Cressa 43 Posted June 18, 2021 Probably an easy one for someone.... I have been under my car today and noticed halfway under the car, the 3 fuel lines disappear into a tunnel, something is missing Vr6 It looks as though It had some old perished sponge in there to stop them from vibrating/wearing on the chassis. What should protect them at this point please anyone . I love a picture to explain things to me 🤔 Quote Share this post Link to post Share on other sites
Cressa 43 Posted June 18, 2021 Not a Corrado, but this picture shows fuel lines going in on the right. I dont want to fully block the area in case it holds water Quote Share this post Link to post Share on other sites
Dox 22 Posted June 18, 2021 Rear of the chassis rails they just clip to the floor pan, forward they go inside the rail to bay and are wrapped in heat proofing Quote Share this post Link to post Share on other sites
Cressa 43 Posted June 18, 2021 Cheers Dox, Mine are clipped up to this point . It made me wonder if something should be at the beginning of this box section as I removed some sort of worn material.... Quote Share this post Link to post Share on other sites
fla 9 Posted June 18, 2021 I think mine also have some foam around them towards the back that leads into that channel Quote Share this post Link to post Share on other sites
Cressa 43 Posted June 19, 2021 Bit of rust treatment. But I have pulled out some degraded sponge.. 1 Quote Share this post Link to post Share on other sites
Elderrado 0 Posted September 21, 2021 On 6/18/2021 at 4:37 PM, Cressa said: Probably an easy one for someone.... I have been under my car today and noticed halfway under the car, the 3 fuel lines disappear into a tunnel, something is missing Vr6 It looks as though It had some old perished sponge in there to stop them from vibrating/wearing on the chassis. What should protect them at this point please anyone . I love a picture to explain things to me 🤔 I plan to use some pipe cladding to replace the foam in that area when i replace my fuel lines but worried it may hold moisture ? Quote Share this post Link to post Share on other sites
Cressa 43 Posted September 21, 2021 I havent sorted mine yet, but seems a good idea Quote Share this post Link to post Share on other sites
Keyo 47 Posted May 3, 2022 (edited) Anyone know the best way to change the black feedline that goes through this tunnel- would it be best to tie it to the old one coming out- is it a hell of a job best done on a ramp, ? Thanks I have this to fit from filter to engine bay. Picture of hose which is the same for a late g60 or vr - its about the only hose you can buy now so not doing the soft hose hack- if you can buy new you by new. I believe Sean has done this job ? Edited May 3, 2022 by Keyo Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 3, 2022 (edited) It's not bad threading it through. I pushed the heat sleeve in the bay down a bit and did everything else from the filter end. I taped a bit of string to the old one and pulled it out, then attached it to the new one and pulled it back through, but I didn't encounter much resistance to be honest. Probably better safe than sorry though! Edited May 3, 2022 by seanl82 Quote Share this post Link to post Share on other sites
Keyo 47 Posted May 3, 2022 2 hours ago, seanl82 said: It's not bad threading it through. I pushed the heat sleeve in the bay down a bit and did everything else from the filter end. I taped a bit of string to the old one and pulled it out, then attached it to the new one and pulled it back through, but I didn't encounter much resistance to be honest. Probably better safe than sorry though! Lol i will give it a go this weekend need to do the vr and g60 - hope I dont shag it up if it gets stuck will be in all sorts of trouble ha. Thanks Quote Share this post Link to post Share on other sites
