Purple Tom
Breaking - 1994 Dragon Green VR6
Very specific one - would you have the centre of the gear knob? the little disc with the numbers on it? Understand if you don't want to sell separately (I have a good leather gearknob but the disc is lost you see)
Mr frog, try trimsport if no luck here, they do disks for their alloy gear knobs. Not sure if they are exactly the same size as a standard one but always worth an ask.
Ben.
Nope I'm afraid not, sold my last rocker cover a few weeks ago.
Tom
Thanks for letting me know. I am still interested if you get to know of one being available.
No dipstick tube, or ABS pump, but I do have a decent selection of water hoses.
What do you need Karmannski?
Do you have a 280mm passenger side brake calliper? Should be stamped with "54" thanks
Just away on holiday at the moment so only just noticed these updates - I'm back later this week so will reply fully then!
Thanks
Tom
Hi there, do you have a complete working sunroof? Mine is busted. Also looking for the elusive VSR / shrick inlet, fat chance huh?
Right:
Perksy - I do have a fair amount of wiring - ABS loom, fan loom and various other stuff - what do you need?
Hofmeister - I do have a pair of those calipers but they're not in usable condition unfortunately.
GBH - No resistors I'm afraid.
Laywer6 - no sunroof or Schrick either - have you tried an early mk1 Octavia?
Thanks
Tom
Thank you Tom. I have the center console with rotary controls for the A/C etc but the ashtray is broken. Would you have a full set?
Sorry, I meant if possible Id like to replace the entire console including the ashtray but if that is not feasible then Id just have a go at replacing just the ashtray
Ah right. Yeah unfortunately the centre consoles are a pretty rare commodity now which I don't have. I'm pretty certain I have a couple of ashtrays though, do you need both the ashtray insert and the ashtray holder?
Thanks
Tom
Hi Tom, do yo have the nearside front window seal? Also looking for number plate bulb holders and surround
