pettsy
Breaking - Dragon Green 2.0 16v
Have now pretty much stripped the car to a bare shell. Along the way a few bodges have been uncovered and lots of annoying bits broken or damaged sadly. Ive updated the list below to reflect the items I have available.
Parts available
Front bumper irons
Tailgate (some scratches but rust free)
Rear bumper (scuff on corner)
Grey roof lining
Black door cards
Black carpet
Black dash inc glovebox
Black boot carpet
Black side boot carpets
Exhaust heat shields
Rear axle
Power steering setup
Drivers black a pillar trim
Driver and pass black b pillar trim
Driver and pass black c pillar trim
Cross trim at top of tailgate in black
Front hubs
Servo and abs switch
Abs pump
Abs wiring and ecu
Centre tunnel console in black
Roof gutter trims
Front subframe
Front lower crossmember
Wings (passengers scratched but rust free, drivers has bit of surface rust at bottom)
Doors (few dings and scrapes but cheap if any use?)
Bonnet
Distributor
Inlet manifold
Metering head
Fuel pumps
Fuel lines
Ecu
Starter motor
Late spec clocks
Tailgate seal
Passenger door seal
15" space saver
14" space saver
Abf bottom end
9a head
Driveshafts
Gearbox
Selector cables
Front arch liners
Wiper/ind stalks
Black parcel shelf
Black parcel shelf supports
Unknown lowered shocks and springs
Sunroof panel inc motor
Lower dashboard cubby box
Pedal box and hydraulic clutch system
Door glass
Inner door handles (drivers with mirror switch)
Will update as I find more bits
Located near Matlock in Derbyshire. Collection of parts preferred but can post smaller items.
Matt 07944 884008
Edited by pettsy
Hi. Does the sunroof work properly? If so please let me know how much you want for it.
Cheers
Sorry for Lack of updates, haven't had chance to strip as much of car as I would have liked. As the car is an early one with some later interior parts fitted ( and broken in the process!) I need to see which bits are useable.
Hi mate is the black parcel shelf available? If so now much would you want including postage to Southampton?
Yes but not keen on posting due to damage risk.
Do you have the engine loom and ecu ?
Yes, both available
Have you got a horn?
Think it got scrapped with the shell,sorry
Late set of clocks - mileage? red needles? MFA hose on back? Cost?
Unknown mileage,pretty sure needles are red. Will get pics this weekend.
Hi Mate
how much for the tailgate and is the spoiler still working?
Looking for £25 for tailgate, not sure if spoiler worked but can try and test it
