robrado974 1 Posted May 15, 2019 I know your supposed to use the correct tool , but can I get away with putting a cloth over a large flat head screwdriver or blunt chisel?,and tapping it loose ? I’ve tried it by hand but I can’t shift it . I presume it isn’t a left hand thread ?. Kind regards Rob Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 15, 2019 Yeah, screwdriver and a rubber mallet is how I've always done it - same when tightening - I guess that's what the plastic ridges on the ring are for! Quote Share this post Link to post Share on other sites
ger040 3 Posted May 15, 2019 standard thread - just chisel it to the left some come off easy some are tight to the last thread Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 15, 2019 righty tighty, lefty loosey ;) Quote Share this post Link to post Share on other sites
tonedef 9 Posted May 15, 2019 And if it’s anything like mine, it’s really easy to cross thread and almost impossible to fit right when refitting it. Of course when it’s not right it leaks fuel all over the floor when I fill up so I can tell straight away! Quote Share this post Link to post Share on other sites
Keyo 47 Posted May 15, 2019 I would say my fuel pump has def never been changed as the screw cap looks absolutely brand spanking new in my car !!! Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 15, 2019 Yeah, it's usually lovely and clean under there, especially if it's leaking petrol. The reason it's hard to refit is that the seal on the lid with the hoses is really hard to get on properly - I found the easiest way was to dunk it in petrol, then fit it to the lip of the tank opening, and then gently push on the lid until it sits snugly - if done right, the lock ring will go back on easily with no bother. You can tell I've been there done that a few times before when it comes to the fuel pump! Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted May 16, 2019 Also spraying the lockring's threads with silicone spray is another way to avoid cross threading it. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 16, 2019 Thanks chaps, much appreciated info . I will take a look on Sunday. Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 16, 2019 You can make one,flat bit of metal thar fits into the ribs then bend over to fit the rid ring ,fit a large nut bolt in the middle then undo the rib ring they are not that tight Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 16, 2019 1200 bandit said: You can make one,flat bit of metal thar fits into the ribs then bend over to fit the rid ring ,fit a large nut bolt in the middle then undo the rib ring they are not that tight If I can’t undo it I will make something up like the tool you describe. Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 16, 2019 It should come off no bother with a mallet and chisel/flat blade - never had an issue and have done it on 3 different cars. Quote Share this post Link to post Share on other sites
a_riot 0 Posted May 16, 2019 The tool is cheap enough if you want to save yourself some agro. Getting that ring on and off is the only part of the job that gives me any grief. https://www.ebay.com/i/202510808498?chn=ps Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 17, 2019 Nice one riot , thank you. Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 17, 2019 That's dirt cheap actually - only ever going to get used a few times though in the lifetime of a car. You could rent it out though! ;) Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 17, 2019 Lol , yeah I probably could . Quote Share this post Link to post Share on other sites
bryangreene3 10 Posted May 18, 2019 Removing the filler cap is the "fun" part, lots of lube sprayed around and twisting to get them out. Quote Share this post Link to post Share on other sites
