petemcr 10 Posted January 19, 2019 Might be a long shot but does anyone have a VR6 ISV that they know works knocking around they would be willing to sell. I am looking at getting a new one at some stage but I just want to test the ISV is failing at this position my before I shell out for a new one, or if anyone knows a good way to test the current one, I have VAG Com and I'm sure there's a way to manually open the ISV using it but can't remember where the option is Cheers Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 19, 2019 I have an ISV I can send you . Quote Share this post Link to post Share on other sites
petemcr 10 Posted January 19, 2019 robrado974 said: I have an ISV I can send you . Awesome, life saver How much do you want fella? Quote Share this post Link to post Share on other sites
fla 9 Posted January 19, 2019 You an also operate the isv manually by applying 12v directly to.the two spade connectors. You'll feel the isv buzz and the flap will (should)open fully. It will then close fully on removal of the power source. Quote Share this post Link to post Share on other sites
Keyo 47 Posted January 19, 2019 Anyone had a punt of one of these cheap ones off ebay . https://www.ebay.co.uk/itm/FOR-VOLKSWAGEN-CORRADO-2-9-VR6-PETROL-1992-1995-IDLE-AIR-CONTROL-VALVE/121863374042?hash=item1c5f9f84da:g:j0QAAOSwYIhWlNyY:rk:1:pf:0 Quote Share this post Link to post Share on other sites
petemcr 10 Posted January 19, 2019 Think they were the ones I was debating getting if it does turn out to be the ISV, worth a shot I reckon Quote Share this post Link to post Share on other sites
petemcr 10 Posted January 19, 2019 fla said: You an also operate the isv manually by applying 12v directly to.the two spade connectors. You'll feel the isv buzz and the flap will (should)open fully. It will then close fully on removal of the power source. Will this show it's working correctly? I thought they could still stick even if they can open fully Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 19, 2019 Yeah I bought one. The symptoms were worse than my original so I sent it back for a replacement, but the replacement was almost as bad. I ended up just cutting my losses and bought a known good second hand one. Quote Share this post Link to post Share on other sites
Keyo 47 Posted January 19, 2019 Ill make sure ill never buy one them then thanks for sharing ! There is an intermoto one for £200 and something not sure Ive heard of the brand though . What are peoples thought of the JP Group Danish outfit , I have purchased a Mass sensor a while back with no issues and today purchased a starter motor manafacturd by them . Quote Share this post Link to post Share on other sites
fla 9 Posted January 19, 2019 petemcr said: Will this show it's working correctly? I thought they could still stick even if they can open fully It coukd stick if the flap is not well or properly lubricated using a light oil. You can also move it by hand to check the operation is smooth. Quote Share this post Link to post Share on other sites
petemcr 10 Posted January 19, 2019 Good to know the eBay ones aren't worth getting, I was debating them but at least they're known to be no good, back to the drawing board. Will need to test the one that's on now but I'm pretty sure its no good, replaced it with a used one a while back and it's been stood for some time Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 19, 2019 I know some have used them and they've worked (which is why I tried it), but unfortunately not for me! Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 19, 2019 petemcr said: Awesome, life saver How much do you want fella? Call it a tenner plus pnp . If you still need it pm me your details and I will send it to you . Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 20, 2019 I got an ebay one and it sorted my idle out and has been good for a few years now Quote Share this post Link to post Share on other sites
Keyo 47 Posted January 20, 2019 This one might be a bit better quality as cost in the fifties(make an offer) and a 4 year guarantee descirbed as heavy duty , never heard of the brand though but manufactured in Germany . https://www.ebay.co.uk/itm/GENUINE-SKV-GERMANY-HEAVY-DUTY-AIR-SUPPLY-IDLE-CONTROL-VALVE-VW-AUDI/263976793113?epid=24016566482&hash=item3d763e3419:g:4a8AAOSwt6NbuKYn:rk:8:pf:0 Also can still get a Bosch one brand new but at a cost ha. https://www.arz-tuning.de/shop/en/Idle-Stabilizer-Valve-ISV-VW-VR6-Corrado-Golf-III-Passat-Vento/Jetta Quote Share this post Link to post Share on other sites
Keyo 47 Posted January 20, 2019 Early VR6 dont have the PVC Valve I beleive maybe they dont work as well these fitted god knows. Quote Share this post Link to post Share on other sites
petemcr 10 Posted January 20, 2019 Not sure if the ISV is used straight away or if it goes off once fast idle goes off but I just started it with the pipe off that had the valve opening behind and there was no movement from it, which I guess means it's definitely had its day Quote Share this post Link to post Share on other sites
