GrahamU 6 Posted June 29, 2021 Dropped my car on the floor at the weekend, first time with wings and arch liners in for many years, when I drove it I noticed the tyres scrape the liners and its not that low, So what do people do with the liner when they drop them right down? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 29, 2021 i guess they remove them ive got my KW's set at 2 finger gap between top of tyre & the bottom of the wing, this is ok the majority of the time unless im going fairly quick & there is a short big bump in the road when i then get a slight rub on the rebound i guess it depends on the J width of the wheels that are being ran as well as the liners arch downwards as they approach the wing Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 29, 2021 Turn up the stiffness, raise it up, or a combo of both Quote Share this post Link to post Share on other sites
Dox 23 Posted June 29, 2021 I’ll say smaller tyre? Quote Share this post Link to post Share on other sites
Dox 23 Posted June 29, 2021 12 minutes ago, g0ldf1ng3r said: i guess they remove them ive got my KW's set at 2 finger gap between top of tyre & the bottom of the wing, this is ok the majority of the time unless im going fairly quick & there is a short big bump in the road when i then get a slight rub on the rebound i guess it depends on the J width of the wheels that are being ran as well as the liners arch downwards as they approach the wing 2 fingers with or without the weight of the driver? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 29, 2021 2 minutes ago, Dox said: 2 fingers with or without the weight of the driver? without driver my KW's are V1's so no adjustments other than height unfortunately if the OP's got that ability i would play around with bound & rebound settings to try & firm it up or just jack the coilovers up a touch id be hesitant to remove the arch liners due to all the crap off the road getting up into the engine bay but that would also depend on how many miles it covers each year, if minimal then i guess you could keep on top of the bay cleaning Quote Share this post Link to post Share on other sites
GrahamU 6 Posted June 29, 2021 1 minute ago, g0ldf1ng3r said: without driver my KW's are V1's so no adjustments other than height unfortunately if the OP's got that ability i would play around with bound & rebound settings to try & firm it up or just jack the coilovers up a touch id be hesitant to remove the arch liners due to all the crap off the road getting up into the engine bay but that would also depend on how many miles it covers each year, if minimal then i guess you could keep on top of the bay cleaning I have Koni coilovers so will be playing with adjustment, The rear is sitting 20mm higher than the front so I plan to go up 10 on the front and down 10 on the rear but the camber on the front is quite bad with the top in a long way so I am concerned that when the camber is sorted it will be back to the same situation even though its not very low. It does have spacers to clear the Brembo's as well Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted June 29, 2021 4 minutes ago, GrahamU said: I have Koni coilovers so will be playing with adjustment, The rear is sitting 20mm higher than the front so I plan to go up 10 on the front and down 10 on the rear but the camber on the front is quite bad with the top in a long way so I am concerned that when the camber is sorted it will be back to the same situation even though its not very low. It does have spacers to clear the Brembo's as well what wheels are you running graham? im still on the 15" speedlines & also run 10mm spacers on the front to clear my 4 pots - my running height is fine 99% of the time, it is only those small sharp rise bumps that cause a slight rub as the weight shifts downwards have your Koni's got bound & rebound adjustment? i guess another possible route would be to get a higher spring weight on the coilover springs but obviously that is an expensive option Quote Share this post Link to post Share on other sites
GrahamU 6 Posted June 29, 2021 Mine are 205/40/17 To be honest I'll need to check if the Koni's have both bump and rebound, I bought them quite some time ago I wasn't sure if people did remove the liners because it seems a bit risky to get all the dirt and water up there Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 29, 2021 What et are the wheels? that can be important too. Quote Share this post Link to post Share on other sites
fla 9 Posted June 29, 2021 1 hour ago, 1xshaunx1 said: What et are the wheels? that can be important too. I think the lowest (or highest) offset without rubbing (on the back) is 32. Ideally 33 to 43. I assume something similar at the front? Quote Share this post Link to post Share on other sites
GrahamU 6 Posted June 29, 2021 2 hours ago, 1xshaunx1 said: What et are the wheels? that can be important too. You're assuming the rest is standard, you haven't seen my build have you 🤣 the wheels do sit further out than standard Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 29, 2021 3 hours ago, GrahamU said: Mine are 205/40/17 To be honest I'll need to check if the Koni's have both bump and rebound, I bought them quite some time ago I wasn't sure if people did remove the liners because it seems a bit risky to get all the dirt and water up there Not sure if it was the cause Graham, but I had to cut out and weld in a new inner wing due to rot. My car was very low when I bought it so my guess is that a previous owner removed the liners to "slam it". Even the oil pump pickup had a crack in it and had scored the inside of the sump! Surprisingly engine is still strong and in good health though! Quote Share this post Link to post Share on other sites
GrahamU 6 Posted July 1, 2021 On 6/29/2021 at 10:26 PM, seanl82 said: Not sure if it was the cause Graham, but I had to cut out and weld in a new inner wing due to rot. My car was very low when I bought it so my guess is that a previous owner removed the liners to "slam it". Even the oil pump pickup had a crack in it and had scored the inside of the sump! Surprisingly engine is still strong and in good health though! Thanks Sean, that's what I would be worried about if removing is the answer worst case I'll modify some with the soft fabric designs they use these days 🙂 Quote Share this post Link to post Share on other sites
