Keyo 49 Posted July 16, 2019 I might have some good news with a replacement evaporator. Today I took the old unit to a manufacturer who is 3 miles from me... Unbelievable. He said they are going to 3D image it and get back to me. And he sees no reason why they wouldn't be able to do it. So, fingers crossed and hopefully a sensible cost. I will keep this thread updated Good luck with this. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted July 17, 2019 Wish you well with it matey, I know it’s been an ordeal getting it sorted. Fingers crossed you’ve found the man that can. Quote Share this post Link to post Share on other sites
Jayceer 10 Posted July 27, 2019 Looks like the engine pipe work for mine will need replacing, has anyone any idea on where I could source these pipes? Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 27, 2019 Looks like the engine pipe work for mine will need replacing, has anyone any idea on where I could source these pipes? Assuming you have the Diavia system installed, just take them off and to a hose manufacturer. Lots around just Google hydraulic hose replacement, They do any hose and fitting. If everything else is ok has your evaporator/drier been replaced lately? This sits behind the front grille in front of the condenser. Well worth a replacement as the part is less than 30 pounds Quote Share this post Link to post Share on other sites
Jayceer 10 Posted July 27, 2019 Assuming you have the Diavia system installed, just take them off and to a hose manufacturer. Lots around just Google hydraulic hose replacement, They do any hose and fitting. If everything else is ok has your evaporator/drier been replaced lately? This sits behind the front grille in front of the condenser. Well worth a replacement as the part is less than 30 pounds Cheers for that, I’ll give that a whirl, it is a Diavia system, yes replacing the drier too. Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 27, 2019 (edited) Managed to source a new one mate, it’s the make Sanden model 7830 if anyone has a similar preference in the future Where did you get the compressor from Jayceer? Edited July 27, 2019 by Cressa Spelling Quote Share this post Link to post Share on other sites
fla 9 Posted July 28, 2019 Is there any major difference in the various compressors? I've got a spare Sanden which i might try and refurb (if it needs it. Cant be too difficult surely?? Famous last words...) Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 28, 2019 Is there any major difference in the various compressors? I've got a spare Sanden which i might try and refurb (if it needs it. Cant be too difficult surely?? Famous last words...) I had a quick look into this and read that some are direct and some are indirect... worth comparing product numbers first. I have one here off the car Quote Share this post Link to post Share on other sites
Jayceer 10 Posted July 29, 2019 Where did you get the compressor from Jayceer? Readily available from Germany on UK eBay, I got another sanden Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 1, 2019 Will remove the front bumper at the weekend.. I've got a few thought but what's the best way to support the engine with the bumper off... need to have a good look at the weekend really. Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 2, 2019 I used a trolley Jack with a block of wood. Left it there for months and was fine supporting it as only the front mount is removed. Good luck with it. I did try replying off my phone yesterday, but only got that stupid error coming up!! Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 28, 2019 Jobs to do while the front bumper is off... I’ve changed all the air co pipes and seals... new receiver drier... condenser and compressor look okay. Any maintenance needed on the compressor apart from new belt.. Where’s the evaporator in the passenger foot well ... not looked yet. Any thing else need doing before recharge. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 28, 2019 I used a trolley Jack with a block of wood. Left it there for months and was fine supporting it as only the front mount is removed. Good luck with it. I did try replying off my phone yesterday, but only got that stupid error coming up!! Founds some nuts. So put the bumper bolts back in, to support the engine while the bumper is out Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 28, 2019 Jobs to do while the front bumper is off... I’ve changed all the air co pipes and seals... new receiver drier... condenser and compressor look okay. Any maintenance needed on the compressor apart from new belt.. Where’s the evaporator in the passenger foot well ... not looked yet. Any thing else need doing before recharge. The evaporator is behind the glovebox and bolted through the air vent. On removing the complete unit it was an absolute pain to split. I wouldn't recommend doing it unless you have a problem with the evaporator. I still haven't sourced a replacement yet.. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 29, 2019 (edited) The evaporator is behind the glovebox and bolted through the air vent. On removing the complete unit it was an absolute pain to split. I wouldn't recommend doing it unless you have a problem with the evaporator. I still haven't sourced a replacement yet.. Is this a good replacement part for the condenser https://www.autoairconparts.co.uk/universal-condenser-aftermarket-part-ssp022301.html Just sheared the lower connection off mine. Part number cross references, just wondering on quality. Edited August 29, 2019 by delfinis38 Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 29, 2019 Is this a good replacement part for the condenser https://www.autoairconparts.co.uk/universal-condenser-aftermarket-part-ssp022301.html Just sheared the lower connection off mine. Part number cross references, just wondering on quality. That is the one I purchased. On fitting my old hose to the new condensor I ruined the thread. Tried an old spare hose and this was the same, which leads me to believe they are different threads!!! I looked at my old condensor and that had been ruined / botched, so please check yours. I think they have never been right so take your condensor to your hose man to check b4 fitting Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 29, 2019 thanks... hoping for some better luck to finish the airco... Quote Share this post Link to post Share on other sites
