potatonet
Crank bolt?
Lock the flywheel with a large flat screwdriver, wedged between the ring gear & bell housing (may need a friend to help you).
Get third friend with large feet to stand on the brakes with the car in gear. :D
Gavin
Don't use a std bolt as a replacement. Get one from an A1 with the DX engine.
what car and model would have one? and why?
Golf GTI MK1 has a DX engine - the crank bolt is not a "stretch" bolt like the Corrado one.
Gavin
Noooo - the disc retaining screw will just shear off... :cry:
Gavin
Not if you have the wheels on, or at least the wheel bolts in through the disks... That's how I did mine anyway... :p
so will the 84 GTI bolt work? removing is easy, cause I think its loose otherwise I will follow stevemac's instructions.
yeah i used the dx bolt and washer,with a little thread lock
i worried for ages about undoing the old one but it came undone about as easy as a tight wheel nut, no need to jam the flywheel etc
My passat one came off easy cos the chuffer had spun the crank pulley :roll:
I fitted a std bolt while the DX one came in. Even that was hard to get out. I wouldn't fit one with a gun, especially a std one, the constant shocking can't be good for it.
Wheelbolts are made of different steel and not done up as tight.
Gavin
Workshp airgun - turned to "max" wouldn't shift mine - I had to swing on a 2ft breaker bar to get the old bolt out.. :shock:
