Jonnie 0 Posted June 22, 2021 H reg (1990/91) Corrado , washer jets, will other VW fit the rectangular hole? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 22, 2021 6 hours ago, Jonnie said: H reg (1990/91) Corrado , washer jets, will other VW fit the rectangular hole? not sure as never compared there is an alternative though, i have wiper arm mounted jets which work brilliantly Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 22, 2021 (edited) VDO to sell the oe ones have a couple of new ones here as spares. 191955985A for heated https://www.ebay.co.uk/itm/173448243443?epid=249512620&hash=item28625228f3:g:K9gAAOSwv0tVW4Ea None heated 191955986A https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=191955985A&_sacat=0&_pgn=2 Get these both from the dealers Im guessing. Anyone know does the heating come on when deforst button switched on or is it auto heat when washer switch pressed, Edited June 22, 2021 by Keyo Quote Share this post Link to post Share on other sites
fla 9 Posted June 22, 2021 I think its when the rear demist is pressed. Also puts the mirror demist on too Quote Share this post Link to post Share on other sites
GrahamU 6 Posted June 29, 2021 On 6/22/2021 at 11:25 PM, fla said: I think its when the rear demist is pressed. Also puts the mirror demist on too Every diagram I've seen shows them as coming on when the ignition is on (KL15) so they are on whenever the car is. Fuse 14 and connection D/9 from fuse box Always surprises me as I expected it to be when rear demist was on Quote Share this post Link to post Share on other sites
Keyo 47 Posted June 29, 2021 1 minute ago, GrahamU said: Every diagram I've seen shows them as coming on when the ignition is on (KL15) so they are on whenever the car is. Fuse 14 and connection D/9 from fuse box Always surprises me as I expected it to be when rear demist was on I imagine most of these do not work then if on all the time. Quote Share this post Link to post Share on other sites
Cressa 44 Posted June 29, 2021 2 hours ago, GrahamU said: Every diagram I've seen shows them as coming on when the ignition is on (KL15) so they are on whenever the car is. Fuse 14 and connection D/9 from fuse box Always surprises me as I expected it to be when rear demist was on I tested mine and it was as above, ignition on. Does seem strange !!! Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 29, 2021 Well, washing with warm water is always better than cold lol I’m sure the elements have to burn out after a couple of years though - have never tested mine. Screenwash does have a lower freezing point, so assume this is just to help clear the nozzles? Quote Share this post Link to post Share on other sites
