k993apc 10 Posted April 21, 2019 (edited) Hi all Is there anywhere in the Midlands area that can rewire the entire wiring for the cooling system on a vr6 as mine does whatever it wants Cheers Edited April 21, 2019 by k993apc Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 21, 2019 What is happening exactly? Check out the definitive VR6 cooling thread stickied in the engine section of the forum for plenty of helpful info - I can't think of a reason why you would need to rebuild the entire loom unless it was butchered or damaged in the past. Quote Share this post Link to post Share on other sites
k993apc 10 Posted April 21, 2019 Fans only work on full speed. Both fans come on. Sometimes come on when you turn ignition off and take key out. Put key in. They go off Today turned car off. Went to shop. Came back and fans had turned themselves on Replace temp sensor in rad and large relay by header tank Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 21, 2019 Ok - still worth going through the steps in the guide. Which speed are they coming on at? I presume speed 3 since you say full in your post? The two fans are linked by a belt and the motor only drives one, so both will always spin together unless the belt breaks. Have you replaced the temp senders in the thermostat housing at the front of the engine block? Quote Share this post Link to post Share on other sites
fla 9 Posted April 22, 2019 Sounds like the full speed relay in the fan control unit is stuck. Might be worth removing and dismantling to clean the contacts. I've not taken one apart so cant really suggest any pointers there unfortunately although I'm sure someone can advise. Quote Share this post Link to post Share on other sites
k993apc 10 Posted April 22, 2019 It's the third one and still the same. 2 used 1 brand new Quote Share this post Link to post Share on other sites
mooG60 11 Posted May 3, 2019 It's worthwhile removing the little fuse strip at the top of the fan module and giving it and the contacts a clean if there is any corrosion forming. Fans coming on some minutes after a car has been switched off is a normal occurrence as far as I'm aware. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted May 4, 2019 Have you tried hot wiring the fan from the battery to see if it will produce all three speeds, I’m wondering if the fan is goosed and will only work on speed 3. If the fan works correctly chase the wires from the fan plug to the controller ( big black relay near expansion tank) the positive feed wires from it to the fan maybe joined together so always sending power for speed 3 Quote Share this post Link to post Share on other sites
swiftkid 1 Posted May 8, 2019 Radiator fan speed 3 is the black sensor in thermostat housing not in the radiator, thats stage 1 & 2 I think. I'd start with the basics, unplug fan & bridge contacts to check 12v on each of the speeds (see million page discussion thread). If they all check out then it's likely your actual fan is packing in. If not maybe try another fan control module as they have been known to pack up, I don't know for sure but you might be able to try any fan controller of that era instead of corrado with scene tax added. The way the system works is that you have 3 x 12v feeds to the fan (stage 1,2 & 3), stage 1 goes through 2 resistors, stage 2 goes through 1 and stage 3 is direct feed. Quote Share this post Link to post Share on other sites
bryangreene3 10 Posted June 30, 2019 Using a mechanical fan for a high horsepower application can work just fine if a couple of things are considered. A larger radiator, a larger clutch-fan, and a shroud would probably keep your engine cool; mechanical fans can sometimes work better than electric fans. Quote Share this post Link to post Share on other sites
