coullstar
Is this cam ok?
I had decided to fit the inlet cam from my KR to the 9a and had a quick look at the cam last night.
What I found was a chip out of the case harding on one of the lobes. This was probably done when it was in my garage and I am pretty sure its now gooosed. Is it?
Yeah, that's shot - and it's more likely to have happened while it was in the previous engine. It looks like pitting more than a chip, and this would be consistant with the surrounding wear pattern.
I don't think you should use that again.
Olly
If you decide it is, have a word with TomB. I gave him an inlet cam last weekend. Not sure if he used it or not.
In my amateur opinion, that cam is useable. In formula 1 you wouldn't but providing there are no high spots then it shouldn't damage the tappet and would probably run forever.
Gavin
personally i wouldn't use it, it's not like the damage is off the profile, it's right on the end where valve spring resistance is greatest!
as said by others, I wouldn't put that in a decent engine/car. If it was a 50 quid runaround that you were only going to drive for a few months and didn't give any stick then it would probably out-live the rest of a banger, but not in a high rpm 16v that you plan on keeping!
David.
