Will.I.Dub
What's this inside my door?
Inside the rear of the drivers door at the bottom
And the cable from it, any ideas?
Sent from my D5803 using Tapatalk
Edited by Will.I.Dub
Hmm. . I'll hopefully get my other door off in a couple of days so will have a look. Unless someone else can help b4 then
Sent from my SM-G900F using Tapatalk
Thanks! I should know but I've gone blank
Connector for the locking actuator? I can't remember either which I should, I've had the door card off enough times!
I don't recognise that, the vacuum actuator is further up and the rod connecting it to the rest of the lock mechanism is obvious. Maybe an aftermarket alarm actuator for central locking?
The wires don't look original to me, The only thing i can think of that looks a bit like that is the connector to the electric mirrors.
It's looks to be an electrically operated central locking actuator. It could be that this was an ill informed repair to a fault in the CDL system, instead of repairing the vacuum OEM system. I have seen people fit aftermarket CDL systems because they thought that the Corrado did not have it as stock, and other times where these actuators have been fitted to allow a remote locking alarm fob to operate the locking system.
Thanks all, Tigerfish and John you hit the nail on the head
Part of a dysfunctional alarm immobiliser with a horrible keypad fitted sometime in the cars history
