karmannski
KARMANNSKI roof trims mouldings re-pro
Ideally yes, but saying that mine are not taped and never came off while driving
Wysłane z iPhone za pomocą Tapatalk
Taped mine with a 3M acrylic foam tape. Worked great, practice fitting them before using the tape imo
I'll have a set too please
I would like a set also please
cheers
Alex
Sure, will let u all know here once in
Hi mate do they come with end trims
Yes they are. And they will be on shelf by end of this month.
I'd like a set too please if you could let me know
cheers
Kip
Sure
At last got around to starting to fit the trim, bonded two front clips to the new trim will let them cure then the other end.
Hi,
I'm interested in the trims and clips set.
Will you ship to Vancouver, Canada?
They look fantastic!
Robert
Are these still available? My trims are bit corroded :D
Sent from my iPad using Tapatalk Pro
Hi are these still available.
Yes I believe they are still.
You possibly have two options:
1) is to try and get in touch with KARMANNSKI who started this thread, he might have some roof trims left ?
From what I've seen and heard from other Forum members, his remade trims are good quality.
2) is to contact VW Heritage as they stock some items for the Corrado, or they can ship them over from Germany from VW Classic Parts.
Think they are roughly £150 per side from Heritage = these are OEM that VW Classic Parts remanufactured using the original tooling back in 2017 I think.
Si
