Kempy 0 Posted April 29, 2020 Hello all. Nice to be back. I'm looking to replace a fuel line. The long one under the car on my valver, from the filter to the front of the car. Anyone know where it comes out and what it's connected to? Many thanks Kempy Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 29, 2020 That's the feed line - comes from the tank to the pump, then to the filter and then to your fuel accumulator. There should also be a return line that goes straight back to the tank. 1 Quote Share this post Link to post Share on other sites
Kempy 0 Posted April 29, 2020 Cool thanks. I've damaged it getting the car down the drive. Petrol spewing out of it. I've seen parts are a bit easier to get nowadays. It's been a while since I bought anything for it. Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 29, 2020 I think the 16v ones are still available new from VW (and they are similar to the 16v Mk2) - check with member @Keyo on here, as he also has a 16v GTI and may be able to help - I remember it coming up in a post before. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 29, 2020 Sounds like the feed fuel pipe from filter to engine bay No 8 on diagram and part number 535201374. http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/COR/year/1995/drive_standart/76/hg_ug/201/subcategory/69000/part_id/3687212/lang/e#sec_8 Quote Share this post Link to post Share on other sites
Kempy 0 Posted April 29, 2020 Ya that's what I was looking at buying. Just wondered where I'd find it in the bay. But I have a good idea. Would u think be good idea for new bandjos etc too Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 29, 2020 (edited) 5 hours ago, Kempy said: Ya that's what I was looking at buying. Just wondered where I'd find it in the bay. But I have a good idea. Would u think be good idea for new bandjos etc too Be very lucky to find one as obsolete as a Dodo, the PG block has the same part number with an A on the end of the part number but looks incorrect for a KR block. Its a good idea to change everything in that area to be honest - Hel Performance will replicate you one if you send your fuel line to them to copy. VW Rule member on here might be able to advise you on where you can source one as he knows your engine well in Corrado- he has been quiet on here lately though. Hel custom made me some injector lines for my MK2 16V KR early last year so can reccomend. Edited April 29, 2020 by Keyo Quote Share this post Link to post Share on other sites
Kempy 0 Posted April 29, 2020 Mines a 9a. The parts on the vw heritage site I thought Quote Share this post Link to post Share on other sites
Kempy 0 Posted April 29, 2020 I'll have to get one made up then. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 29, 2020 (edited) Im not 100 percent what fuel line your on a about but this a feed(supply) line connected to your metering head so will connect to the damage pipe . Goes from metering to towards bulk head, unfortunately the one on Heritage is for most corrado but not for a 9A. VW rule has refurbished this area so is pretty clued up on it - I'm sure he wouldn't mind if you dropped him a PM. 051133723E Edited April 29, 2020 by Keyo Quote Share this post Link to post Share on other sites
dragon green 6 Posted April 30, 2020 I’m sure this is what you want https://www.ebay.co.uk/itm/153462664845 Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 30, 2020 (edited) They are injector lines from metering head to each injector and cold start - his on about the main fuel line that runs under car from filter to bulkhead then onto metering head I guess . My video was just to show the quality of Hel work . Also those injector lines are horrible off the shelf as they do not come with the bends manufactured in them and look a mess . If he has damaged the lines by bottoming out I wouldn't be surprised if the swirl pot under the car is damaged as well because its made of plastic and lower then the fuel lines - KR/9A has such a prehistoric fuel system compared to a VR including x2 pumps- accumulator - cold start - 5th injector - metering head - individual injector lines and more. Edited April 30, 2020 by Keyo Quote Share this post Link to post Share on other sites
dragon green 6 Posted April 30, 2020 If it was me,I’d probably make them myself.Once you know the fitting sizes, the fittings are all available on line. I made this one, Teflon lined,with stainless overbraid, Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 30, 2020 2 minutes ago, dragon green said: If it was me,I’d probably make them myself.Once you know the fitting sizes, the fittings are all available on line. I made this one, Teflon lined,with stainless overbraid, That looks nice how did you pressure test them and what to ? Quote Share this post Link to post Share on other sites
Kempy 0 Posted April 30, 2020 I think I know what it goes to on the metering heads. I'll take it off and get one made, one that'll withstand some punishment under the car if possible Quote Share this post Link to post Share on other sites
dragon green 6 Posted April 30, 2020 That looks nice how did you pressure test them and what to ? They have olives in the fittings, like brake pipes, the hose has burst pressure of 7000psi , I used to put a blanking plug on one end, and a fitting for an air hose on the other,and pump it up with a foot pump to a couple of bar, but through the years, making quite a few, you get used to making them, and touching wood , I haven’t had a leak yet ! Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 30, 2020 Certainly good knowledge to have on how to make them with the majority of the these fuel lines been obsolete. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 30, 2020 On 4/29/2020 at 6:52 PM, Kempy said: I'll have to get one made up then. Kempy Geri is breaking a 9A. Quote Share this post Link to post Share on other sites
ger040 4 Posted April 30, 2020 the metering head on the car is now gone kempy is it just where the lines connect to the metering head you need to know? Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 15, 2021 Afternoon. Sorry went a bit quiet for a bit. I've bought some parts and they will do the job but I deffo need a line from the metering head to the filter as it's snapped. Can I use a length of rubber line from a heritage for example and attach with clips? They have it listed but it's not in stock. Which I think someone had said already. Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 15, 2021 VID-20210814-WA0012.mp4 Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 17, 2021 On 8/15/2021 at 1:01 PM, Kempy said: Afternoon. Sorry went a bit quiet for a bit. I've bought some parts and they will do the job but I deffo need a line from the metering head to the filter as it's snapped. Can I use a length of rubber line from a heritage for example and attach with clips? They have it listed but it's not in stock. Which I think someone had said already. You might have an issue because k-jetronic operates at a higher pressure than electronic fuel injeciton systems, generally around 5.5-6 bar (designed for Messerschmidt engines!) as opposed to 2.5-4.5, so you need to make sure that you source the right kind of fuel hose - that's why all the fuel distributor lines are braided. Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 18, 2021 Might splash out on the hel ones. They look worth the money Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 19, 2021 So the one goodridge hose isn't quite fitting and I think it's for the unit which has the filter attached to the plastic casing of the pump. I wonder if anyone would be interested in this on its own? Quote Share this post Link to post Share on other sites
Kempy 0 Posted August 23, 2021 So I've plumbed it all up and it's all working with no leaks. Happy days Quote Share this post Link to post Share on other sites
