John Blount 11 Posted March 27, 2016 Just thought the following might be useful to anyone who is thinking of doing the head light wiring upgrade to improve the poor head lamp brightness. There are loads of kits out there to do this but I've found one from Rayne automotive which is really good. There's no cutting of any of the cars wiring as the headlamp plugs on each side plug directly into the supplied wiring harness and then back into the back of each respective headlamp leaving just the positive and the negative to connect direct to the battery. Really easy to do and if ever it requires changing back to original you just un-plug the wiring harness and plug the original plugs back into the head lamps. Rayne automotive sell them on e-bay or you can buy direct http://www.rayneautomotive.co.uk I brought the wiring harness and headlamp kit which included two H4 Osram night breaker plus lamps for around £50 and the difference is amazing. Just need to buy some H4's now though to match up the side lights. Quote Share this post Link to post Share on other sites
Hisnibs 10 Posted March 27, 2016 From my experience this set-up can't handle the nightbreakers - the inline fuse will pop on full beam. That 3rd relay is sorely needed. Quote Share this post Link to post Share on other sites
Dox 23 Posted March 27, 2016 I have the rayne loom with phillips vision h4s and h7s (dip / main and spots) no issues to report 100% worth the money. Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 27, 2016 Me too, have a look in suppliers forum as they do forum discount. Only thing I've found it that the battery neg cable is about 2" too short, but that's solely due to where I've routed it. It's all soldered joints too, and as an weapons engineer I can't fault the quality. I'd definitely recommend them! Quote Share this post Link to post Share on other sites
easypops 8 Posted March 27, 2016 I've also got one, not fitted yet but as above the quality of work looks very good. I'll be more than happy to fit it :) Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted March 27, 2016 Just thought the following might be useful to anyone who is thinking of doing the head light wiring upgrade to improve the poor head lamp brightness. There are loads of kits out there to do this but I've found one from Rayne automotive which is really good. There's no cutting of any of the cars wiring as the headlamp plugs on each side plug directly into the supplied wiring harness and then back into the back of each respective headlamp leaving just the positive and the negative to connect direct to the battery. Really easy to do and if ever it requires changing back to original you just un-plug the wiring harness and plug the original plugs back into the head lamps. Rayne automotive sell them on e-bay or you can buy direct http://www.rayneautomotive.co.uk I brought the wiring harness and headlamp kit which included two H4 Osram night breaker plus lamps for around £50 and the difference is amazing. Just need to buy some H4's now though to match up the side lights. Pm me i have a set of H4's new and sealed here as i bought too many by accident. Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 27, 2016 They do the heated seat loom i need aswell. still need to find a swtich tho! Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted March 27, 2016 I have one on my VR fitted with Nightbreakers and the 15amp inline would blow within 10/15 minutes, changed to 20 amp two years ago and no issues since. It's a well made loom and simple to fit Quote Share this post Link to post Share on other sites
John Blount 11 Posted March 27, 2016 Pm me i have a set of H4's new and sealed here as i bought too many by accident. Thanks mate but I've already brought some today... Quote Share this post Link to post Share on other sites
Mystic Blue VR 10 Posted March 28, 2016 I've got a Rayne Automotive loom kit fitted with Nightbreakers too. I thought the quality looked spot on. Interesting about the 15amp fuse blowing. Going to change mine to 20amp too to be on the safe side. Quote Share this post Link to post Share on other sites
John Blount 11 Posted March 28, 2016 I've got a Rayne Automotive loom kit fitted with Nightbreakers too. I thought the quality looked spot on. Interesting about the 15amp fuse blowing. Going to change mine to 20amp too to be on the safe side. The loom I've got is fitted from 20 amp fuses so I suspect Rayne have upgraded them.. Quote Share this post Link to post Share on other sites
Mystic Blue VR 10 Posted March 29, 2016 Checked mine yesterday. 20 amp in one & 15 amp in the other. Both have 20 amp fuses in now, presume that is OK? Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted August 24, 2017 Just ordered one of these. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted August 24, 2017 Just ordered one of these. blimey - i thought they had stopped selling them / trading careful with it Ron - they used to only be 2 relay versions, as such if the one which works the normal dipped beam fails you will not have any lights except full beam (which obviously you cant really drive with) rather than a 3 relay version, such as the KUR2Y ones, which allow side lights to still work if the dipped beam relay fails Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 24, 2017 Few peeps have had problems with the 2 relay looms... kurzy made mine but I got the OEM connectors from rayneautomotive Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted August 24, 2017 Few peeps have had problems with the 2 relay looms... kurzy made mine but I got the OEM connectors from rayneautomotive that was what prompted my post to ron too m8 Quote Share this post Link to post Share on other sites
annavr6 10 Posted August 24, 2017 We do one of these at heritage https://www.vwheritage.com/wc941w000-headlight-wiring-loom-upgrade-mk1-2-golf in fact we have just improved ours making the wiring and joins better. It does have 15amp fuses though although if people say its better we could swap to 20amp no problem. Ive had no reports of them blowing so far. Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 24, 2017 It's the OEM plugs that make all the difference. Mine even has a male headlight socket on the loom for the control inputs from the car loom - you simply plug the battery side headlight connector in. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted September 7, 2017 Mine has arrived from Rayne just need to fit it. Quote Share this post Link to post Share on other sites
VR6appeal 10 Posted September 10, 2017 I fitted mine yesterday and it certainly makes an appreciable difference. Mine also has one 20 and one 15 amp fuse (I assume that's for the different length runs for each light, not sure if that's a fair assumption). Quote Share this post Link to post Share on other sites
