CONFIG]76317[/ATTACH][ATTACH=CONFIG]76318[/ATTACH][ATTACH=CONFIG]76319[/ATTACH][ATTACH=CONFIG]76320[/ATTACH][ATTACH=CONFIG]76321[/ATTACH][ATTACH=CONFIG]76322[/ATTACH][ATTACH=CONFIG]76323[/ATTACH]
Quarter panel sorted on drivers side.
[ATTACH=CONFIG]76324[/ATTACH]
Down both sides of windscreen were rotted I made new pieces to go in but cant find photos
[ATTACH=CONFIG]76325[/ATTACH]
Before
[ATTACH=CONFIG]76326[/ATTACH]
After
[ATTACH=CONFIG]76327[/ATTACH]
Old side repeater holes welded up and early mk3 golf/ passat side repeaters welded in.
[ATTACH=CONFIG]76328[/ATTACH]
Deseamed rear end and lost the corrado badge.
[ATTACH=CONFIG]76329[/ATTACH]
Home made grille
[ATTACH=CONFIG]76330[/ATTACH][ATTACH=CONFIG]76331[/ATTACH][ATTACH=CONFIG]76332[/ATTACH]
Rear arches and back panel etch primed and factory undersealed.
Edited by willmason1975
[ATTACH=CONFIG]76333[/ATTACH][ATTACH=CONFIG]76334[/ATTACH][ATTACH=CONFIG]76335[/ATTACH][ATTACH=CONFIG]76336[/ATTACH][ATTACH=CONFIG]76337[/ATTACH][ATTACH=CONFIG]76337[/ATTACH]
All prepared for primer
[ATTACH=CONFIG]76338[/ATTACH][ATTACH=CONFIG]76339[/ATTACH][ATTACH=CONFIG]76340[/ATTACH][ATTACH=CONFIG]76341[/ATTACH][ATTACH=CONFIG]76342[/ATTACH][ATTACH=CONFIG]76342[/ATTACH]
Primed
[ATTACH=CONFIG]76343[/ATTACH]
The new colour or should I say the original colour!
[ATTACH=CONFIG]76344[/ATTACH][ATTACH=CONFIG]76345[/ATTACH][ATTACH=CONFIG]76346[/ATTACH][ATTACH=CONFIG]76347[/ATTACH][ATTACH=CONFIG]76348[/ATTACH][ATTACH=CONFIG]76349[/ATTACH][ATTACH=CONFIG]76350[/ATTACH]
All painted and
[ATTACH=CONFIG]76352[/ATTACH][ATTACH=CONFIG]76351[/ATTACH][ATTACH=CONFIG]76353[/ATTACH]
Buffed up
[ATTACH=CONFIG]76354[/ATTACH]
288mm brake conversion with new goodridge hoses and mk4 rear calipers and new discs and pads on back. New wheel bearings all round new hubs on front with all new bushes and ball joints,track rod ends ect.
[ATTACH=CONFIG]76356[/ATTACH]
Quick fit up on front end to see what its going to look like.
[ATTACH=CONFIG]76355[/ATTACH]
Cheap projector headlights from bulgaria but it shows. Split them apart and painted them black.
Fair play, unrecognisable from where you started.
I take it your a pro painter?
Fair play mate. Top turn around. Nice to see the effort being put in rather than taking it to the scrappy :)
Well the project has come to a grinding halt! Ive tried to plug the fuse box back in and it will turn over but wont start. I dont know enough about wiring to go any further. Theres no fuel pump kicking in. I cant even tell if the immobiliser is working VAG-COM isnt connecting to anything so I will have to get an auto spark to have a look.
Got to take my hat off to you mate that is an amazing transformation from what it looked like at the start. Have you checked all the relays on the fuse box? Could be fuel pump relay not working
Yeah I'm not too sure on wiring at all I may have even damaged something putting it all back. I've checked fuses but don't know how to check relays I've swapped fuel pump relay with a known working one but the more I do the less things work so gonna leave this one to the pros I think! I've done a 1z conversion into a t4 and that was simple because everything was already connected and running in donor so only had to transfer things over. I don't even know if there's anything missing or if the ecu works on this because it was a non runner when I got it
Those pictures of it being painted were in an old WW2 ammunition bunker. My son thinks it's funny how I resurrected a German car in a British war bunker made to destroy germany!
