carrots
servis washing machine fault
tried that.i thought it might be the interlock so bought a 2nd hand one and its still the same.its like it doesent think the doors shut
Does it have any error codes displayed?
No its very basic.if I turn the nob to a program and press the start button.the door should lock but it doesn't so after s few seconds the start button starts flashing as if the program has finished
Are the flashes a fault cod? ie 3 flashes, 2 flashes (32)
Usual faults for washing machine as brushes as mentioned (won't spin at high speed in the first instance) water pump or its controllers - the water needs to be out before spinning, there's sometime a crude sensor (a plastic bottle affair) that fills with soap powder making the washer think there's water inside the drum so no spin cycle.
EDIT
http://www.whitegoodshelp.co.uk/troubleshooting-washing-machine-faults/
Edited by Dox
Have you tried connecting VAGCOM?
could be the turbo.
on a serious note I always check the motor brushes first.... cheap and easy to fix....
Edited by delfinis38
The washing machine is now 100% dead.ive bought a new one and kept the drum out of the old one its going to be a fire pit
Great use of the drum. They really do make a great burning bin.
Sent from my SM-G900F using Tapatalk
i saw a cracking BBQ made from an old washing machine or dishwasher a couple of years ago - made to spit roast a whole lamb
i have just sourced a 55 gallon steel drum to try to convert into one
