easypops 8 Posted October 15, 2015 Just on the off chance that anyone has these lying about new and unused as I plan to order them soon. All brake pipe clips for rear beam and underside. Any of the associated nuts/bolts needed for the underside Cheers :) Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted October 15, 2015 I have bud but not new ones sorry Quote Share this post Link to post Share on other sites
easypops 8 Posted October 15, 2015 lilfuzzer said: I have bud but not new ones sorry I knew you would mate, it's a bit of a long shot but you never know I might get lucky Thanks though :) Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 16, 2015 I've got a bag of new rear beam clips, think there's only about 4 though, just need to lay my hands on them. Quote Share this post Link to post Share on other sites
easypops 8 Posted October 16, 2015 Great Dave, fairly sure there is only 4 on the beam itself :) Quote Share this post Link to post Share on other sites
ChrisL 20 Posted October 16, 2015 If its the white clips for the brake pipes, beware there are 2 types dependant on the age of the car. Quote Share this post Link to post Share on other sites
easypops 8 Posted October 16, 2015 Is it just the beam ones that differ mate, or is is also the ones that run along the underside? I've a powdercoated beam I got from Goldie, which was tied to the red VR he had, so that's a late one for sure....... I can cobble together more than I need from what I have but I'd like them new so I can forget about them for a while :) Quote Share this post Link to post Share on other sites
science 0 Posted October 16, 2015 I've been meaning to buy these for a while, not sure if these are what you're after: http://www.ebay.co.uk/itm/Genuine-New-Vw-BRAKE-LINE-HOSE-PIPE-DOUBLE-CLIP-SET-OF-5-Golf-Mk2-Corrado-Polo-/161329274751?roken=cUgayN via @eBay_UK Quote Share this post Link to post Share on other sites
ChrisL 20 Posted October 16, 2015 Those are the clips that run under the car that hold the rigid brake lines. Its just the beam ones that differ. A later beam has screwed studs for the clips where the earlier cars have smooth studs (they are in different positions too). Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 16, 2015 I have these..... Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 16, 2015 I think these are the ones I bought for my beam . I would check but I think they are boxed and buried with all the other parts ! Quote Share this post Link to post Share on other sites
ChrisL 20 Posted October 16, 2015 daves16v said: I have these..... These are for an early beam Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 16, 2015 ChrisL said: These are for an early beam Fitted these to my 94 beam. Quote Share this post Link to post Share on other sites
science 0 Posted October 16, 2015 ChrisL said: Those are the clips that run under the car that hold the rigid brake lines. Its just the beam ones that differ. A later beam has screwed studs for the clips where the earlier cars have smooth studs (they are in different positions too). That's right, thanks! Had a brain fart and posted the wrong link. Try again; http://www.ebay.co.uk/itm/Genuine-New-Vw-REAR-AXLE-BRAKE-LINE-PIPE-CLIPS-SET-OF-5-Golf-Mk2-Corrado-Polo-/161329253041?hash=item258ff90ab1:m:mGr0QSI1wCu_qas-mZyoXew Didn't realise there are two types, do you know what year they changed over? Quote Share this post Link to post Share on other sites
ChrisL 20 Posted October 16, 2015 Not sure what year they changed over but both my 95 vr's had the screw type pins on the beam and the plastic clips are different to those on your link and Daves picture. Earlier beams had pins that are like upside down top hats and the clips slide on. You can see how this would work with the picture Quote Share this post Link to post Share on other sites
