Bora Bora 0 Posted January 2, 2005 I picked up an old airbox for my valver today and plan to fit a cold air feed pipe to it. I think I will remove the grill and using a hole saw cut a hole into the panel behind it. Then do the same to the airbox and link up the holes with some pipe. Anyone done anything similar? Any tips? And what is the best sort of pipe and diameter to use? Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 3, 2005 I've done this, check out my personal gallery for pics. It took quite a bit of fabrication to get it out the side, I think the diameter of the Ali pipe is about 70mm. Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 3, 2005 Thats exactly what I want to do mate! Impressively done! Struggling to find some flexible pipe to do the job.Where did you get yours from and also the aluminium piece? Does it make much difference or just sound nice? Quote Share this post Link to post Share on other sites
rs200f40 0 Posted January 3, 2005 I did the same to my Golf as daves16v did, it did seem to help the responsivness of the engine and I didn't really notice any difference in noise. Have a rummage through a scrapyard and find some flexible air ducting from behind a dashboard. Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 3, 2005 Improved the response but no more noise. I work in the fab industry so was able to get the tube from work and have a plate welded to it that had mounting holes that also blanked off the original inlet to the box. I also made a blanking plate so the box could be returned to standard. The flexible tube was given to me by a friend who was refurbing his caravan. He had some caravan ducting tube left over which is about £8 a metre. Best tube I've ever used, very flexible but stiff at the same time and also fire proof. Best thing about it was that it reduced from about a metre to about a 300mm whilst remaining flexible. Mine doesn't poke thru the front but sits just behind the gap between the slam panel and bumper. I was a little concerned about too much water getting in. Quote Share this post Link to post Share on other sites
JBOB 0 Posted January 3, 2005 I was a little concerned about too much water getting in. I was thinking about doing this and thats a very good point. Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 3, 2005 At the point the flexible pipe meets the Ali pipe I've drilled about an 8mm hole at the bottom to help drain any water getting in. Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 3, 2005 dave's 16v You have obviously thought of everything! Advice is much appreciated! Quote Share this post Link to post Share on other sites
dubweiser 0 Posted January 3, 2005 hi candywhite did u finall get ya car sorted maye?did u get the metering head?And where did u get the air box for ya motor?ive been looking everywhere for bloody ages to get hold of one but cant find one.Where the hell did u get it from.Also i have a full how to about modding the airbox with an airfed pipe and everything.Ill try and find it somewhere Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 3, 2005 CandyWhite16v, There seem to be alot of cold air feeds that have used the existing inlet (behind the headlight) and this results in the flexible pipe being squashed as it routes into the area behind the grill. I saw this as inefficient so decided to go with the side outlet. You have to remove the rubber o-ring that holds the box down and bend down the tab that the o-ring sits around. Don't worry the box doesn't move about. There isn't alot of height in the lower air box so you need to be choose the pipe size carefully if you intend coming out the side of the box. Getting the parts fabricated could be a problem if you don't have access to the facilities. Quote Share this post Link to post Share on other sites
dubweiser 0 Posted January 3, 2005 hey candywhite if u send me ya email adress i canmail u the full how to for this airbox mod soon as i ge the chance mate Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted January 3, 2005 ... or remove the carbon canister and route the ducting in from underneath, with the front end of the tube fixed to the 'lower grille'. Have a look at http://www.greenfilters.com -they do loads of universal air feeds etc. Quote Share this post Link to post Share on other sites
slot 0 Posted January 3, 2005 Gsf do some air ducting it's about £2 or £3 a length , that's what i used ! :) You can drill the air box or remove the mouth piece to direct your hose into !! :wink: Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 3, 2005 Dubweiser. You have pm. Slot .Cheers I'll give GSF a bell in the morning Quote Share this post Link to post Share on other sites
flusted 0 Posted January 3, 2005 On the 16v theres a huge plate near the headlight in the chassis that pops out.I beleive this is where the carbon canister normally gos on other models.Ive popped this out and have managed to get a 4" flexi tube down through the hole and into the airstream.Ive used tumble drier hose before but the bit im using at the mo is a internal heater pipe from a landrover Quote Share this post Link to post Share on other sites
dubweiser 0 Posted January 4, 2005 hi candy ive just sent the howtomate.Covers just about everything.Hope it helps :-P Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 4, 2005 dubweiser Cheers! Doing mine alittle bit different and will post up some pics when finished. Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 19, 2005 Finally got the job done today! Looks quite factory fitted...even if I do say so myself :D Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 19, 2005 Behind the grill Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 19, 2005 CandyWhite16v, similar to mine, notice any improvement? Quote Share this post Link to post Share on other sites
corradophil 3 Posted January 19, 2005 I've done this on mine, I have also separated off part of the area behind the grill to make a scoop, plus I have plumbed it in so the air flap inside the airbox can still block the cold feed if needed. Quote Share this post Link to post Share on other sites
Bora Bora 0 Posted January 19, 2005 Seems a bit more responsive and gives a nice growl along the way! Quote Share this post Link to post Share on other sites
