aposegil 0 Posted September 7, 2005 Hello guys As im going to take the rebuild of my engine on myself where can i find a step by step guide to rebuild it with all the torque values i need i already knwo all the ones for the head so thats not a prob its the bottom end im doing for the first time so things like oil pump and rod bolts etc. thank you in advance Quote Share this post Link to post Share on other sites
Dennis.be 0 Posted September 7, 2005 Bentley has a repair manual for that engine, but it's for a US Golf MK 2 2.0 16v 9A. Maybe is that a possible way to find the right info about your engine? Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 7, 2005 as far as i was awear us didnt get the 9A i might be wrong but thats what those guys over there tell me Quote Share this post Link to post Share on other sites
rmn 0 Posted September 7, 2005 bentley doesnt cover it Alex, but here is the haynes data sheet http://www.corradoclub.org/Tech%20files/Corrado%202.0%2016v.pdf here is the 1.8 16v infor to compare http://www.corradoclub.org/Tech%20files/Corrado%201.8%2016v.pdf Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 7, 2005 thanx mate Quote Share this post Link to post Share on other sites
Jim 2 Posted September 7, 2005 The Passat used the same engine from 08/88 - 12/93.. so the Haynes manual for that version of the Passat should have the info you need as well mate? :) Quote Share this post Link to post Share on other sites
Lippy 0 Posted September 7, 2005 Think Gavin(h100vw) picked one up recently..........he may be able to help you Alex Good luck! Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 7, 2005 Hello guys As im going to take the rebuild of my engine on myself where can i find a step by step guide to rebuild it with all the torque values i need i already knwo all the ones for the head so thats not a prob its the bottom end im doing for the first time so things like oil pump and rod bolts etc. thank you in advance Think it's all in the Haynes Passat one Alex, I'll have a look this eve and scan it for you if it's all there, there's certainly loads of torque settings listed. If not my dad built my 6A from a bare block so will have the info somewhere, he's certainly got piles of Autodata reference books at work which must have that info in. David. Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 7, 2005 guys thanx alot didnt think i would get this kind of repsonse :) still in two minds if to let a local guy put it back together as they have the proper equipment for honing and boring or if to have a go myself but any info is great thanx in advance Quote Share this post Link to post Share on other sites
corradophil 3 Posted September 7, 2005 Yes, the Haynes Passat one has the 9A. I think to be honest a Mk2 Golf manual covering the KR will have most of the info you need. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted September 7, 2005 These should also help! http://www.clubgti.com/forum/forum_post ... 52550&PN=1 http://www.the-corrado.net/.archive/forum/viewto ... ghlight=9a http://www.clubgti.com/downloads/6a_conversion.pdf Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 7, 2005 Think Gavin(h100vw) picked one up recently..........he may be able to help you Alex Good luck! I did get a Bentley Passat manual at e38. It would appear the only engine the spams got was the 9A. I can probably sort you with the info you need. None of the Haynes manuals I have seen have the 9A in. Gavin Quote Share this post Link to post Share on other sites
Dennis.be 0 Posted September 7, 2005 as far as i was awear us didnt get the 9A i might be wrong but thats what those guys over there tell me The us did get the 9A, but in the golf 2. http://www.doppel-wobber.de/g2_16v2.html I geuss i mixed some manual up to eachother, my mistake. :oops: Quote Share this post Link to post Share on other sites
RW1 0 Posted September 7, 2005 None of the Haynes manuals I have seen have the 9A in. Gavin, Out of print Passat 1988 - 1991 Haynes Book No. 1647 has the 9A in it. It was replaced by the current Passat book 1988 - 1994? Best source is EBAY these days. Purple cover. Covers the pre face lift Corrado for other things quite well so is worth buying for a few quid. Chris ------- aposegil: It covers 9A torque settings on the engine. If that is all you need, it's two pages to scan?? . Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 8, 2005 Chris, That must have been out of print chuffing years, I had my first Passat GT 16V in 1998. I guess it was a 'workshop' manual, as opposed to the common or garden 'service and repair' manual, which isn't half as much use in my humble opinion. Gavin Quote Share this post Link to post Share on other sites
RW1 0 Posted September 8, 2005 I guess it was a 'workshop' manual Yeah, old "better" type Haynes manual. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 8, 2005 I guess it was a 'workshop' manual Yeah, old "better" type Haynes manual. here we are: Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 8, 2005 thanx for all the replies guys :) hopefulyl have my block out this weekend as ive got to much on in the evenings dont worryh no shamefull pics of the damage :cry: maybe ones of the new pistons in there once ive got it to a machine shop :) Quote Share this post Link to post Share on other sites
