carrots 1 Posted November 24, 2014 (edited) got in the car this morning and noticed my fuel gauge and mfa dont work.not sure if anything else doesnt work.does it sound like a fuse cheers Edited November 27, 2014 by carrots Quote Share this post Link to post Share on other sites
carrots 1 Posted November 25, 2014 anyone??????? i might look to see if ive got a blown fuse if the rain stops soon Quote Share this post Link to post Share on other sites
carrots 1 Posted November 25, 2014 (edited) Just been in it,no fuel gauge,temp gauge,rev counter,handbrake light,indicators light on dash.no maf but it's got dash lights.checked fuses they seem fine.no ignition lights spoiler doesn't work aswell Edited November 25, 2014 by carrots Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted November 25, 2014 You have a bad earth somewhere. Sorry I can elaborate any more than that. Start with the earth's in the engine bay and go from there. Quote Share this post Link to post Share on other sites
carrots 1 Posted November 25, 2014 Ok cheers I was thinking could be a wire on battery maybe.have to check in day light Quote Share this post Link to post Share on other sites
carrots 1 Posted November 27, 2014 heater motor,fog lights and wipers also stopped working tonight Quote Share this post Link to post Share on other sites
carrots 1 Posted November 27, 2014 any ideas were to start,were are the earths.cheers i need to fix it sat Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 27, 2014 Follow your battery earth down. Theres a little post just to the back left of the battery. I'd start with that one. Also starter motor, and the right hand side of the block as you're looking at it. Remove them all, wire brush with some WD40 both the cables and the earth points, wipe them down and re-attach. Internally the main one is just behind the drivers side vent behind the dash. Shouldn't be any problems really with that unless you've been tinkering with your wiring. There are a few others in various locations, but those are the main ones I think. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 28, 2014 This reminds me I mlst check mine. Quote Share this post Link to post Share on other sites
carrots 1 Posted November 29, 2014 just checked the earths and fuses,number 16 had blown and blows as soon as i change it and put ignition on Quote Share this post Link to post Share on other sites
Dox 23 Posted November 29, 2014 (edited) You have a short somewhere or a seized motor overloading the circuit blowing the fuse. I'd unplug the motors on that fuse Replace the fuse ignition on, what happens? Wiring into the hatch could also be broken and touching the body work? Have you done any electrical work to the car recently? - re-trace your steps, even replacing rear light bulbs can give allsorts of weird electrical gremlins if they're not correctly installed (stop / tail bulbs especially) There will be a collection of earths near the fusebox, make sure they're clean and secure too Edited November 29, 2014 by Dox Quote Share this post Link to post Share on other sites
carrots 1 Posted November 30, 2014 Found it.I pulled the glove box wires and the fuse didn't blow after .taken the glove box out but couldn't see any breaks in the wires it must be behind stereo or further along Quote Share this post Link to post Share on other sites
Dox 23 Posted November 30, 2014 Its sounds like a fire in the making, I'd disconnect the battery and investigate further if it was mine. Quote Share this post Link to post Share on other sites
carrots 1 Posted November 30, 2014 yer think i will take dash apart next sat and check the wires Quote Share this post Link to post Share on other sites
