BarryNL 10 Posted August 31, 2018 I revised the engine, gearbox and subframe of my Corrado VR6. Everything is back in place. I marked allmost all my bolts recept these two identical ones. I have no idea where to put them. Any ideas? The bolts are 50mm long metric8 about 2 centimeters is unthreaded Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted September 25, 2018 Engine mounts? Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 25, 2018 Are they bumper bracket to subframe bolts? Quote Share this post Link to post Share on other sites
BarryNL 10 Posted September 25, 2018 @fendervg hits the jackpot! Forgot that there are three bolts per side instead of two :-) Quote Share this post Link to post Share on other sites
fla 9 Posted September 25, 2018 cross member centre bolts? Quote Share this post Link to post Share on other sites
GrahamV 10 Posted September 25, 2018 (edited) VR6 photo [attach=config]95182[/attach] others [attach=config]95183[/attach] Steer rack parts photo [ATTACH=CONFIG]95184[/ATTACH] Hope this helps Edited September 25, 2018 by GrahamV Quote Share this post Link to post Share on other sites
tonedef 10 Posted September 25, 2018 M8 x 50, I’m guessing as I’m away from home and my paperwork but I’d say they’re the steering rack bolts. I’ve had the rack out loads of times recently and hate those bolts!!! Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 25, 2018 What size are the heads ?. Surely there must be something that’s not held in place ?. Quote Share this post Link to post Share on other sites
tonedef 10 Posted September 25, 2018 tonedef said: M8 x 50, I’m guessing as I’m away from home and my paperwork but I’d say they’re the steering rack bolts. I’ve had the rack out loads of times recently and hate those bolts!!! Now that I've taken a better look i.e. not on my phone, they look more like the secondary front crossmember bolts, item number 6 on the VR6 Photo posted by GrahamV above. That has two M8 bolts and four M10 bolts, the M8s hold the crossmember in place when the bumper is removed but the M10s secure it and also fix the front bumper brackets in place. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 26, 2018 I agree with the above. Should be 3 bolts into the cross member that holds the engine mount on each end, 2 big ones hold it all together inc. bumper the one keeps the member in place when just removing the bumper. Quote Share this post Link to post Share on other sites
