G60mm 0 Posted October 10, 2005 For some reason my 91 Corrado G60 refuses to start. It's definately getting fuel (plugs got soaked once, but cleaned then dried). Parts changed so far for New: Fuel Filter Ignition Coil Distributor Distributor Cap Rotor Arm Ignition Timing set manually to tdc Still nothing. Car has fresh fuel, running Bosch W6DPO Spark Plugs, Leads have been checked on another car - all ok. Still no spark, I suspect it's the ecu (seeing as everything else has been eliminated). There seems to be no spark coming out of the coil. Please help as this car is my daily driver !! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 10, 2005 So its turning but not starting??? Have you got an immobiliser fitted? Checked king lead, battery voltage, engine earths? Quote Share this post Link to post Share on other sites
_Monkey 0 Posted October 11, 2005 I had the same problem, i tried everything, it turned out it was the hall sender in the dizzy, they're quite prone to going. Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 11, 2005 The wet plugs is a bit strange as the ECU would need to be working to do that??? There would also need to be a signal out of the hall sender for the ECU to know the engine was turning and that it should fire the injectors. Could be the coil? Gavin Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 11, 2005 Well, he's swapped the coil and dizzy - maybe time to check the wiring... Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 11, 2005 Oh yeah! :oops: Although maybe the output to the coil in the ECU is bad. Could try his ECU in the donor vehicle first. Don't fit a known good ECU to the bad car, without proving the ECU is dead. You may end up with 2 duff ECUs. Gavin Quote Share this post Link to post Share on other sites
g60griff 0 Posted October 11, 2005 i had this exact problem. it did turn out to be the feed from the ecu to the dizzy, i got an auto electrian in and he just put a new feed in. good as new now. Quote Share this post Link to post Share on other sites
_Monkey 0 Posted October 11, 2005 My mate had a similar problem in his rallye, apparently the battery was suffering and it was using up all it's power to turn the starter motor so it couldn't power up the ecu. It's a long shot, but worth a try. Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 11, 2005 Seen that on other cars where the ign switch is duff. When you release the key you get a spark and the engine catches, just. If you hold it all the way to crank it never starts. The fuel could be getting through as the switch is released, the sparks don't get chance to ignite it....?? Gavin Quote Share this post Link to post Share on other sites
Henny 0 Posted October 11, 2005 yup, that's exactly what mine was doing when my switch went on J-DUB Gav... Turn the key to ignition so that it's all ready to run, but don't turn it to start. Make sure the car is out of gear Connect a THICK wire to the spade terminal on the starter solenoid and touch the other end to the +ve on the battery to "trick" the car into starting (basically a partial hot wire) If this works and the car starts, then you have a dodgy ignition switch... ;) Good luck! Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 11, 2005 So its turning but not starting??? Have you got an immobiliser fitted? Checked king lead, battery voltage, engine earths? Immobiliser is fitted, but work ok ( i get green light) Battery is also new Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 11, 2005 The green on the immobiliser wouldn't be proof that the relays inside are ok. But I think the ign switch deal is more likely from what you have posted.... Immobilisation would be on the starter motor crank wire and the fuel pump feed. As it turns over and you have wet plugs we cam eliminate them I reckon. Gavin Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 11, 2005 Will try direct feed to starter tonight, I'll keep you guys posted. Many thanks everyone for all your input so far Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 12, 2005 well that did not work, tried and just the same no spark what so ever Quote Share this post Link to post Share on other sites
Henny 0 Posted October 12, 2005 Cool, that's probably ruled out the switch then... 8) It could still be a dead hall sender in the dizzy then... otherwise, I'd go with a dead imobiliser no matter what the little lights are showing... :| Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 12, 2005 it has a brand new dizzy Quote Share this post Link to post Share on other sites
Henny 0 Posted October 12, 2005 looks like an immobiliser problem then... :| Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 12, 2005 thanks henny i will give it a check :cry: Quote Share this post Link to post Share on other sites
Henny 0 Posted October 12, 2005 reading back through this thread again, you've basically narrowed the fault down to 4 things. (excluding the posibility of a dodgy new component) 1) your immobiliser 2) the ECU 3) the ECU relay 4) dodgy wiring... I'm assuming that you've checked that your coil has power. Have you tried your ecu in another car to eliminate that from the equation? That'd be the first thing that I'd try... I'd then swap across an ECU relay to make sure that's working properly... after that it's a case of removing the imobiliser and then as a final resort start buzzing wires through to find the problem... Good luck mate... 8) Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 12, 2005 the ecu relay have 30 on it if so have changed today, still nothing Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 12, 2005 I dont know if this will help but the car was running ok then began to misfire and pop flames out of the back, then nothing it has not fired since Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 12, 2005 Have you tried your ecu in another vehicle Quote Share this post Link to post Share on other sites
G60mm 0 Posted October 12, 2005 no other g60 around to try the ecu in Quote Share this post Link to post Share on other sites
Tempest 0 Posted October 12, 2005 Can only suggest the ECU as well, as after long searches into my G60 starting problem, I fitted the very original ECU (ending with letter 'B') and the very original chip again, and voila, 3 times now, each time with a full day inbetween, my G60 started without any stutter whatsoever! The ECU can hence be a big factor in the equation of starting. Tempest Quote Share this post Link to post Share on other sites
g60griff 0 Posted October 13, 2005 this sounds exactly the same as mine. check the feed from the ecu to the dizzy. Quote Share this post Link to post Share on other sites
