dubweiser 0 Posted December 5, 2004 I need to change my cv boot and i managed to get the nut off the ball joint bolt but the bolt will not budge(yet).Is there a way to get it out other than persuading it with a hammer.Is it threaded perhaps?or does it just need a bit of friendly coaxing?Just want to make sure before i hit it.Also i got a new cv boot kit from ECP and there are a few bits in it im not sure about ie a small semi circle shape piece of wire,a plastic ring which is stepped and a flat(ish) metal type washer.Anyone clarify what all these bits are please.Cheers Quote Share this post Link to post Share on other sites
stevemac 0 Posted December 5, 2004 I just had to belt fcuk out of my ball joints when I did them.. :rambo: Quote Share this post Link to post Share on other sites
dubweiser 0 Posted December 5, 2004 i take that as a yes to the hammer solution? Quote Share this post Link to post Share on other sites
Heardy 0 Posted December 5, 2004 Why don't you just udo the 3 bolt's instead it will be much easier. Quote Share this post Link to post Share on other sites
stevemac 0 Posted December 5, 2004 Renew the ball joints while you have the thing in bits - they're very likely to be knackered. dubweiser - open up the ball joint bolt housing with a claw hammer - the bolt should come out a little easier. :wink: Quote Share this post Link to post Share on other sites
Scruffythefirst 0 Posted December 5, 2004 Just buy a ball joint splitter. theyre not expensive and will save damaging anything else. Once they're lose you can jack the hub up and the wishbone should fall downwards freeing the hub so you can get the driveshaft out. If your goign to reuse the balljoint make sure you dont damage the rubber boot otherwise it'll last less than 5 minutes Quote Share this post Link to post Share on other sites
billinjah 0 Posted December 5, 2004 i did the cvs with the ball joints in situ just un do the bolts at the box then turn it to lock the driveshaft will fall down undo axle bolt with wheels on floor first though Quote Share this post Link to post Share on other sites
dubweiser 0 Posted December 7, 2004 Heardy......what three bolts???My plan of action was to just undo the ball joint bolt and the drive shft end nut and that was it.What three bolts u on about mate? Quote Share this post Link to post Share on other sites
Heardy 0 Posted December 7, 2004 The 3 bolt's that hold the ball joint to the wishbone, i just find it easier to undo them rather than beating the ball joint with a hammer.. Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 7, 2004 Are they all bolted on. I have had to drill out some big rivets before which were replaced by bolts. Gavin Quote Share this post Link to post Share on other sites
dubweiser 0 Posted December 7, 2004 aha.....maybe i didnt explain it properly.Its not the actual joint im having probs with but the bolt that goes through.Ive got the nut off but didnt want to hit the bolt if it was not meant to come out like this.Cheers Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 7, 2004 The bolt should come out but they are often rusted solid. a good soaking with WD and a rattle with an impact gun works wonders. Undoing the 3 bolts would be easier. but you risk altering the tracking if you don't get it back exactly where it came from. Gavin Quote Share this post Link to post Share on other sites
dubweiser 0 Posted December 7, 2004 cheers.....ive got the wd AND the plusgas on standby.Any advice as to what all the bits in the new kit are? Quote Share this post Link to post Share on other sites
Heardy 0 Posted December 7, 2004 All the one's that i've seen have been bolted on but there probably are some that are riveted :roll: Dubweiser is the bolt that youre talking about vertical?/ because if it is i dont't think you're going to shift it by hitting it you need to hit the part that the bolt goes into the while applying some downward pressure :wink: O too late never mind..... Quote Share this post Link to post Share on other sites
Rossco 0 Posted December 8, 2004 Aparently they came from the factor riveted so if yours arent riveted then its likely they have been changed Quote Share this post Link to post Share on other sites
dubweiser 0 Posted December 8, 2004 its not the ball joint itself!!Its just the bolt that locks it in place that goes through the hub assembly.Horizontal bolt with 17mm nut on it. Quote Share this post Link to post Share on other sites
Scruffythefirst 0 Posted December 8, 2004 Yeah you can hit that out - put a screwdriver or simmilar on it and give it a good tap. You should idealy replace them with new ones on reassembly. Then jack the hub up and gently tap the wishbone downwards and that should release the ball joint. Make sure you stop the jack from moving backwards when you jack up the hub as the spring will want to force the hub out and use a block of wood so you dont damage your wheel studs / disc. Quote Share this post Link to post Share on other sites
dubweiser 0 Posted December 13, 2004 cheers scruffy.u know wot i was on about.Ive bought a new bolt to replace the old one so its fingers crossed now........... Quote Share this post Link to post Share on other sites