Cressa 46 Posted October 15, 2019 EVAPORATOR update. The firm I went to do the 3d image decided they couldn't do it!! But would help me change the fittings if I got one similar. So....After days/weeks/months of looking at the internet and contacting people i thought i had found the perfect item. It was a Webasto/Diavia item and the measurements were perfect for fitting in the box. I asked the company to confirm these sizes as it is a special order Non returnable (WTF) £160 with parliament tax. As the specialist dealer all i got was, that's what the catalogue says. Desperation, i finally took the plunge. 4 weeks later after walking to here from Italy!! You guessed it, too bloody Big. WAN###S (Sorry)point to note:- measurements are approximate, really..4 whole centimetres longer. So, went to the local firm for altering things and he says " too busy, no can do " WAN###S ( anyone spot a theme here )�� 6 months on with the Corrado high and lows and still no further on... I'm sure it won't beat me but I understand why people RIP IT OUT.. Breathe, breathe.. Next attempt is to get in touch with the Land of China to see if they can copy my original. And if so to get a few made. So a day off with man flu isn't wasted, as I start to learn Mandarin, for beginners. HELP..... Oh, for sale. 1 expensive oversized evaporator that will never fit a Corrado :bonk::dance::epicfail::epicfail: Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted October 15, 2019 You poor man. Have you tried the USA, there must be someone in California who can help. They need air con there. I’m not laughing honest. I’ve bought a few parts I was informed fitted but didn’t, temper tantrum moments. Chin up, move on. Quote Share this post Link to post Share on other sites
fla 9 Posted October 15, 2019 EVAPORATOR update. The firm I went to do the 3d image decided they couldn't do it!! But would help me change the fittings if I got one similar. So....After days/weeks/months of looking at the internet and contacting people i thought i had found the perfect item. It was a Webasto/Diavia item and the measurements were perfect for fitting in the box. I asked the company to confirm these sizes as it is a special order Non returnable (WTF) £160 with parliament tax. As the specialist dealer all i got was, that's what the catalogue says. Desperation, i finally took the plunge. 4 weeks later after walking to here from Italy!! You guessed it, too bloody Big. WAN###S (Sorry)point to note:- measurements are approximate, really..4 whole centimetres longer. So, went to the local firm for altering things and he says " too busy, no can do " WAN###S ( anyone spot a theme here )�� 6 months on with the Corrado high and lows and still no further on... I'm sure it won't beat me but I understand why people RIP IT OUT.. Breathe, breathe.. Next attempt is to get in touch with the Land of China to see if they can copy my original. And if so to get a few made. So a day off with man flu isn't wasted, as I start to learn Mandarin, for beginners. HELP..... Oh, for sale. 1 expensive oversized evaporator that will never fit a Corrado :bonk::dance::epicfail::epicfail: Hi Cressa, sorry to hear this. Can you send me some dimensions and images - we source various items from manufacturers in China and there are a few that we know although they manufacture components for industrial heat exchangers. I don't mind asking them to see what they can do, if that's of any help? Quote Share this post Link to post Share on other sites
Cressa 46 Posted October 15, 2019 Fla, I've pm'd you my details Quote Share this post Link to post Share on other sites
Keyo 49 Posted October 15, 2019 Sorry to hear this a measurement should be exactly that. Quote Share this post Link to post Share on other sites
Cressa 46 Posted November 9, 2019 Further update.. I have sourced an evaporator that FITS in the box and has the correct size pipes. BUT the pipes do need altering to fit in the correct position. 225mm long x 210mm wide x 75mm deep. VW no. 1j2820024A for RHD, NRF part no. 36106 Hella 8fv-351210771. I bought this one as it was only £62 off Ebay, so I'm going to try it. This part has gone to my mate who manufactures trailers, in the hope he can sort the pipes. He said he could... but I am used to being let down on this. Watch this space.. Quote Share this post Link to post Share on other sites
Cressa 46 Posted November 9, 2019 And, I managed to fall out with the guy that was making my pipes over some nuts that were left on !! and the £180 cost of them all. During this time I asked the aircon firm to make me some instead.... To be right with the first company I paid up but wasn't happy with my OCD.. Anyone want a complete replacement set of hoses??? My aircon firm actually made the hoses up during this time...... so i have ended up with two sets. With this set costing me more than double the first price, but they are nice and shinier. Christ this Corrado tax is expensive. Note to self, look for a different hobby :cheers: Quote Share this post Link to post Share on other sites
delfinis38 1 Posted November 9, 2019 (edited) And, I managed to fall out with the guy that was making my pipes over some nuts that were left on !! ���� and the £180 cost of them all. During this time I asked the aircon firm to make me some instead.... To be right with the first company I paid up but wasn't happy with my OCD.. Anyone want a complete replacement set of hoses??? My aircon firm actually made the hoses up during this time...... so i have ended up with two sets. With this set costing me more than double the first price, but they are nice and shinier. Christ this Corrado tax is expensive. Note to self, look for a different hobby :cheers: I got my pipes from pirtek. 120 each but I did a cash deal in the end for 80 each, a donation to the Friday beer and curry fund. I guess it ain’t that bad after it’s pressure tested... I was a bit peed off... thought it was better than stripping the front end again in the future. Edited November 9, 2019 by delfinis38 Quote Share this post Link to post Share on other sites
