Fanjita 1 Posted September 12, 2019 (edited) ***SOLD*** R32 1993 Dark Pearl Burgundy Corrado - £3500 ono With regret, I need to pass my beloved car onto a new owner. It's a fantastic drive, and has been extremely fun in the last few months on the occasion I've chosen to take it for a spin. Vehicle Mileage: 188,000 Engine Mileage: ~25,000 (Seller of engine claimed 10k, no reason to disbelieve this, 15k covered since) Engine MKV R32 3.2l 24v VR6 - Remapped by Vince at Stealth Racing to 290.8 BHP!! BMC CDA intake Poly front engine mount Dubpower 6 branch stainless manifold Magnex (standard VR6) exhaust New parts including MAF, Lambdas, Radiator, ECU, Throttle Pedal Suspension & Drivetrain 288mm Brake upgrade MKIV Rear Calipers KW V2 Suspension Upgraded control arm bushes (R32 golf) All subframe & drivetrain components replaced over the last 3 years, including wheel bearings, brake discs/pads, suspension bushes, rear beam bushes and complete brake overhaul, handbrake cables. Body & Exterior Restoration work on boot around windscreen, number plate surround, both wings, sills (done in 2014) Inpro lights all round, not to everyone's taste and unfortunately do not have any standard parts (bought from previous owner this way) Upgraded headlight loom Black BBS RC 17" wrapped in Toyo T1Rs (genuine wheels) Spoiler has been serviced and works. Sunroof hasn't been serviced but still works! Interior Momo steering wheel JVC stereo Used as a daily by me for a number of years both before and after the new engine. Had a lot of love and care over the years, with all work completed to a high standard by myself or others I took it off the road from September 2015 until November 2018. Since November, it's regained an MOT and has been used on weekends and evenings and when not in use it's garaged. Whilst I've been using it these last few months, I've had various things done including; New Battery, Alternator and starter motor (all bosch/varta) New front offside outer CV New clutch slave cylinder (in the last 3 months alone, it's had around £1300 spent on it!) Negatives The windscreen has a crack on both sides. It's not in a position to cause a failed MOT, but it will need replacing. There are two areas of rust that will need sorting; One spot is on the inside of the A-Pillar approximately 1 or two inches, it had always been my intention to get the windscreen replaced and fix this rust at the same time. Underneath and adjacent to the rear badge are two spots bubbling, approximately the size of a 20p piece each. Rust wise, this is pretty much it. There is none in the usual other places, like under the filler cap, wings and sills. These have already been restored around 4 years ago to a high standard. Reason for sale: This needs to go on to someone who has the time to make it perfect. I have put a lot of time and money into this car, but want to hang up the hat. It is a fantastic car and I will miss it greatly, it will give the new owner a great amount of enjoyment. £3500 ono Located in Leicester. Contact me on here or by email: jameswright1987@gmail.com with any questions! Recent video of it running: [video=youtube_share;5dFu_Dt0SzY] 20190625_171849 by Fanjita2009, on Flickr 20190326_135711 by Fanjita2009, on Flickr 20190326_135757 by Fanjita2009, on Flickr 20190815_122551 by Fanjita2009, on Flickr Build thread below http://the-corrado.net/showthread.php?t=43612 Edited September 16, 2019 by Fanjita Car Sold Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 13, 2019 Wow - some car at a great price! Good luck with sale. Quote Share this post Link to post Share on other sites
blue95 0 Posted September 14, 2019 What a great motor.....bargain buy for someone....get it on eBay for a higher price :0 Quote Share this post Link to post Share on other sites
Fanjita 1 Posted September 16, 2019 I suspect you might be right! Car now sold! Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 16, 2019 Not surprised it sold that quick, you couldn't even pay someone to do the conversion for less than that. Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 16, 2019 swiftkid said: Not surprised it sold that quick, you couldn't even pay someone to do the conversion for less than that. My thoughts exactly! Quote Share this post Link to post Share on other sites
fla 9 Posted December 5, 2019 Anyone here bought this? Quote Share this post Link to post Share on other sites
swiftkid 1 Posted December 6, 2019 Yes, he pm'd me the other day. I'll let him introduce himself, seems to have been a member for a while Quote Share this post Link to post Share on other sites
51ngh 11 Posted December 6, 2019 Hi All, As swiftkid mentioned, I purchased this, will be starting a thread when I get a chance, only driven a few times since purchase as it seems to have got the dreaded pedal problem, was driving and no response from pedal.. need to get it on vagcom. I have a replacement pedal already and have taken the ECU out, checked for water ingress and it seems fine.. may need to source another BUB ECU, but seems weird this has had the same problem a few times before. I did speak to SWICT for any wiring conversion diagrams however they couldn't provide. Things I will be doing (or in the process of): 6speed conversion (already have the gearbox) Wavetrac diff (already purchased) New discs and pads all round (brembo and ds2500 already purchased ) Will be getting new tyres Sourcing rear polo stub axles with the stronger rear bearing... Hesitation at 2k rpm I'm not happy with, will be going to Eddie (aka toyotec) who will be entrusted to sort map out I would like recaros of some sort General tidy up of engine and inspect/ clean/ refurb parts Rear standard lights have been sourced and put back Front inpro will be up for sale soon, I have sourced original front lights which will go back on.. Need to sort out alittle rust by the a pillar near windscreen and source and fit a new screen (if anyone has Need to source a 90mm front splitter Bonnet and wing will be repainted to match condition of rest of car.. Had lots of people comment on it and offer to buy whilst it has been out 🙂 Quote Share this post Link to post Share on other sites
Keyo 49 Posted December 6, 2019 Sorry to change the subject but does any of the members own a R36 conversion on here, surely that is the holy grail of engine swaps for the corrado ? Quote Share this post Link to post Share on other sites
